Legacy Personal Blogs How to get EEG data via Bluetooth from Mind Flex toy
  • Author Author: kk99
  • Date Created: 23 May 2019 2:16 PM Date Created
  • Views 4109 views
  • Comments 5 comments
  • neurosky
  • tgam1
kk99
kk99
23 May 2019
Mind Flex is toy which allow users to control elements thing in game based on brain-computer interface. It contains NeuroSky TGAM1 chipset which is a single channel EEG with support for UART/Serial communication. By default chipset returns information about attention/meditation and EEG power bands values. It is possible to receive a raw EEG data but it requires a change in configuration on TGAM1 board. There are two pads BR0 and BR1 which are responsible for configuration of output baud rate and data content. I used a default configuration with 9600 baud with normal output mode (without raw data).
In my modification I have added a HC05 Bluetooth module to output of TGAM1 board. Module is powered from main board via main switch.
Below are images from modification:
After pairing in Linux system the HC05 module is available as following serial device: /dev/rfcomm0.
To receive data I have used synapse-python application which implements ThinkGear protocol and allows to visualize the data. Application is available here with installation manual: synapse-python
Here is example output from these application:
In attachment there are documentations for TGAM1 board and protocol specification. At below page there is more detailed explanation of similar modification with usage of Arduino: brain-hack
imagemindset_communications_protocol.pdf
imageneurosky_eeg_brainwave_chip_and_board_tgam1.pdf
    DAB over 7 years ago +2
    Nice device. I used an earlier Neurosky device to watch my pain levels. Very interesting effect on concentration. DAB
    dubbie over 7 years ago +1
    This looks like an interesting toy and and interesting modification. I've always wanted to see my own brain ways - not sure why, perhaps I watched too many Big Bangs. Dubbie
    dubbie over 7 years ago in reply to DAB +1
    DAB, That sounds interesting. I have pain sometimes, and if I don't I can also exercise, or garden, or walk or ... Dubbie
    Dubbie
    Dubbie
