Legacy Personal Blogs I am getting a Panic code on boot up.
  • Author Author: donb
  • Date Created: 28 Mar 2015 4:25 PM Date Created
  • Views 1143 views
  • Comments 6 comments
donb
donb
28 Mar 2015
I had my Pi system off for a while and moved it to a different work space and when I tried to boot up I get:
Panic:VFS: unable to mount root fs on unknown-block(179,8).
From what I have read this is an error while loading some file in the boot procedure.
I am using Rasbian a Debian Wheezy port, optimized for Raspberry Pi.
I would like if I can replace the one file that seems to be corrupt, and what file that is on the SD card.
Thanks  Don
  • donb
    donb over 11 years ago in reply to gadget.iom +1
    may have been a little vague. I edited the post.
  • clem57
    clem57 over 11 years ago +1
    It has almost always happened at unclean shut downs. Sometimes, when booting even if power is taken off, it gets corrupted. You have a software error created by bad block data. I can give you two ways…
  • donb
    donb over 11 years ago in reply to clem57
    Thanks I generally do a controlled shutdown but perhaps did not one time.
    Thanks for the post
  • clem57
    clem57 over 11 years ago in reply to donb
    Most likely you may have had a power pulled without a good shutdown. Please try to always do a "sudo shutdown - h now" command if possible.
    Clem
  • donb
    Thanks Clem I am not versed enough to try to do brain surgery so will opt for a new build
    Thanks again, I appreciate your time.
  • clem57
    It has almost always happened at unclean shut downs. Sometimes, when booting even if power is taken off, it gets corrupted. You have a software error created by bad block data. I can give you two ways out. The simple to rebuild the card from scratch. This means loosing all data. It requires the master boot record be rewritten as a new single partition and reinstall software. The second may recover your data but is more like brain surgery on the card.
    Clem
  • donb
