Legacy Personal Blogs I would like some help
  • Date Created: 25 Mar 2014 10:54 PM Date Created
  • Views 568 views
  • digit
  • segment
  • display
  • 7
  • 4
e14 Contributor
e14 Contributor
25 Mar 2014
I am using a MSP430
Can you please tell me
How can i put the correct numbers that i want to be on the 4 digit 7 segment display
int digit1 = 2; //PWM Display pin 1
int digit2 = 10; //PWM Display pin 2
int digit3 = 14; //PWM Display pin 6
int digit4 = 19; //PWM Display pin 8
int segA = 5; //Display pin 14
int segB = 6; //Display pin 16
int segC = 7; //Display pin 13
int segD = 8; //Display pin 3
int segE = 18; //Display pin 5
int segF = 15; //Display pin 11
int segG = 11; //Display pin 15
int num=0;
void setup() {
pinMode(segA, OUTPUT);
pinMode(segB, OUTPUT);
pinMode(segC, OUTPUT);
pinMode(segD, OUTPUT);
pinMode(segE, OUTPUT);
pinMode(segF, OUTPUT);
pinMode(segG, OUTPUT);
pinMode(digit1, OUTPUT);
pinMode(digit2, OUTPUT);
pinMode(digit3, OUTPUT);
pinMode(digit4, OUTPUT);
Serial.begin(9600);
pinMode(13, OUTPUT);
void loop()
if(Serial.available()>0)
num = Serial.read();
dispNumber(num);
void dispNumber(byte toDisplay) {
#define DISPLAY_BRIGHTNESS 600
#define DIGIT_ON HIGH
#define DIGIT_OFF LOW
long beginTime = millis();
for(int digit = 4 ; digit > 0 ; digit--) {
//Turn on a digit for a short amount of time
switch(digit) {
case 1:
digitalWrite(digit1, DIGIT_ON);
break;
case 2:
digitalWrite(digit2, DIGIT_ON);
break;
case 3:
digitalWrite(digit3, DIGIT_ON);
break;
case 4:
digitalWrite(digit4, DIGIT_ON);
break;
//Turn on the right segments for this digit
ligNumber(toDisplay % 10);
toDisplay /= 10;
delayMicroseconds(DISPLAY_BRIGHTNESS); //Display this digit for a fraction of a second
//Turn off all segments
ligNumber(10);
//Turn off all digits
digitalWrite(digit1, DIGIT_OFF);
digitalWrite(digit2, DIGIT_OFF);
digitalWrite(digit3, DIGIT_OFF);
digitalWrite(digit4, DIGIT_OFF);
while( (millis() - beginTime) < 10) ; //Wait for 20ms to pass before we paint the display again
void ligNumber(int numToDisplay) {
#define SEGMENT_ON LOW
#define SEGMENT_OFF HIGH
switch (numToDisplay){
case 0:
digitalWrite(segA, SEGMENT_ON);
digitalWrite(segB, SEGMENT_ON);
digitalWrite(segC, SEGMENT_ON);
digitalWrite(segD, SEGMENT_ON);
digitalWrite(segE, SEGMENT_ON);
digitalWrite(segF, SEGMENT_ON);
digitalWrite(segG, SEGMENT_OFF);
break;
case 1:
digitalWrite(segA, SEGMENT_OFF);
digitalWrite(segD, SEGMENT_OFF);
digitalWrite(segE, SEGMENT_OFF);
digitalWrite(segF, SEGMENT_OFF);
break;
case 2:
digitalWrite(segC, SEGMENT_OFF);
digitalWrite(segG, SEGMENT_ON);
break;
case 3:
break;
case 4:
break;
case 5:
digitalWrite(segB, SEGMENT_OFF);
break;
case 6:
break;
case 7:
break;
case 8:
break;
case 9:
break;
case 10:
break;
Thank you.
