Legacy Personal Blogs Information Display System using WeMOS and MAX7219
  • Author Author: oksbwn
  • Date Created: 13 May 2017 4:42 PM Date Created
  • Views 1337 views
  • wemos display
  • alberto
  • max7219
  • bikash panda
  • max72
  • weargenius
  • wemos
  • oksbwn
oksbwn
oksbwn
13 May 2017
This tutorial is all about making a WiFi based information display system. This system is built around ESP8266 but not the standalone ESP8266 instead WeMOS is used and programmed using Arduino IDE. So In this video, we will check out how to make an information display system like that using Wemos and MAX7219 based dot matrix display modules. The display system fetches data from the local/online server and displays the received. In this system, u can display any data that you want and that's up to you however over here I am using this to display my YouTube subscribers and twitter followers count.
Code:
#include <ESP8266WiFi.h> #include <SPI.h> #include <bitBangedSPI.h> #include <MAX7219_Dot_Matrix.h>  const byte chips = 4; //No of MAX7219 Dpt Matrix Display unsigned long lastMoved = 0; unsigned long MOVE_INTERVAL = 100;  // mS int  messageOffset;  MAX7219_Dot_Matrix display (chips, 2);  // Chips / LOAD  char message [90] = "WeArGenius                       "; //String to be displayed  const char* ssid = "weargenius"; // SSID Of the Router const char* password = "omisoksbwn";// Access point Password const char* host = "192.168.0.1"; //Server IP or URL int requestTime=0; int exitT=1;  void updateDisplay () {   display.sendSmooth (message, messageOffset); //Display commands for the Matrix   // next time show one pixel onwards   if (messageOffset++ >= (int) (strlen (message) * 8))     messageOffset = - chips * 8; }  // end of updateDisplay  void setup() {   display.begin (); //Initialize teh displays   Serial.begin(115200);    delay(100);   Serial.println();   Serial.print("Connecting to ");   Serial.println(ssid);   WiFi.begin(ssid, password); // Initiate connection to the Wi-Fi network   while (WiFi.status() != WL_CONNECTED) {     delay(500);     Serial.print(".");   }   Serial.println("");   Serial.println("WiFi connected");     Serial.println("IP address: ");   Serial.println(WiFi.localIP()); //Printout the IP assigned to the module in DHCP   display.setIntensity(15); // Intensity of the Dot Matrix module can be 0-15 }  void loop() {   if(millis()-requestTime>120000){ // Request data from the Srever after every 2 Minutes     requestTime=millis();     Serial.print("connecting to ");     Serial.println(host);          WiFiClient client;     const int httpPort = 80;     if (!client.connect(host, httpPort)) { //Connect to SERVER       Serial.println("connection failed");     }          String url = "/test/index.php"; //Path of the webpage in the server to request     Serial.print("Requesting URL: ");     Serial.println(url);     client.print(String("GET ") + url + " HTTP/1.0\r\n" +         "Host: " + host + "\r\n" +          "Connection: close\r\n\r\n");      while (client.available() == 0) { // check Response from server     if (millis() - requestTime >30000) { // 30 seconds to wait for response before timeout       Serial.println(">>> Client Timeout !");       client.stop();       exitT=0;       break;     }     }     String line="";     while(client.available()){ // Read response from Server       line += client.readStringUntil('\r');     }     line=line.substring(line.indexOf('[')+1,line.indexOf(']')); // Process the response     Serial.println(line);     int i;     for (i=0;i<line.length();i++) // Put response  to char array to display       message[i]=line[i];      if(exitT==1){        exitT=1;       Serial.println("closing connection");       client.stop();     }   }   for(int i=0;i<5000;i++){ // Display the content     if (millis () - lastMoved >= MOVE_INTERVAL){       updateDisplay ();       lastMoved = millis ();     }     delay(1);   } }
MAX7219 Library for WeMOS: http://bit.ly/2oTtoty
Arduino HTTP Call (ESP8266): http://bit.ly/2r8yKBp
Fetch data using XPATH and PHP: http://bit.ly/2pGB0zC
Programming Esp8266 using Arduino IDE: http://bit.ly/2hdARij
Github Repository: http://bit.ly/2r8GFhX
Schematic: http://bit.ly/2pG6ogI
More Videos on ESP8266: http://bit.ly/2ijh6qX
Projects Like This: http://bit.ly/2r8x8rr
Related VIdeos:
Getting started with ESP8266 : http://bit.ly/2fchgTc
ESP8266 with Raspberry Pi : http://bit.ly/2fchHgb
Subscribe on YouTube : https://goo.gl/FhfdL7
Guys Subscribe to my channel for latest contents into your inbox.
___________________________________________
Website: http://www.weargenius.in
Twitter: https://twitter.com/geekybikash
YouTube: https://www.youtube.com/weargenius
Instagram: https://www.instagram.com/weargenius/
GIT : https://github.com/oksbwn
Facebook: http://www.facebook.com/geekybikash
