Legacy Personal Blogs IOError: [Errno 9] Bad file descriptor (Multi-threaded SPI Issue)
  • Author Author: alanmcdonley
  • Date Created: 4 Jul 2016 1:17 PM Date Created
  • Views 1935 views
  • python;
  • spi interface
  • multi-threading
  • sensor-polling
alanmcdonley
alanmcdonley
4 Jul 2016
In my case this error was occurring due to multi-threaded accesses to a MCP23S17 I/O expander and an MCP3008 ADC analog to digital converter.
Errors looked like:
File "/home/pi/RWPi/PDALib.py", line 324, in writeDio
r = spi.xfer([0x40,reg,val&255,val>>8])
and
File "/home/pi/RWPi/PDALib.py", line 319, in readDio
r = spi.xfer([0x41,reg,0,0])
The fix in Python appears to be to use a critical section around the reads and writes:
import threading
dio_lock = threading.Lock()    # mutex variable that threads will attempt to grab
def read_something( ):
    with dio_lock:      # critical section
        value=perform function
        return value
def write_something( ):
        return value
I was running three polling threads - bumpers, ultrasonic distance, and motor control - that were frequently causing the
"IOError: [Errno 9] Bad file descriptor" exceptions.
Since adding the critical section around the reads and writes, I have not seen the error.
  • clem57
    clem57 over 10 years ago
    So the events were overlapping and therefore not being serviced soon enough. Lessons learned.
    C
  • clem57
    C
