Legacy Personal Blogs Issue using Energia for the CC3200 LaunchXL
  • Author Author: kweber250
  • Date Created: 26 Dec 2018 8:31 PM Date Created
  • Views 1889 views
  • Comments 7 comments
kweber250
kweber250
26 Dec 2018
Hello All,
I'm trying to compile this code in Energia and I receive the error below, I receive a similar error regardless of the code, if I need to download a library to write in c, which library and where do I download it.
Thank you!
////////////////////////////////////////CODE/////////////////////////////////////////
#include <msp430.h>
volatile unsigned int i;
void main(void) {
WDTCTL = WDTPW | WDTHOLD;
P1DIR |= (1<<0);
P1OUT &= ~(1<<0);
while(1) {
P1OUT ^= (1<<0);
i = 65535;// SW Delay
while(i --!= 0);
////////////////////////////////ERROR/////////////////////////////////////////
Build options changed, rebuilding all
test.c:1:20: error: msp430.h: No such file or directory
#include <msp430.h>
compilation terminated.
exit status 1
    Jan Cumps over 7 years ago +3
    This does not seem to be energia code. Energia code looks and feels like arduino sketches. msp430.h is not for a cc3200 controller. You seem to try and use msp430 registers on the cc3200. These two controller…
    Jan Cumps over 7 years ago in reply to kweber250 +3
    You’d use an IDE such as TI’s code composer studio for non-energia projects. Energia, like the Arduino IDE, expects you to follow the sketch way of working.
  • jomoenginer
    jomoenginer over 7 years ago +2
    This might be more inline with what you are looking for. https://energia.nu/pinmaps/cc3200-launchxl/ http://energia.nu/guide/boards/ https://forum.43oh.com/forum/125-energia-tivaccc3xxx/ Is there a particular…
    You seem to try and use msp430 registers on the cc3200. These two controller families aren’t register compatible.
  • kweber250
    kweber250 over 7 years ago in reply to Jan Cumps
    Oh I see, I thought C and C++ could be used in Energia?
  • kweber250
  • fmilburn
    fmilburn over 7 years ago in reply to kweber250
    You can use C / C++ but as Jan says, that is not Energia compliant code.  You can find more about Energia and the link to download the IDE here:  http://energia.nu/
    There is a blink sketch in the examples that does what you are attempting above.
  • phoenixcomm
    phoenixcomm over 7 years ago in reply to kweber250
    Yes, You can use C/C++ with the TI CCSx or just run Eclipse. BTW CSSx is Eclipse
