Legacy Personal Blogs Knipex pliers
  • Author Author: neuromodulator
  • Date Created: 11 Mar 2020 5:01 AM Date Created
  • Views 2397 views
  • Likes 20 likes
  • Comments 21 comments
Knipex pliers
neuromodulator
neuromodulator
11 Mar 2020
I recently received a nice package from E14:
Of all these items my favorite items are the Knipex pliers. They are mostly cutters and so far I'm very happy with them as they appear to be very high quality and well built. Lets take a closer look at them.
These cutters have a longer handle, use a coiled spring and have an opening limiter mechanism. Cutting with them is effortless, these are the kind of pliers I would first chose to cut electronic component leads. The only difference between these 4 cutters is that gray ones have ESD protection, and that the bigger ones can cut through bigger diameters.
Then we have the rest of the pliers with shorter curved handles:
Here are some close-ups of their jaws:
This one is really nice, it contains a "lead-catcher", which is a mechanism that keeps the cutted lead stuck until you open the grips:
This one is interesting, the cutting piece is made of a different material, which I suspect is tungsten carbide. The hard cutting piece cut even piano strings (which are very hard):
Of all the pliers these two are the only one that are not cutters, and are what I would use to bend wires:
    dubbie over 6 years ago +7
    What a great set of cutters. Who would have thought that so many different cutters even existed! I'd be tempted to arrange these in a big circle and stick them on a wall, as wall art. As they do in Stately…
    shabaz over 6 years ago in reply to Gough Lui +7
    As non-electronics-engineers find out, when they borrow tools without asking, and try to mess with mains electricity! Come back complaining that they got tingles and there's something wrong with the tools…
  • neuromodulator
    neuromodulator over 6 years ago in reply to 14rhb +5
    I don't know, but there are other important differences between the 2 types. Coiled spring ones have an opening limiter, while leafed ones don't. Coiled ones require less force as result of longer handles…
  • 14rhb
    14rhb over 6 years ago
    An awesome range, thanks for photographing them in such detail and describing each. Whilst reading I notice some have a coil spring while others use a pair of leafs. Any ideas why Knipex have gone for both approaches?
  • 14rhb
  • neuromodulator
    I don't know, but there are other important differences between the 2 types.  Coiled spring ones have an opening limiter, while leafed ones don't. Coiled ones require less force as result of longer handles, smoother pivot points and apparently a weaker springs. I haven't checked if Knipex sells spring replacements, and if they ever wear out before the cutting piece, but leaf springs are easy to remove and replace, I'm not sure about coiled springs.
    • Vote Up +5 Vote Down
  • knipex
    knipex over 6 years ago in reply to neuromodulator
    Yes, that's the difference. image
