Legacy Personal Blogs Leakage current & current leaks – part 3
  • Author Author: mlease
  • Date Created: 2 Jun 2015 3:34 PM Date Created
  • Views 693 views
  • voltage_divider
  • low_power
  • i2c
  • leakage_current
  • hardware_design
  • spi
  • thermistor
  • thermal_design
  • chip_select
mlease
mlease
2 Jun 2015
This post will focus on “current leaks”, the points of power consumption that are often designed into a device without much thought. In some cases they are things you have some amount of control over, in other cases they are things you have little control over but have to account for in your power budget in order to get an accurate power consumption or battery life estimate. While technically not leaks as in leakage current, I call them leaks because they are where your battery life drains away.
Read the complete post at http://cmicrotek.com/wordpress_159256135/.
  • clem57
    clem57 over 11 years ago
    Dont know why I missed these, but glad I found them here. Seems like many places to worry about if you have to design a battery powered MCU. Thanks
