Legacy Personal Blogs Let's try this again
  • Author Author: sasquatch84
  • Date Created: 31 Aug 2017 4:57 AM Date Created
  • Views 1442 views
  • Comments 7 comments
sasquatch84
sasquatch84
31 Aug 2017
Ok, so I grabbed another Nano and got it all wired up like the last one.  I soldered a diode directly onto the solenoid valve contacts.  Maybe I should have just put it on the circuit board?  Anyone think I should?  Let me know.
Also, I tried my hand at making a schematic.  Let me know if this makes sense.
I'm not plugging anything in until I get at least a little feedback on here. (gulp!)
    jw0752 over 8 years ago +3
    Continuing: The diode soldered to the solenoid is actually a good idea as it deals with the counter EMF right where is occurs. Here is an example of part of your schematic. My schematic assumes that the…
    beacon_dave over 8 years ago in reply to jw0752 +3
    Perhaps one downside to soldering the diode directly to the solenoid though is that if someone (especially a third party) has to replace the valve at a later point in time, then they may not realise that…
    jw0752 over 8 years ago in reply to sasquatch84 +3
    Thank you to gecoz for stepping in with some great advice. I am 2 hours later that Clinton and I got tired and went to bed before we could finish last night. If you really don't like heat get one of these…
    Hi Clinton,
    The diode in your schematic is backwards. Remember the marked end has to go towards the + voltage supply. As wired the relay would be energized all the time. The pole of the relay should be tied to the ground and not to pin D8. I would redraw it for you but I wanted to make sure you didn't test this arrangement as the diode backwards would possibly damage your relay.
    Hi Clinton,
