Legacy Personal Blogs Looking for a rugged hinged SIM connector?
  • Author Author: LaurenceHillGCT
  • Date Created: 24 Feb 2015 10:15 AM Date Created
  • Views 734 views
  • robust_sim_connector
  • hinged_sim_connector
LaurenceHillGCT
LaurenceHillGCT
24 Feb 2015
Then look no further than SIM5055 from GCT!  This hinged SIM Connector accepts Mini SIM cards, it's robust locking mechanism holds the SIM card tight and provides solution resistant to vibration and mechanical shock. The hinge opens, the SIM card is slotted into place, the lid closes then the metal clip is pushed across to hold the lid in place.  SIM cards are polarised, to allow the card to be inserted only in the correct orientation.
A customer using this part in volume tests mechanical shock independently by striking a large metal weight against a panel, on the reverse of the panel is the connector loaded with SIM card, the customer measures for discontinuity of signal and is happy that this connector provides piece of mind for their challenging security application.
SIM5055 has six contacts, is 2.50mm (.098") profile above the PCB, it also features a card detection switch which electronically measures card presence, the switch is 'normally open'..
SIM5055 - Hinged Mini SIM - 6 contacts with card detection switch - LooseSIM5055 - Hinged Mini SIM - 6 contacts with card detection switch - Loose
Resources:
Find product specification and 3d models at the GCT SIM5055 page.
