Legacy Personal Blogs Makevember : Wire Frame Christmas Trees
  • Author Author: dubbie
  • Date Created: 11 Nov 2019 12:01 PM Date Created
  • Views 3603 views
  • Likes 15 likes
  • Comments 19 comments
  • makevember
  • wire frame trees
dubbie
dubbie
11 Nov 2019
For a contribution to the Makevember topic I decided to make some wire frame Christmas tree decorations. I wanted to make them to look good and to have some LEDs on them. I didn't quite (yet) manage this although I have made something, see below.
I aim to try and improve more on the wire frame trees and then I will have to work out some way of attaching LEDs and getting them to light up nicely.
Dubbie
    jw0752 over 7 years ago +7
    Hi Dubbie, I got curious and decided to run my own experiment with some 3.16 mm ( 1/8 inch ) aluminum ground wire that I had in the shop. Here is the initial shape of the wire: I put the wire in the vise…
  • fmilburn
    fmilburn over 7 years ago in reply to dubbie +5
    I have not tried it but have seen several times where people used a drill to straighten copper wire: https://www.youtube.com/watch?v=meZRMNF-6tQ. A good idea to have eye protection and gloves while doing…
    jw0752 over 7 years ago in reply to fmilburn +5
    I do a lot on things with wire as a structural material. I usually put one end of the wire in a secured vise and the other end in a drill chuck. I pull the wire as tight as I can and give it about one…
    dubbie over 7 years ago in reply to jw0752
    John,
    My original idea was to use two identical wire trees and solder the LEDs between them. The Aluminium seems to have a low resistance, under 1 Ohm. I was expecting to find a skin of Aluminium Oxide on the wire which I think is an insulator, but it didn't seem to be there. Perhaps the wire had not been exposed to enough air, or maybe it is some sort of Aluminium alloy anyway.
    When I couldn't make two identical trees I just used a pre-existing LED string of bead LEDs that I think are all wired in parallel to a 3V battery pack. The connecting wires on the LED string seem to have a plastic coating so are insulated from the Aluminium wire so I just wrapped the LED string around the wire tree shape. It is not particularly good but it gave some idea of what it would look like.
    Dubbie
    John,
    Frank also mentioned this approach. I will have to give it ago. I have only ever used the stretching method before but stretching 2 mm Aluminium wire takes some doing..
    Dubbie
    dubbie over 7 years ago in reply to fmilburn
    Frank,
    I hadn't thought of putting the wire into a drill like this. I might give it a go, although I'm not sure that 2 mm Aluminium wire will twist nicely. It might also produce a nice surface twist finish.
    Dubbie
    Hi Dubbie,
    This looks like a fun project and while it may seem simple there are always side effects and challenges to make it more fun. How did you handle the electrical with the different voltage drops in the different color LEDs? I was guessing a series with constant current but perhaps you had a better idea.
    I do a lot on things with wire as a structural material. I usually put one end of the wire in a secured vise and the other end in a drill chuck. I pull the wire as tight as I can and give it about one turn per meter. It amazingly makes the wire as straight as can be.
    • Vote Up +5 Vote Down
