Legacy Personal Blogs Max32 IO Code - first run...
  • Author Author: patkelly
  • Date Created: 26 Mar 2012 7:03 AM Date Created
  • Views 392 views
patkelly
patkelly
26 Mar 2012
Here is the code that I used to get the OI shield to display, it's a mashup of the demo script and the usual Arduino button script. So if you switch the sliding switch at pin 2 on, the OLED screen turns on, switch it again it goes off.
A few prerequisites, when you download the OLED demo from the Max32 website the example code is in a different folder to the files required so make sure you copy all these over to the same directory (it's one those silly little things that gets you scratching your head, for ages going "but it's right, just work"):
  • ChrFont0.c
  • delay.c
  • delay.h
  • FillPat.c
  • IOSheildOled.cpp
  • IOShieldOled.h
  • OledChar.c
  • OledChar.h
  • OLedDriver.c
  • OledDriver.h
  • OledGrph.c
  • OledGrph.h
<-------Code Start--------->
#include <IOShieldOled.h>
const int buttonPin = 2;
int buttonState = 0;
void setup()
  IOShieldOled.begin();
  pinMode(buttonPin, INPUT);
void loop()
  int irow;
  int ib;
  //Clear the virtual buffer
  IOShieldOled.clearBuffer();
  //Chosing Fill pattern 0
  IOShieldOled.setFillPattern(IOShieldOled.getStdPattern(0));
  //Turn automatic updating off
  IOShieldOled.setCharUpdate(0);
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed.
  // if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // turn LED on:
    IOShieldOled.displayOn();
  else {
    // turn LED off:
    IOShieldOled.displayOff();
  for (irow = 0; irow < IOShieldOled.rowMax; irow++)
    IOShieldOled.setCursor(0, 0);
    IOShieldOled.putString("element14.com");
    IOShieldOled.setCursor(0, 1);
    IOShieldOled.putString("Community");
    IOShieldOled.setCursor(0, 2);
    IOShieldOled.putString("by PK");
    IOShieldOled.setCursor(0, 3);
    IOShieldOled.putString("Not bad eh!");
    IOShieldOled.updateDisplay();
    delay(100);
  delay(100);
<------------Code End--------------->
