Legacy Personal Blogs Micron 40th Anniversary
  • Author Author: kevinkeryk
  • Date Created: 5 Oct 2018 7:52 AM Date Created
  • Views 1457 views
  • Comments 6 comments
  • micron
  • memory
kevinkeryk
kevinkeryk
5 Oct 2018
According to this Wikipedia entry here, today is the 40th anniversary for Micron:
https://en.wikipedia.org/wiki/Micron_Technology
So happy birthday to you Micron, you are really a great supplier to work with on several projects over the years!
I came across this very old flyer in a magazine I uncovered when I was cleaning up my office a few weeks ago and I wanted to post here to share my nostalgia with the community:
Interesting that although the technology has changed along the way, the need for more memory in a system will always be a timeless requirement from software engineers like myself. image
I am guessing by the memory density, this would ad would have been from sometime around 1995.  Any other cool Micron nostalgia available from other community members?
  • Gough Lui
    Gough Lui over 8 years ago +6
    Well, the SIMMs in the image have chip numbering of 9246 meaning Week 46, 1992, if that helps place the ad. I don't think it would have been as late as 1995 as 30-pin SIMMs such as the above generally…
  • Gough Lui
    Gough Lui over 8 years ago in reply to genebren +2
    Well, before that, I remember the days of doing tweaks to CONFIG.SYS to ensure I had HIMEM.SYS to allow for >640k, LOADHIGH as many device drivers as possible, freeing up as much conventional memory as…
  • kevinkeryk
    kevinkeryk over 8 years ago in reply to Gough Lui +1
    Thank you for the info Dr. Lui! That is an amazingly well curated collection that you have! I agree, the memory in the ad in probably earlier than the ad itself since marketing folks are known to use older…
  • Gough Lui
    Well, the SIMMs in the image have chip numbering of 9246 meaning Week 46, 1992, if that helps place the ad. I don't think it would have been as late as 1995 as 30-pin SIMMs such as the above generally stopped as soon as the 80486 became popular - they normally used 72-pin SIMMs although there was a SIMMverter that could be used to adapt four (if I recall correctly) 30-pin SIMMs into a 72-pin SIMM.
    Speaking of which, there is just one module with Micron chips lurking around my "The SIMMS" page, with a number of other contemporary manufacturers represented. A similar story on my SDRAM collection as well. That being said, my first computer I had access to at home had Micron Technology 30-pin SIMMs (a 386SX 16Mhz). Later Micron's consumer-memory division became Crucial.
    - Gough
    • Vote Up +6 Vote Down
  • kevinkeryk
    Thank you for the info Dr. Lui!  That is an amazingly well curated collection that you have!  I agree, the memory in the ad in probably earlier than the ad itself since marketing folks are known to use older stock images image
    -Kevin
  • kevinkeryk
    -Kevin
  • Gough Lui
    Gough Lui over 8 years ago in reply to kevinkeryk
    On a quick inspection, the ad seems to have 1M x 1-bit chips, of which there would be 9 on a single 30-pin parity-enabled SIMM, making each of them 1MB modules. So indeed, you probably are right, since the ad references 4Mb 30-pin SIMMS with parity (i.e. x9) and also 16Mb 72-pin SIMMS with parity (i.e. x36). What a shame, as I used to have more of them lying about, but in our haste to clean-up the house on a move, they were thrown out along with my old 486DX2-66 gear image.
    - Gough
