Legacy Personal Blogs MINI PANEL METER Project
  • Author Author: SmilinVamp
  • Date Created: 19 Nov 2015 4:14 PM Date Created
  • Views 1186 views
  • meter
  • volt
  • electronics
SmilinVamp
SmilinVamp
19 Nov 2015
This is from my BLOG TechMaester.com - Published 2012/11/23
Mini Panel Meter - TechMaester.com
Looking for a simple mini panel meter for your next project.  In this project I have added my take to the CX101 panel meter.
This particular panel meter is reliable and of reasonable quality. Best of all is it’s low cost.  It is a 3 1/2 digit meter with decent accuracy for the price.
There are a number of flavors for this meter and choice is application dependant. The CX101A & CX101B are designed to be used with an independent (isolated)  ground.  The signal being measured does not share a common ground with the supply voltage for the panel meter.
The model CX101BG is a 5 Volt version that can used with a common ground.
The CX101 series consists of three versions:
  • CX101B is a 5V version
  • CX101A is a 9V Version
  • CX101BG is a 5 V version which can use a common ground
For my purposes I have chosen the common ground version, the CX101BG.
To make this little guy useful, some additional circuitry must be added.  As The “guts” of the measurement circuit, I have added a power supply and a range selection switch.
This meter project is available in my Panel Meter – Build Log.
SEE MORE AT WWW.TECHMAESTER.COM
  • SmilinVamp
    SmilinVamp over 10 years ago
    Thanks! It's a small thing and mostly following the datasheet.  However is was necessary for my BogusBurden 4000 project
    A constant current dummy load circuit.  I was going to post it next.
    DAB over 10 years ago
    Looks like a nice clean product.
