Legacy Personal Blogs More I2C stuff
  • Author Author: packetgeek
  • Date Created: 3 Apr 2015 2:28 AM Date Created
  • Views 831 views
  • raspberry
  • i2c
  • pi
  • radio
More I2C stuff
packetgeek
packetgeek
3 Apr 2015
A couple quick switches this week...
Successfully figured out the C code to control the volume on the RDA5807.  The Bass Boost feature refuses to work.  It could be that the documentation is borked.  At this point, I'm giving up as going further means writing code for features I don't use.  Will post what code I have on Github shortly.
Started working on getting the Si4707 weather band breakout board working.  Like the others, it's becoming a "learning experience".  The documentation claims that it can be driven into 2-wire mode, using the same method used for the Si4703.  I've missed something as the chip still doesn't show up on the I2C bus.
I'm hoping to have the Si4707 figured out quickly as an entire evaluation kit for the Si4735 (think FM, AM, and short wave) was waiting for me when I arrived home.  This one will take a lot of research.  The code that comes with it is for Windows, the board interface is USB, and I'm not sure if I can piggyback a Pi onto it (fingers crossed).  Will let you known when I start playing with this.
- Tim
    Would you be so kind as to share your code? Try it with a Raspberry Pi 2. So far no success only noise
  • packetgeek
    packetgeek over 11 years ago in reply to e14 Contributor
    Andy,
    Noise is a good thing.  It means that you're close.  Probably just the tuning routine needs tweaking.
    The non-wiringPi code* shouldn't need much revision to work on the Pi2.  Maybe changing some of the pin numbers.  I don't have a Pi2 yet so I cannot comment in any detail.  I will update the code one I acquire a Pi2 or two.
    The code for the various chips is at: https://github.com/packetgeek?tab=repositories
    If you're willing, send me your code (or post it here) and I'll take a look at it.
    - Tim
    * I've not finished converting the wiringPi-based code so there may be a missing routine or two.
  • packetgeek
    Andy,
    - Tim
