Legacy Personal Blogs Multicolour Hex Key Set Torx
  • Date Created: 8 Sep 2015 12:29 PM Date Created
  • Views 512 views
e14 Contributor
e14 Contributor
8 Sep 2015
SPKL 967/9 TORX Registered BO Multicolour Hex Key Set, Black Laser
9 pieces in two-component clip, with Magnetizer. For inside TORX Registered screws and TORX Registered screws with pin (BO = hole). TORX Registered BO (BO = hole) on the short arm, TORX Registered ball end on the long arm, thereby screwing possible even in a slightly inclined state. Safe operation even under difficult circumstances. Wrench with plastic coating (SPKL) are made of round grip-friendly material. The coating makes the work even at low temperatures pleasant and safe. All angles are key quickly by their size and color coding identification on hand. The wear-free material of the clip ensures secure retention of key angles and easy removal.
Code
05073599001
967 SPKL TORXRegistered BO Multicolour
1 x TX 8x76 1);1 x TX 9x79 1);1 x TX 10x85 2);1 x TX 15x90;1 x TX 20x96;1 x TX 25x104;1 x TX 27x112;1 x TX 30x122;1
