Legacy Personal Blogs Multimeters - Some things are just worth bragging about
  • Author Author: parachaser
  • Date Created: 2 Aug 2020 5:26 AM Date Created
  • Views 1035 views
  • Comments 5 comments
  • multi meter
  • meter
  • meter dial
  • digital_meters
  • handheld_meter
parachaser
parachaser
2 Aug 2020
I have had many test meters on my bench some good , some not so good.. I had come across the AstroAI DM6000AR . Read a lot of great things about it . Very low price tag ,so I thought I would check it out.
  • PROFESSIONAL LEVEL features include Auto-Ranging capability, and True RMS for measuring both AC Current and Voltage
  • EASE OF USE: Convenient features like Data Hold, Large LCD Backlit Screen, Auto Shut-off and Hanging Magnet, and Kickstand make taking and recording measurements easier than ever before
  • IDEAL FOR COMMERCIAL settings where it can handle the demands of a long workday, from the durable exterior to the wide range of heavy-duty capabilities
  • Built-in F400mA/600V and F10A/600V explosion-proof ceramic fuse tubes; Double Protection, more secure and reliable; The fuses can protect the multi-meter effectively; Overload protection on all ranges. 3 Year Warranty provided by AstroAI. Note: Please take off the cap before using the test leads.
Test results are very impressive and very accurate .. it comes with a device for testing Transistors and caps as well , If you are looking for a low cost meter with all the bells and whistles this may be of interest to you. The only negative thing I can say about the meter is that it does not come with alligator clips for the test leads.
    Jan Cumps over 6 years ago in reply to colporteur +2
    It's the temperature sensor's business end.
  • michaelkellett
    michaelkellett over 6 years ago +1
    How accurate is the meter, what tests did you do ? Have you any pictures of it in use ? Have you opened it up to look at "Built-in F400mA/600V and F10A/600V explosion-proof ceramic fuse tubes; Double Protection…
  • parachaser
    parachaser over 6 years ago in reply to michaelkellett +1
    General usage testing is all , Voltage , resistance, capacitance etc.. No have not taken it apart,, In my younger years I would open this up just to see what them tick.. these days if it is not broke I…
  • colporteur
    colporteur over 6 years ago
    \image
    What is the probe I have circled?
  • parachaser
    parachaser over 6 years ago in reply to Jan Cumps
    Thanks Jan image You Rock !
  • parachaser
