Legacy Personal Blogs my own avr devolopement programming board
  • Date Created: 8 Mar 2015 6:28 AM Date Created
  • Views 872 views
  • Comments 5 comments
e14 Contributor
e14 Contributor
8 Mar 2015
hai every one...
i am new to element 14.. i am beginner to electronics.. i have a doubt ..
i started to design  my own avr devolopement programming board last week.. i soldered components  and followed the site-
www.robotplatform.com/howto/...board/atmega8_dev_board_3.html.. i connect  my board to 9v supply, the output to board should be 5v using a voltage regulator 7805.. but when i checked my voltage at board using multimeter it shows only 0.95volts... also my status led is also not glowing... i rechecked all the connections.. it was absolutely right... guys help me...
  • michaelwylie
    michaelwylie over 11 years ago +1
    You have the input and output caps on the regulator? It can be unstable without them.
  • michaelwylie
    e14 Contributor over 11 years ago in reply to michaelwylie
    thanks for the reply michael...
    nope..i have got an output capacitor from regulator...any way i rechecked the circuit and fixed the  problem.. thanks friend...image
