Legacy Personal Blogs New ERZ-E10 Series - Radial Leaded Disc ZNR®︎ Transient / Surge Absorber (MOV) from PANASONIC
  • Date Created: 14 Jan 2014 4:11 PM Date Created
  • Views 359 views
  • industrial
  • power_supply_input
  • anti_surge_resistors;
  • znr_surge_absorber;
  • _protection
  • industrial_machinery;
  • panasonic_industrial_europe;
  • resistors;
e14 Contributor
e14 Contributor
14 Jan 2014
Performance of a 14mm Device in an 10mm Size for Drop-In Replacement!
Watch out for the the NEW ERZ-E10 Series Radial Leaded Disc ZNRRegistered Transient/Surge Absorbers to our already outstanding ZNRRegistered product line. ZNRRegistered stands for Zinc-oxide Non-linear Resistor, also commonly known as Metal Oxide
Varistor or MOV.
Panasonic invented the ZNRRegistered Surge Absorber in 1968 and is a pioneer in the use of Zinc Oxide as a Surge Absorber. ZNRRegistered devices are used to protect electronic equipment against voltage surges and save board space and cost. The NEW ERZ-E10 Series offers a finer, more uniform grain structure which facilitates enhanced performance while allowing for size reduction. Offering voltages ranging from 200 to 1100V, the ERZ-E10 Series has the performance of a conventional 14mm diameter device in an 10mm diameter size, all with the same lead spacing for a 14mm replacement.
With the New ERZ-E10 Series you not only save money but as well PCB space.
Please check: http://uk.farnell.com/znr-surgeabsorbersimageimage
imageERZ-E10 Datasheet.pdf
