Legacy Personal Blogs New Isolated Current and Voltage Amplifiers
  • Author Author: peterjcs23
  • Date Created: 9 May 2015 7:30 PM Date Created
  • Views 847 views
  • current
  • signal conditioning
  • din-rail_mounting
  • isolation
  • amplifiers
  • voltage
  • din_rail_mount
  • analog
peterjcs23
peterjcs23
9 May 2015
I am working on the design of new isolated current and voltage amplifiers for mounting on a DIN rail.
The DRA002 will be used to measure current using an external current shunt (50mV).
DRA002 Current Ext and Voltage Int RevA
The DRA003 will be used to measure current using an internal current sense resistor rated at 12A continuous and 20A peak.
DRA003 Current Int and Voltage Int RevA
Should be available to buy online in August.
Available from:
Signal Conditioner Module - Peak Test
  • michaelkellett
    michaelkellett over 11 years ago
    The spec is a bit brief at the moment - I hope you are going to add things like linearity, noise, offset, gain accuracy and stability, frequency response  etc.
    I know you've been in the business a while, how are you planning to cope with all the regulatory nonsense that now goes with selling in the UK and EU like CE and ROHS paperwork/certification, not to mention WEEE registration and all the other stuff.
    MK
