Legacy Personal Blogs Oil Tank Monitor Components and Sketch Strategy
  • Author Author: shoemakersp
  • Date Created: 10 Feb 2013 4:36 PM Date Created
  • Views 545 views
shoemakersp
shoemakersp
10 Feb 2013
Good progress is being made on the development of my oil tank monitoring system. The circuit currently consists of the following components on a breadboard.
  • Arduino Uno
  • (1) MPX5050 Pressure transducer
  • Pushbutton
  • Nokia 5110 display (with realtor resistors
  • one way valve for air line and a "T" to allow for depth measurement.
The current version of the Sketch:
-runs a calibration routine on start up to establish a min and max value for the transducer (A0) and maps it to a value between 0 and 40.
-draws a display of 5 vertical bar graphs and dynamically updates the first graph with data from the first sensor.
Goals for the final version:
  • calibration tool to set values for each tank (use Blum's ep 10 to run through the different sensors?)
  • Values for each tank need to be calculated for the gallons contained in that tank (need capacity in gallons for each tank).
  • on board pump or "truck air" is used to create pressure in all lines before readings can begin.
  • user presses a "test" button and it turns on the pump, waits and then takes readings from all sensors.
    • will simple bar graphs on the truck suffice
    • how to output gallons data? bluetooth to phone? store to log file?
