Legacy Personal Blogs PCB Fabrication
  • Date Created: 17 May 2012 9:30 PM Date Created
  • Views 1523 views
  • pcb_fab
  • pcb
  • pcb_fabrication
PCB Fabrication
e14 Contributor
e14 Contributor
17 May 2012
PCB Fabrication is the process of manufacturing PCB(Printed Circuit Boards). A PCB contains thin layer of copper foil and insulating layers dielectric and coating it by the solder mask. The solder mask could be of different colors like green, red, black, yellow, etc. The dielectric layers are typically laminated together with epoxy resin prereg. The dielectrics have capacitance and it is really an issue of how to eleminate the capacitance and many other environmental factors that depletes the PCB's quality
  • colporteur
    colporteur over 6 years ago
    There didn't appear to be a question in your post so, I'm not sure if this commentary is relevant. I went in search of a PCB manufacture this year  Recommend Manufacture for Prototype PCB , the resources provided in the discussion were very helpful.  I have tried JLCPCB, recommended by a few members and was satisfied with the work. The context of the boards was for a small home project that didn't need to adhere to any standards. The order process was easy. The shipping costs direct, gave me reason to leave my second order at a drop box in the US. Unfortunately, closed boarders due to the COVID-19 crisis prevents me from going across and retrieving the order.
  • colporteur
