Legacy Personal Blogs PCB Fabrication
  • Date Created: 17 May 2012 9:30 PM Date Created
  • Views 1514 views
  • pcb_fab
  • pcb
  • pcb_fabrication
PCB Fabrication
e14 Contributor
e14 Contributor
17 May 2012
PCB Fabrication is the process of manufacturing PCB(Printed Circuit Boards). A PCB contains thin layer of copper foil and insulating layers dielectric and coating it by the solder mask. The solder mask could be of different colors like green, red, black, yellow, etc. The dielectric layers are typically laminated together with epoxy resin prereg. The dielectrics have capacitance and it is really an issue of how to eleminate the capacitance and many other environmental factors that depletes the PCB's quality
  • smith000
    smith000 over 6 years ago
    Use www.nextpcb.com to convert your circuit into an industry-grade professional PCB. Just upload the Gerber file and they will give you an instant quotation. They have custom shapes and color options. The quality of the PCB is excellent. I highly recommend trying once.image
  • smith000
