Legacy Personal Blogs PCB question
  • Date Created: 12 Feb 2015 12:19 AM Date Created
  • Views 1490 views
  • Comments 8 comments
  • boards
  • circuit
  • pcb
  • remotely
  • solenoid
PCB question
e14 Contributor
e14 Contributor
12 Feb 2015
I am wondering if there is a way to make a *small pcb in the realm of 2x3 inches that could run on batteries. I would want it to allow for a remote signal when that signal is received, engage a solenoid for 2-3 seconds and then reset the solenoid back to its original position. I don't know anything about PCB's and am in the need of one for a woods project at home. Just wondering if its possible and how I would go about having one made. Thanks.
  • michaelwylie
    michaelwylie over 11 years ago
    I think it's definitely reasonable. The battery will likely be bigger than the board. Unless you wanted to do it yourself, I would make a post titled something like "Looking to solicit a PCB and circuit design". The rates you get quoted will vary a lot, but this type of project could be done by a hobbyist at a reduced rate.
  • michaelwylie
