Legacy Personal Blogs PentOpiliones - robot is finished
  • Date Created: 9 Feb 2013 6:01 PM Date Created
  • Views 851 views
e14 Contributor
e14 Contributor
9 Feb 2013
I have programmed and run my five legged robot. Bellow I show you a movie with its capabilities.
A robot is controlled from a Laptop computer using a Bluetooth. It walks very nicely, even on terrain with various obstacles. Its gait is stable and fluent and can go with the speed up to 20 cm/sec. During the walk, it consume about 1,3 A, so the battery lasts for 1,5 h of walking. So far there is an assumption, that robot walk on the flat terrain because it doesn't use any force sensors in his legs, but it is sufficient to walk even in external environment. I want to thank Farnell for help and support with electronic parts to the robot.
    e14 Contributor over 13 years ago in reply to DAB
    Robot was completely designed and builded by me. In previous posts I put some of its visualisation in Autodesk Inventor Program.
    To reduce costs, most of mechanical parts and servos I bought in China (standard servos like this in RC toys). All mechanical parts cost about 450$ and electronic parts cost about 400$.
    DAB over 13 years ago in reply to e14 Contributor
    I like it.  It gives me some ideas on a lot of applications.
    Was this a kit or did you design it yourself?
    What is a rough cost to duplicate it?
    Thanks
    The two main segments of a leg (femur and tibia) have length of 15 and 25 cm, respectively. Consequently robot can raise to have a clearance between ground and trunk of 30 cm. It can go over obstacles of 20 cm high.
    Very interesting.
    How large is the robot.  I am curious about how big the obstacles need to get before it cannot maneuver.
    Cool build.
