Legacy Personal Blogs Please help in checking ir, pir sensors and gps and accordingly sending data via gsm module
  • Date Created: 11 Apr 2016 6:15 PM Date Created
  • Views 498 views
e14 Contributor
e14 Contributor
11 Apr 2016
hi
i am working on a project theft intimation of vehicles using gsm and tracking it by gps.
here i am getting stuck with the infinite loop used in gps as it is continuously sending the lattitude and longitude. i also have to check 4 ir sensors and a pir sensor continuously.
please help me urgently for how am i going to use two loops in a program, out of which one is infinite loop.
the codes i am using are
#include<SoftwareSerial.h>
#include<TinyGPS.h>
long lat, lon;
int ir1 = 4;
int ir2 = 5;
int ir3 = 6;
int ir4 = 7;
int pir = 8;
int out = 9;
SoftwareSerial gpsSerial(2,3);
TinyGPS gps;
void setup()
  pinMode(ir1, INPUT);
  pinMode(ir2, INPUT);
  pinMode(ir3, INPUT);
  pinMode(ir4, INPUT);
  pinMode(pir, INPUT);
  pinMode(out, OUTPUT);
  Serial.begin(9600);
  delay(100);
  gpsSerial.begin(9600);
  send_sms ("ANUPAM YOUR CAR IS BEING ACCESSED BY SOMEONE");
  send_sms ("AND THE POSITION OF YOUR CAR IS :");
//void loop() {}
void send_sms (char msg[])
   Serial.println("AT");
   delay(2000);
   Serial.println("ATE0");
   Serial.println('\r');
   delay(1000);
   Serial.println("AT+CMGF=1");
   delay(1000);
   Serial.println("AT+CMGS=\"9453894151\"");
   delay(1000);
   Serial.println(msg);
   Serial.println("\x1A");
   delay(1000);
void send_sms2 (long x, long y)
   delay(2000);
   delay(1000);
   delay(1000);
   delay(1000);
   Serial.print("Position: ");
   Serial.print("lat: ");Serial.print(x);Serial.print(" ");
   Serial.print("lon: ");Serial.println(y);
  delay(1000);
  void loop()
  while(gpsSerial.available())
  if(gps.encode(gpsSerial.read()))
    gps.get_position(&lat,&lon);
    send_sms2(lat,lon);
and the code for sensors is
#define ir1 4
#define ir2 5
#define ir3 6
#define ir4 7
#define pir 8
#define out 9
boolean flag_1 = LOW;
void setup()
void loop()
/* if((digitalRead(ir1) == HIGH) || (digitalRead(ir2) == HIGH) || (digitalRead(ir3) == HIGH) || (digitalRead(ir4) == HIGH) || (digitalRead(pir) == HIGH))
  digitalWrite(out,HIGH);
  flag_1 = HIGH;
else
  digitalWrite(out,LOW);
if (digitalRead(ir1) == HIGH)
else
if (digitalRead(ir2) == HIGH)
else
if (digitalRead(ir3) == HIGH)
else
if (digitalRead(ir4) == HIGH)
else
if (digitalRead(pir) == HIGH)
else
please help to merge these two codes in one
