Legacy Personal Blogs Project Crucible Raspberry Pi Benchmark Script
  • Author Author: airbornesurfer
  • Date Created: 26 Aug 2020 12:20 AM Date Created
  • Views 922 views
  • project cruicble
  • raspberry pi
  • bash
  • bash script
  • raspbian
  • benchmark
airbornesurfer
airbornesurfer
26 Aug 2020
Xybernaut Wearable PC
element14 presents  |  AirborneSurfer's VCP Profile |  Project Videos
This bash script runs as sudo, installs the sysbench application as its only dependency, and loops through three benchmarking tests giving an elapsed time and processor temperature for each test.
#!/bin/bash
[ "$(whoami)" == "root" ] || { echo "Must be run as sudo!"; exit 1; }
# Install sysbench if needed
if [ ! `which sysbench` ]; then
  apt-get install -y sysbench
fi
clear
sync
echo -e "element14 Presents 'Project Crucible'"
echo -e "Raspberry Pi Benchmark Test"
echo -e "CC-BY-SA AirborneSurfer Productions"
# Show current hardware
vcgencmd measure_temp
vcgencmd get_config int | grep arm_freq
vcgencmd get_config int | grep core_freq
vcgencmd get_config int | grep sdram_freq
vcgencmd get_config int | grep gpu_freq
# Loop benchmark tests
while true
do
echo -e "Running CPU test..."
sysbench --num-threads=4 --validate=on --test=cpu --cpu-max-prime=1000 run | grep 'total time:\|min:\|avg:\|max:' | tr -s [:space:]
echo -e ""
echo -e "Running THREADS test..."
sysbench --num-threads=4 --validate=on --test=threads --thread-yields=1000 --thread-locks=6 run | grep 'total time:\|min:\|avg:\|max:' | tr -s [:space:]
echo -e ""
echo -e "Running MEMORY test..."
sysbench --num-threads=4 --validate=on --test=memory --memory-block-size=1K --memory-total-size=3G --memory-access-mode=seq run | grep 'Operations\|transferred\|total time:\|min:\|avg:\|max:' | tr -s [:space:]
echo -e ""
done
