Legacy Personal Blogs projects
  • Author Author: atillad
  • Date Created: 10 Oct 2016 3:59 AM Date Created
  • Views 699 views
projects
atillad
atillad
10 Oct 2016
i have multiple projects currently one of wich is a project others have don but. i havent worked on my self so here is pictures of the piboy project so far.
currently the piboy project is on hold till i can get a 3d printer so i can make the case as for my other project.
i a wile back got a full sized stand up arcade unit for 10$ and have it almost fully running. all the controls work one of the coin acsepter lights work wile the other is needing a bulb replacement the first player button needs repaired or replaced the plastic for the micro swich holder had warped a bit. all the other controls do work the other things i need too repair is the screen i am sure a cap kit could fix it but i want too replace it with a led hd tv and put a computer down in side of it too give it other games i can play as well though currently that project is on hold waiting till i get the converter board too use the tv's vga input for the jamma output. here are some pictures of that unit.
i have the banner though it got ripped in half from the prior owners trying too get in too the unit too try to fix it and not realizing that it had been reworked where the back cant com off. so i will be having too ither re print it or have a sign printer print a new one. i also salvaged backlights and other nessessary parts out of a lcd tv that uses led's for the back light so i can replace the floresent tube with led's and eliminate that noise and exes power usage from the unit. i have thought about using a rasberry pi for a retro pi game system and use the tv's hdmi in for it though not fully sure yet.
  • atillad
    atillad over 9 years ago +1
    woot i got my 3d printer now i need too get more filiment so i can print out the pipboy case and transfer the electronics. so far i am getting the prints too turn out amazing i have had a few failed prints…
  • atillad
    here is a diferent project its a fallout 4 cell phone charger using batterys scrapped from a laptop and a fusion core printed off on my 3d printer .image
  • atillad
    atillad over 8 years ago in reply to atillad
    a update on the fusion core battery i designed a case too fit the charger board i use here are the pictures. i also replaced the strap with some velcro and it looks and works amazing.
    on the last picture i am demonstrating that i made the cover too the screen able too be slid off. i added glow in the bark paint too the words and put some blue painters tape over the display so it will clear up the display emencely. a new set of 4 cells also added tons of battery life too it.
  • atillad
