Legacy Personal Blogs Raspberry Pi 3 - Boot up attempt
  • Author Author: tonyboubady
  • Date Created: 19 Jul 2016 7:46 AM Date Created
  • Views 715 views
  • raspberry-pi3
  • ras pi 3
  • rasp_pi
  • raspberrypi3
tonyboubady
tonyboubady
19 Jul 2016
I have managed to prepare my 4GB SD card with official SDFormatter for the NOOB...
It's working great... from this stage, I have concluded that the Rpi 3 board I have received is working properly. I have tested the mouse and on-board wifi, both are working great...
The problem I have right now is, not enough space in SD card, so i have to use 8GB SD. I am sure there will be a 8GB card lying around in my house. I don't own USB keyboard, what I am having is, keyboard with PS/2 connector. So, I have to put on a hold with the raspberry hands-on until I buy the USB keyboard.
Until then...
    e14 Contributor over 10 years ago +1
    If I were you, I would not get an 8GB MicroSD card; go for a larger one, say, 16-32GB. As time goes on, you will probably be adding more software packages and related data. This would give you room for…
    e14 Contributor over 10 years ago in reply to e14 Contributor +1
    I had tossed all my usb keyboards in the garbage needed one to get mine going went to a thrift store they had lots and I paid 2 dollars
    If I were you, I would not get an 8GB MicroSD card; go for a larger one, say, 16-32GB.  As time goes on, you will probably be adding more software packages and related data.  This would give you room for growth.
    Regarding the PS/2 keyboard, I've used a PS/2-USB adapter in the past for a keyboard.  It worked fine for me.  Maybe you could take your RPi3 and your PS/2 keyboard to a friendly supplier like Fry's (DFW area in Texas) or the equivalent for a test before purchasing if you find that an adapter would be less expensive.
  • tonyboubady
    tonyboubady over 10 years ago in reply to e14 Contributor
    Intersting...i have to look for second hand or even 3rd hand USB keyboard, if I can get anyone here...
  • tonyboubady
