Legacy Personal Blogs Reference Designs
  • Author Author: nickgray
  • Date Created: 21 Oct 2013 1:51 PM Date Created
  • Views 850 views
  • at:design_tips
  • at:applicationnote
  • electronics
  • reference_designs
Reference Designs
nickgray
nickgray
21 Oct 2013
I once worked for a company that provided circuit designs and even application notes based upon construction of a single copy of a circuit, generally at the request of a customer. This is fine if the usual disclamers are given. However, that company did not give any disclaimers at all and customers rightfully complained when they designed the circuit into their prototype systems and the circuit did not work properly. It was my job to help customers with these and other problems and most of the time it was a matter of tolerance of passive components. I fully understand that most manufacturers that provide reference circuits today are more careful to be sure that their circuits show their products in the best light, so are much more careful about what they publish, I still have the habit of going through the necessary worst case analysis of a circuit to be as sure as I can that it will do what I expect over all expected conditions. The burden, of course, is on me as I will be the one to "take the heat" if something goes wrong during prototype testing. Everything today has disclaimers and the user must beware.
It may be tempting to just take a reference design and incorporate it into your own system, but I suggest caution is in order, especially when you have no recourse if something goes wrong. Reference designs can certainly speed up the design process and are a valuable tool, but we still need to do our own sanity checks. Treat reference designs as a tool, not as a proven solution to your design task.
Comments, anyone?
Nick Gray
    DAB over 12 years ago
    Reusing circuits is just like reusing software.
    If you understand what it does and it meets your needs, then you can proceed with some confidence that you have saved some times.
    That said, you need to have good documentation and either experience with the circuit or its type and test data that verifies its capabilities.
    I have seen a lot of money wasted by people trying to fit an old product into a new design.  The tendancies of new engineers is to convince themselves that they can design and build a better circuit/software cheaper.  I have seldom seen this approach work.
