Legacy Personal Blogs Researching burning RPI onto an SD card
  • Date Created: 5 Sep 2013 2:29 AM Date Created
  • Views 656 views
e14 Contributor
e14 Contributor
5 Sep 2013
There's many ways to skin this cat. Previously I used the Raspberry PI installer to burn the image onto a 4Gb SD card. This time around I see that there is a distro especially for hardware hacking.
I found my way from the Adafruit learrning's lesson one
http://learn.adafruit.com/adafruit-raspberry-pi-lesson-1-preparing-and-sd-card-for-your-raspberry-pi/overview
From there I ran into the occidentalis distro as an alternative to wheezy
http://learn.adafruit.com/adafruit-raspberry-pi-educational-linux-distro/
Which led me to the RPI easy SD card setup
http://elinux.org/RPi_Easy_SD_Card_Setup
which recommends using the SD associations SD formatting tool
https://www.sdcard.org/downloads/formatter_4/
which I installed on our Mac
but this is confusing because the formatting tools referenced in the NOOB method. The command line tool method does not mention the formatting tool.
    I found some step by step instructions involvng formatting the card to FAT32 prior to using dd
    http://forums.adafruit.com/viewtopic.php?f=8&t=41018
