Legacy Personal Blogs Send data using MQTT from Raspberry Pi with JAVA
  • Author Author: oksbwn
  • Date Created: 12 Jun 2017 2:48 PM Date Created
  • Views 1458 views
  • tutorial
  • mqtt
  • eclipse paho
  • mqtt java
  • getting started with mqtt
  • raspberry pi
  • getting started
  • raspberry pi dht11 tutorial
oksbwn
oksbwn
12 Jun 2017
This is the third video in the series "IOT with Raspberry Pi" and that's using JAVA. The series comprises of Sensor interfacing using pi4J, REST API usage with JAVA, MQTT usage with JAVA and finally adding all to the same project and running over Raspberry Pi. last two videos shows how to interface DS18B20 1 wire temperature sensor with Raspberry Pi and send data to Thingspeak by using REST API with JAVA. If you have not checked those you can do that with the links down below. This video is the 3rd in the series and is about how to publish or send sensor data using MQTT API to cloud. And in this, we are using ThingSpeak as cloud service to publish data.Publishing Data using MQTT is done using Eclipse PAHO lightweight library. MQTT is a simple lightweight publish/subscribe protocol that can be used over TCP instead of going for HTTP as MQTT is power friendly and bandwidth friendly as compared to HTTP. So it fits perfect for IOT applications. If you are interested in more about it, you can check some docs linked below.
Links :
Github Repo:http://bit.ly/2sxXweP
Code:http://bit.ly/2rPuRo4
Download Eclipse PAHO Library(With Dependencies):http://bit.ly/2srKW4B
Eclipse PAHO Website: http://bit.ly/2srfxPE
First Part (DS18B20 Interfacing with Raspberry Pi using JAVA): http://bit.ly/2rxd1WK
Second Part (Upload data to Thingspeak using REST API ): http://bit.ly/2rZWLMu
More on MQTT
Wikipedia:http://bit.ly/2shULlY
Official Website: http://bit.ly/2shMMp8
Java Application on Pi Playlist: http://bit.ly/2eB1O2K
You can Subscribe on YouTube by clicking this link to show your support and be updated with the latest video on the channel like this.
Subscribe: http://bit.ly/2d8pHge
