Legacy Personal Blogs Si4703 code getting better
  • Author Author: packetgeek
  • Date Created: 28 Feb 2015 5:55 PM Date Created
  • Views 679 views
  • i2c
  • radio
  • rpi
  • si4703
packetgeek
packetgeek
28 Feb 2015
Finally had time to work on the code again.  Figured out last night that the registers are big endian, while the code that usually processes the data is little endian (for some unknown reason).  To tell the truth, this chip set could probably controlled by reading a single 256-bit value and sending back a single 96-bit value.  Current code breaks these up into 16-bit registers to align with how the registers are described in the chip's spec sheet.  Use of single read and rewrite buffers might make the code a bit unwieldy.
In any case, I now have working wiringPi code for initializing the chip, tuning to a specific station, and setting the volume, as well as some tools to assist with coding (e.g., print_registers).  Still to do: develop more controls (e.g., print_RDS) and remove the dependency on the wiringPi library.  More later.
- Tim
  • packetgeek
    packetgeek over 11 years ago
    Experimented with the code for a bit this evening.  Now have a working init function for the Si4703, that doesn't require installation of the wiringPi library!  Will post the code here in the next week or so.
    Still need to improve the seek functions as they are oversensitive (i.e., they stop at noisy frequencies instead of only on actual radio stations).  Also, I still have much more research to perform, for the RDS function.
    If anyone cares, I've been posting my in-progress code over at: https://github.com/packetgeek
    - Tim
