Legacy Personal Blogs Solar Power Use
  • Author Author: knight_rider1977
  • Date Created: 25 Feb 2015 9:16 PM Date Created
  • Views 754 views
Solar Power Use
knight_rider1977
knight_rider1977
25 Feb 2015
I was thinking about using solar power to either charge batteries or power a small Radio Controlled car.  Would this be feasible or would the amount of solar cells needed be so large it would look more like a giant moving solar panel than a car.
  • clem57
    clem57 over 11 years ago +1
    It would be feasible if: Good sunlight where you are located Do not expect a fast charge. These work like a trickle charger depending on voltage needed. Powering a car would not be expected since motors…
  • clem57
    • Good sunlight where you are located
    • Do not expect a fast charge. These work like a trickle charger depending on voltage needed.
    • Powering a car would not be expected since motors would draw too much current typically.
    • Expect to need a circuit board to help regulated the current/voltage.
    Cheers,
    Clem
