Legacy Personal Blogs Throwing in the towel | HLH
  • Author Author: baldengineer
  • Date Created: 1 Apr 2018 6:01 PM Date Created
  • Views 1822 views
  • Likes 8 likes
  • Comments 14 comments
baldengineer
baldengineer
1 Apr 2018
Last night I had strong hopes I would be recording my first gameplay video before going to bed. However, that did not happen.
As of this writing, the screen is working. Most of the buttons work. Except, when controlled by the Pi. When the Teensy and Pi are connected, it appears to create a short circuit. The troubling aspect is that when the Teensy is connected to my computer, no issue there. At least I have a Wii-U style controller for OpenEmu now. image
So the problem is with the Teensy, the Pi, or my wiring. I suspected the wiring first but cannot find an obvious fault. After that, I programmed a new Teensy but did not connect any wires. I get the same behavior by just connecting to the Pi’s USB, which is why I suspect the Pi. Perhaps I damaged the USB controller when de-populating the USB ports. When the kernel driver enables the USB controller, I see the 5 volt rail dip, the under voltage icon comes on (when the screen is connected), and sometimes the Pi reboots. If it makes it to EmulationStation, I can SSH in and see dmesg complaining about overcurrent.
Regardless, I have yet to start editing my video. Even if I could find and repair the fault in the next hour, I would not have time to finish a suitable video by the morning deadline.
I have never captured so much footage while working on a project. Right now my capture folder is sitting at 128 GB (interesting number) with more from yesterday’s SD Cards waiting for transfer.
So that what I captured does not go to waste, my goal is to re-work the project and produce an AddOhms video out of it.
Best of luck to everyone else. I look forward to watching your build videos and seeing who becomes the next Ben Heck.
  • mayermakes
    mayermakes over 8 years ago +4
    Sorry to hear of your bad luck with the project. I was very eager to see your video. I'm sure it will make a great addOhms episode. Btw I see your 128GB of files and I raise my 256GB of Video files for…
    genebren over 8 years ago +3
    Well, you gave it a good shot. There is a lot to say about having tried and failed. It is a lot better than not having tried at all. There is a lot of evidence of good work in the pictures that you posted…
  • baldengineer
    baldengineer over 8 years ago in reply to jomoenginer +3
    Thank you for the encouraging words Jon. The video is due in the morning. Since I did not achieve the primary requirement, a working build, I cannot participate. As I said above, I plan to recover the…
  • 14rhb
    14rhb over 8 years ago
    James,
    Sorry to hear about your issues getting your project finished. Like others have said - sometimes this sort of thing happens, timescales slip, the unexpected happens. I'm absolutely sure the judges have enough background experience to have been there themselves in the past and will judge  your project from what it was aiming to do and what challenges you overcame. Think about school exams - we were always told to show the working out as sometimes you got high marks even though there was one mistake along the way that resulted in the incorrect answer.
    Look forward to seeing it finished still image
    Rod
  • 14rhb
    James,
    Rod
