Legacy Personal Blogs time programming
  • Author Author: kurthjwerner
  • Date Created: 15 Feb 2017 4:40 PM Date Created
  • Views 556 views
time programming
kurthjwerner
kurthjwerner
15 Feb 2017
I need to know how to program the intern timer, or does a timer not excist in the Ras Pi?
I must  learn to program the  GPIO´s together with the intern timer:
Here is my task: time based programming of the GPIO4
It is a starting maskin for sailboat racing:
To start the program, i have an extern switch, that even starts the first signal (hooter)
After 60 seconds, the program must set the GPIO4 high again (for appr. 30 milliseconds).
Then, after 120 seconds, the program must set GPIO4  high again ( ”      ” ”  ”       )   to give a third signal.
Finally, after 60 seconds, the program must set the GPIO4 high again ( ”  ”   ”    ” ) for the final start
signal hooter for all boats.
I´m very exited, programming this little wonder maskin, and i would be very thankfull to you guy´s, if
you would be able to help me now!
(i´ve three other projects, when i finished this one!!)
    shabaz over 9 years ago +1
    Hi Kurt, The Pi runs Linux which provides the timing functions to applications. These functions are identical regardless the underlying hardware. This is important to know, because it then helps when searching…
    beacon_dave over 9 years ago +1
    This example may be of interest clock_gettime() For Acurate Timing – Raspberry Pi Projects
