Legacy Personal Blogs Tracking the Total Solar Eclipse on 8-21-2017
  • Author Author: ninjatrent
  • Date Created: 15 Jul 2017 8:39 PM Date Created
  • Views 2304 views
  • Likes 8 likes
  • Comments 11 comments
  • photograph
  • raspberry pi iot
  • astrophotography
  • space_x
  • astrophysics
  • raspberry_pi_accessories,raspberry
  • amateur astronomer
  • embedded linux
  • raspberry pi 3 projects
  • raspberrypicamera
  • high resolution photographs
  • pi camera v2
  • meteorological
  • camera sensor
  • imaging
  • pi camera project
  • raspbian_release
  • astronaut
  • microsoft windows
  • raspberry pi video camera
  • linux mint
  • solar_eclipse
  • photography
  • camera board
  • nasa
  • linux software dev
  • space
  • weather
  • ubuntu linux
  • android dev
  • raspberry pi camera board
  • win10
  • ios
  • rpi_3
  • pi camera
  • video camera
  • astronomy
  • android developer
  • 8mp raspberry pi camera v2
  • win7
  • linux_foundation
  • raspberry_pi_3
  • international space station
  • linux
  • digital video
ninjatrent
ninjatrent
15 Jul 2017
      The solar corona at the March 2015 total eclipse over Svalbard. Photo: Judy Anderson. Processing: Alson Wong.
Warning! Even if 99% of the sun is covered by the moon, the remaining 1% crescent is dangerous to view with the naked eye and can cause serious eye damage or blindness. For information on safely veiwing and photographing an eclipse, please refer to the following links.
     https://eclipse.gsfc.nasa.gov/SEhelp/eclipsePhoto.html
     How to Photograph a Solar Eclipse from Nikon
     How to Photograph Total Solar Eclipse 2017 - How to Take Pictures of the Sun
     https://eclipse2017.nasa.gov/sites/default/files/Photographing%20the%20Eclipse%20with%20your%20Smartphone.pdf
How can I photograph a total solar eclipse?
You will need to purchase a solar filter that will reduce the brightness of the sun so that the light intensity does not  destroy your camera. If you ONLY take a photo at the moment of totality, you will not need this filter, and will be rewarded by being able to photograph the faint corona, which will not be visible if you have the filter in place. Most digital cameras with telephoto lenses of 100 mm or larger will show a disk for the eclipse that will show some detail. As a trial, photograph the full moon at night. It will be the same diameter as the total eclipse, so you can practice on the moon first to get the right telephoto lens combination. There are many places on the internet where you can get detailed information such as Mr. Eclipse http://www.mreclipse.com/SEphoto/SEphoto.html
The following links contain information with regards to the Solar Eclipse of 2017. There are many resources such as high resolution maps, Tracking Software Apps for Smartphones, 2D/3D Printable Pinhole Projectors, veiwing safety tips and much more available from  https://www.nasa.gov/ .
https://eclipse.gsfc.nasa.gov/SEgoogle/SEgoogle2001/SE2017Aug21Tgoogle.html
https://eclipse2017.nasa.gov/eclipse-maps
https://eclipse2017.nasa.gov/apps
https://eclipse2017.nasa.gov/downloadables
https://eclipse2017.nasa.gov/eclipse-live-stream
https://eclipse2017.nasa.gov/event-locations
https://eclipse2017.nasa.gov/eclipse-misconceptions
https://eclipse2017.nasa.gov/2d3d-printable-pinhole-projectors
https://eclipse2017.nasa.gov/eclipse-art-projects
https://eclipse2017.nasa.gov/eclipse-viewing
https://eclipse2017.nasa.gov/noaa%E2%80%99s-resources
https://eyes.jpl.nasa.gov/eyes-on-eclipse-web-detail.html
https://eclipse2017.nasa.gov/sites/default/files/interactive_map/index.html
https://svs.gsfc.nasa.gov/4518#
My Photos of the 2017 Solar Eclipse
These images were photographed with binoculars, solar filter film removed from disposable solar eclipse viewing glasses, and an android smartphone.
I originally constructed an adapter with the solar filter for the Raspberry Pi Camera but it failed a few hours beforehand. I did use a Pi 3 with display to watch the live stream provided by NASA.  At one point the ISS passed in front of the Sun and was visible with binoculars for a brief moment. I was lucky enough to witness this but unfortunately was unable to capture an image of this rare occurrence. I apologize for the quality of the images, my equipment was improvised.
This was one of the best of many images. Afterwards I lost the proper alignment between the binoculars and camera lense.
Thanks for viewing this post.
  • Dudley
    Dudley over 9 years ago in reply to ninjatrent +6
    I live in the UK. And I'm going! In some ways, living in a different country makes it easier, because I could choose anywhere in the country to go, and it's all equal. So I looked at the path and decided…
    mcb1 over 9 years ago in reply to Dudley +4
    I live in the UK. And I'm going! Why? from what I saw on my visit you guys are used to not seeing the sun Hopefully you'll take DAB's advise and head up into the hills to avoid the clouds. Mark
    DAB over 9 years ago +2
    Nice post. I used to do a lot of solar observing and can recommend the mylar solar filters as being both effective and still provide good visual resolution. Whatever you use, remember to wear sunscreen…
    Nice post.
    Whatever you use, remember to wear sunscreen, plus I suggest setting up a sun blind to block the direct sunlight and just have a viewing port to stick the telescope or cameral lens out.
    Also monitor your gear for heating issues.  Remember, you are out in full sun.
    Be safe and enjoy the show.
    Nice post.
    jw0752 over 9 years ago in reply to DAB
    Hi DAB,
    It looks like you are only a hop skip and a jump from the best spot to view. Hopefully the weather will cooperate.
    DAB over 9 years ago in reply to jw0752
    I have limited expectations here in Ohio.
    I mean it will be August, high humidity, pop up thunderstorms and the usual fluffy clouds.
    If I was more mobile I would go to my ranch in Colorado.  7500 feet, 300 days of sun/year, good flat viewing area, but that is just too much of a road trip.
    If it is clear, I might set up one of my telescopes or mount one of my larger camera lenses on a webcam with the solar filter.
    We will see how I feel and the prospects for clear viewing projects clarify.
  • ninjatrent
    ninjatrent over 9 years ago in reply to DAB
    Unfortunately I live on the East Coast. I will try to observe and photograph what is visible from here. It would be interesting to capture the eclipse on video and record the effects of the eclipse on temp, humidity, and barometric pressure at the point of Greatest Eclipse. I live near the Atlantic ocean. It will be interesting to see how it affects the normal tide forcast and weather conditions.
  • Dudley
    In some ways, living in a different country makes it easier, because I could choose anywhere in the country to go, and it's all equal. So I looked at the path and decided where it would be nice to go on holiday for two weeks and catch an eclipse while there. It'll be my third total, and I am super excited!
    • Vote Up +6 Vote Down
    Jan Cumps over 9 years ago in reply to Dudley
    Nice, Dudley.
    During the partial eclipse over Europe, March 20 2015, I took this series of photos (cheapest camera I could find, freehand, but still nice).
    Each little square is a different photo.
