Legacy Personal Blogs Tractor simulator (cabin tractor interface with Farming Simulator 17): Part 3 - the software, 1/ Arduinos
  • Author Author: dhal
  • Date Created: 17 Dec 2017 11:12 AM Date Created
  • Views 1215 views
  • farming simulator
  • arduino due
  • arduino uno v3
dhal
dhal
17 Dec 2017
1/ Arduino DUE
1.1/ Keyboard : (attached to "FS Hat" PC)
Arduino DUE has to behave as a keyboard, so I will use the <keyboard.h> lib. But all the keys are not included in this lib, so an extension is needed to add extra keys:
keyboard_ext.h  ______________________________________________________________
  Keyboard_ext.h
  keyboard extension adapted from
  https://github.com/rampadc/arduino-thinkpadkb-usb/blob/master/MicroThinkPadAdapter/MicroThinkPadAdapter.ino
//  extended Keyboard
#define KEY_PAUSE           0xD0
#define KEY_PRINT_SCREEN    0xCE
#define KEY_SCROLL_LOCK     0xCF
#define KEYPAD_NUMLOCK      0xDB
#define KEYPAD_0            0xEA
#define KEYPAD_1            0xE1
#define KEYPAD_2            0xE2
#define KEYPAD_3            0xE3
#define KEYPAD_4            0xE4
#define KEYPAD_5            0xE5
#define KEYPAD_6            0xE6
#define KEYPAD_7            0xE7
#define KEYPAD_8            0xE8
#define KEYPAD_9            0xE9
#define KEYPAD_SLASH        0xDC
#define KEYPAD_ASTERISK     0xDD
#define KEYPAD_MINUS        0xDE
#define KEYPAD_PLUS         0xDF
#define KEYPAD_ENTER        0xE0
#define KEYPAD_PERIOD       0xEB
__________________________________________________________________________
1.2/ Digital inputs: (44 inputs)
As explained in the previous part, I exploit interrupts for each of them,  attachInterrupt(pin#, _function, RISING);
Some of the inputs are not yet used, but foreseen for "future extension"...
In the interrupt  _function, I just set a flag (flag |= specialBit) to be read in the main loop. Once tested in the main loop (if flag & specialBit), a special action/function is processed.
I use 3 kind of flags; either a key has to be written to the keyboad (kbCharW), or a char/chain has to be sent to serial link (sndStrFlag), or a key has to be first pressed or released (kbCharPR).
To avoid using many loops to test the bits of the 3 flags (3 x 3 loops), I'd gathered them in common loops (as long as the number of bits to test are equal)
1.3/ Analog inputs: (Steering wheel, accel pedal, accel hand, brakes pedal)
A0 to A3 values are scaled with my own map function (see why below in analog outputs part). I had preferred tuning my inputs in the range 0.1V to 3.2V (see hardware) to avoid negative/overvoltage on the arduino.
curVal = myMap(analogRead(analogInputPin), 124, 3971);
In the 12 bits resolution range [0, 4095] for [0V, 3.3V], [124, 3971] corresponds to [0.1V, 3.2V].
However, even if the potentiometers powered with max +/- 15 V (see hardware), some analog inputs max value (accelerations) were around 2.4 V. That's why I had to adjust the "3971" values for them.
The scaled values are sent directly to the analog outputs.
1.4/ Analog outputs: (Steering wheel, accel forward, accel backward, brakes)
As already mentioned, I had preferred using PWM as I needed 4 analog outputs in the full range [0, 3.3V] voltage.
However, this feature needs some code changes in the arduino lib, to set 12 bits resolution and high PWM frequency (even if I filter @80Hz, to be far from Shannon critical frequencies).
So in C:\Users\{user}\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\variants\arduino_due_x\variant.h
values to set (in bold):
* PWM
#define PWM_INTERFACE    PWM
#define PWM_INTERFACE_ID ID_PWM
#define PWM_FREQUENCY 6000
#define PWM_MAX_DUTY_CYCLE 4095
#define PWM_MIN_DUTY_CYCLE 0
#define PWM_RESOLUTION 12
During the testings, I spent a lot of time to find an error that occured on my analog outputs. The system crashed each time I was at an extremum value of my potentiometers.
I had to use the serial monitor to find the error message duty <= pPwm->PWM_CH_NUM[ul_channel].PWM_CPRD" failed: file "../source/pwmc.c", line 272, function: PWMC_SetDutyCycle
I finally found on internet (thanks google), that it came from the arduino map function (it sometimes returns negative values, which is incompatible with PWM function)! See here.
So I wrote my own map function:
unsigned int myMap(float val, float minin, float maxin) {
  return min((unsigned int) max(0., (val - minin) * (float)maxV12 / (maxin - minin)), maxV12);
1.5/ Serial link:
Set to 115200 bps, it receives and sends data.To gain in reactivity I use just a few bytes (some characters).
A first loop retreives all the incoming characters (while (Serial.available())) while in the other scanning loops the bits are tested to know which chain to send to the serial link.
All the data sent to the serial link will be forwarded to TCP/IP with "PS_Hat" PC. So, to optimise the TCP/IP bandwidth (even if it's in a 1Gb/s local net, yes limited to 100Mb/s due the the raspberry pis), I set a flag to limit the sendings.
okToSend = ((unsigned long)(t1 - t0) >= dt); // cast to avoid to manage roll-over
BTW,  here how to handle millis roll over ...
inputsDUE.c  _______________________________________________________________
  Program Arduino DUE
  Manage tractor inputs for Farming Simulator
  Damien Hallez, nov 2017
#include <Keyboard.h>
#include "Keyboard_ext.h"
//                  DECLARATIONS
// ----- ex IA1
// const short pin_JSC_Left   =  52 ;    // ---- Joystick Cabin Left
// const short pin_JSC_Right  =  68 ;    // ---- Joystick Cabin Right
// const short pin_JSC_Frwd   =  50 ;    // ---- Joystick Cabin Forward
// const short pin_JSC_Bkwd   =  69 ;    // ---- Joystick Cabin Backward
// const short pin_FSp_PB     =  64 ;    // ---- Fix speed button
const short pin_Neutral    =  47 ;    // ---- Neutral for/back ward
const short pin_Horn       =  42 ;    // ---- Horn      => '0_'
const short pin_Beacon     =  16 ;    // ---- Beacon    => 'HOME' + beacon= to Rpi_Disp & Rpi_Out
// ----- ex IB1
// const short pin_JSC_H4     =  65 ;    // ---- Joystick Cabin H4
// const short pin_JSC_H3     =  62 ;    // ---- Joystick Cabin H3
// const short pin_JSC_Pl     =  66 ;    // ---- Joystick Cabin +
// const short pin_JSC_Ms     =  63 ;    // ---- Joystick Cabin -
// const short pin_JSC_PB     =  64 ;    // ---- Joystick Cabin Push Button
const short pin_SeqLev_PB  = 48 ;    // ---- Sequential lever Push Button   => 'O'
// const short pin_SeqLev_SP  =  53 ;    // ---- Sequential lever speed +
// const short pin_SeqLev_SM  =  46 ;    // ---- Sequential lever speed -
// ----- ex IA2
const short pin_Li_FrDown  = 14 ;    // ---- Lights Front Low => 'F/3F' + LghtFrDown/LghtReDown to Rpi_Disp & Rpi_Out
const short pin_Li_FrUp    = 17 ;    // ---- Lights Front Up  => 'KP5'  + LghtFrUp to Rpi_Disp & Rpi_Out
const short pin_Li_ReDown  = 15 ;    // ---- Lights Rear Low  => 'F/3F' + LghtFrDown/LghtReDown to Rpi_Disp & Rpi_Out
const short pin_Li_ReUp    = 18 ;    // ---- Lights Rear Up   => 'KP6'  + LghtReUp to Rpi_Disp & Rpi_Out
// const short pin_PB1       =  19 ;    // ---- Push Button 1
// const short pin_PB2       =  20 ;    // ---- Push Button 2
// const short pin_PB3       =  26 ;    // ---- Push Button 3
// const short pin_PB5       =  28 ;    // ---- Push Button 5
// ----- ex IB2
// const short pin_Frwd_Up   =  53 ;    // ---- sequential forward speed Up
// const short pin_Frwd_Down =  46 ;    // ---- sequential forward speed Down
// const short pin_Bkwd_Up   =  53 ;    // ---- sequential backward speed Up
// const short pin_Bkwd_Down =  46 ;    // ---- sequential backward speed Down
const short pin_Warning      = 37 ;    // ---- Warning button   => 'KP2' + Warning=to Rpi_Disp & Rpi_Out
const short pin_BP4_N        = 21 ;    // ----- N on lights board => 'B'
const short pin_RightBlinker = 49 ;    // ----- Right Blinker   => 'KP3'
const short pin_LeftBlinker  = 44 ;    // ----- Left Blinker      => 'KP1'
// ----- ex IA3
// const short pin_SV1       =  36 ;    // ---- SV1
const short pin_A         = 38 ;    // ---- A
const short pin_UTurn     = 40 ;    // ---- U-turn        => 'G'
const short pin_LG_Up     = 29 ;    // ---- Lift Gear Up    => 'V'
const short pin_LG_Down   = 33 ;    // ---- Lift Gear Down    => 'V'
const short pin_PosN_1    = 31 ;    // ---- Position N      => 'B'
// ----- ex IB3
const short pin_HydrauLeftLeverFrwd  = 41 ; //        => 'X'
const short pin_HydrauLeftLeverBkwd  = 51 ; //        => 'X'
const short pin_HydrauRightLeverFrwd = 43 ; //        => 'I'
const short pin_HydrauRightLeverBkwd = 39 ; //        => 'I'
const short pin_GreenButtonLeftJS    = 27 ; //        => 'C'
const short pin_RedButtonLeftJS      = 30 ; //        => 'BS'
const short pin_GreenButtonRightJS   = 22 ; //        => 'PgUp'
const short pin_RedButtonRightJS     = 24 ; //        => 'PgDwn'
// ----- ex on Rpi
const short pin_FrwdInfo       = 25 ; //
const short pin_BkwdInfo       = 32 ; //
const short pin_FrwdBkwdToggle = 67 ; //
// ----- spares
// const short pinSpare1 = 34
// const short pinSpare2 = 23
// const short pinSpare3 = 45
// const short pinSpare4 = 35
// ----- Toggle buttons:
volatile boolean hornOn     = false;
volatile boolean beaconOn   = false;
volatile boolean warningOn   = false;
volatile boolean Li_fr_down = false;
volatile boolean Li_re_down = false;
volatile boolean Li_fr_up   = false;
volatile boolean Li_re_up   = false;
volatile boolean Lg_up      = false;
volatile boolean leftBlinkerOn  = false;
volatile boolean rightBlinkerOn = false;
volatile boolean zoomInOn = false;
volatile boolean zoomOutOn = false;
volatile boolean cameraOn = false;
volatile short Direction = 0;
// ----- ADC
const short in_steeringW = A0;
const short in_acc_pedal = A1;
const short in_acc_hand  = A2;
const short in_brakes    = A3;
int curStwVal    = 0;
int prevStwVal   = 0;
int curStwAngle  = 0;
int prevStwAngle = 0;
int curAccel     = 0;
int accelPedal   = 0;
int accelHand    = 0;
int prevAccel    = 0;
int curAccel2    = 0;
int prevAccel2   = 0;
int curBrksVal   = 0;
int prevBrksVal   = 0;
boolean brakesOn = false;
const int maxV12  = 4095;
// ----- DAC - real PWM set @6kHz
const short out_steeringW = 7;
const short out_forward   = 6;
const short out_bckward   = 5;
const short out_brakes    = 4;
// ----- Serial -> pins 18 & 19
char rcvString[10] ;
int nrcv = 0;
char sndString[15] ;
const short nStrAcc0         =  0;
const short nStrReRedLght    =  1;
const short nStrBeacon       =  2;
const short nStrLghtFrDown   =  3;
const short nStrLghtReDown   =  4;
const short nStrRightBlinker =  5;
const short nStrLeftBlinker  =  6;
const short nStrWarning      =  7;
const short nStrLghtFrUp     =  8;
const short nStrLghtReUp     =  9;
const short nStrToSend       = 10;
char strToSend[nStrToSend][15];
unsigned int sndStrFlag = 0;
const short bitAcc0         = 1 << nStrAcc0;
const short bitReRedLght    = 1 << nStrReRedLght;
const short bitBeacon       = 1 << nStrBeacon;
const short bitLghtFrDown   = 1 << nStrLghtFrDown;
const short bitLghtReDown   = 1 << nStrLghtReDown;
const short bitRightBlinker = 1 << nStrRightBlinker;
const short bitLeftBlinker  = 1 << nStrLeftBlinker;
const short bitWarning      = 1 << nStrWarning;
const short bitLghtFrUp     = 1 << nStrLghtFrUp;
const short bitLghtReUp     = 1 << nStrLghtReUp;
volatile boolean sendOk = false;
boolean oldSendOk = false;
volatile boolean intOk = false;
// ----- keyboard chars to write
char kbWlist[] = {  KEY_BACKSPACE, KEY_HOME, 'A', 'B', 'C', 'F', 'G', 'I', 'V', 'X', 'O', \
                    225, 226, 227, 229, 230, 0
volatile int kbCharW = 0;
const int bitKeyBS   = 1 <<  0;
const int bitKeyHome = 1 <<  1;
const int bitKeyA    = 1 <<  2;
const int bitKeyB    = 1 <<  3;
const int bitKeyC    = 1 <<  4;
const int bitKeyF    = 1 <<  5;
const int bitKeyG    = 1 <<  6;
const int bitKeyI    = 1 <<  7;
const int bitKeyV    = 1 <<  8;
const int bitKeyX    = 1 <<  9;
const int bitKeyO    = 1 << 10;
const int bitKP1     = 1 << 11;
const int bitKP2     = 1 << 12;
const int bitKP3     = 1 << 13;
const int bitKP5     = 1 << 14;
const int bitKP6     = 1 << 15;
const short nCharWList    = 16;
// ----- keyboard chars to press/release
char kbPRlist[] = { KEY_PAGE_UP, KEY_PAGE_DOWN, '0', 0  };
volatile short kbCharPR = 0;
const short bitKeyPgUpPress    = 1 << 0;
const short bitKeyPgUpRelease  = 1 << 1;
const short bitKeyPgDwnPress   = 1 << 2;
const short bitKeyPgDwnRelease = 1 << 3;
const short bitKey0Press       = 1 << 4;
const short bitKey0Release     = 1 << 5;
const short nCharPRList             = 3; /// divided by 2 (set, released)
// ----- keyboard special send
volatile boolean kbCharSeqFFF   = false;
volatile boolean kbCharSeqFFF5  = false;
volatile boolean kbCharSeqFFF6  = false;
volatile boolean kbCharSeq5F5   = false;
volatile boolean kbCharSeq6F6   = false;
volatile boolean kbCharSeq56F56 = false;
// index
short il;
unsigned int jl, kl, ll;
char *addStr;
// manage the time to send data (avoid overflow)
unsigned long t0, t1;
int dt = 100; // ms to send data to serial
boolean okToSend = false;
// verify if not blocked ...
unsigned long tHorn0;
int dtHorn = 5000; // ms max to be maintained
boolean forceReleaseButtons = false;
int releaseCnt = 0;
//                    SETUP
void setup() {
  // -------------------------------------------- Serial (makes a reset !!)
  Serial.begin(115200);
  // -------------------------------------------- Strings to be sent
  // firt letter : 0 = reset com, 1 = send to Disp,  2 = send both to Disp and Outputs
  // then 3 letters, then value
  strcpy(strToSend[nStrAcc0]        , "1ACC0.00" ); // accel
  strcpy(strToSend[nStrReRedLght]   , "2RRL0" ); // ReRedLght
  strcpy(strToSend[nStrBeacon]      , "2BCN0" ); // Beacon
  strcpy(strToSend[nStrLghtFrDown]  , "2LFD0" ); // LghtFrDown
  strcpy(strToSend[nStrLghtReDown]  , "2LRD0" ); // LghtReDown
  strcpy(strToSend[nStrRightBlinker], "2RBL0" ); // RightBlinker
  strcpy(strToSend[nStrLeftBlinker] , "2LBL0" ); // LeftBlinker
  strcpy(strToSend[nStrWarning]     , "2WRN0" ); // Warning
  strcpy(strToSend[nStrLghtFrUp]    , "2LFU0" ); // LghtFrUp
  strcpy(strToSend[nStrLghtReUp]    , "2LRU0" ); // LghtReUp
  // -------------------------------------------- Buttons
  // ----- position N     -> 'B'
  attachInterrupt(pin_PosN_1, _posN, RISING);
  attachInterrupt(pin_BP4_N,  _posN, RISING);
  // ----- Horn         -> '0'
  attachInterrupt(pin_Horn, _hornOn, RISING);
  // ----- Beacon       -> 'HOME'
  attachInterrupt(pin_Beacon, _beacon, RISING);
  // ----- action 1       -> 'O'
  attachInterrupt(pin_SeqLev_PB, _act_o, RISING);
  // ----- lights Front low     -> KP5
  attachInterrupt(pin_Li_FrDown, _lght_fr_low, RISING);
  // ----- lights Rear low     -> KP6
  attachInterrupt(pin_Li_ReDown, _lght_re_low, RISING);
  // ----- Right Blinker    -> KP3
  attachInterrupt(pin_RightBlinker, _rightBlinkOn, RISING);
  // ----- Left Blinker   -> KP1
  attachInterrupt(pin_LeftBlinker, _leftBlinkOn, RISING);
  // ----- Warning      -> KP0
  attachInterrupt(pin_Warning, _WarningOn, RISING);
  // ----- light FR UP    -> KP5
  attachInterrupt(pin_Li_FrUp, _lght_fr_up, RISING);
  // ----- light RE UP    -> KP6
  attachInterrupt(pin_Li_ReUp, _lght_re_up, RISING);
  // ----- U-Turn       -> 'G'
  attachInterrupt(pin_UTurn, _u_turn, RISING);
  // ----- LG_Up / LG_Down  -> 'V'
  attachInterrupt(pin_LG_Up,   _lg_up, RISING);
  attachInterrupt(pin_LG_Down, _lg_down, RISING);
  // ----- HyLeftFwd      -> 'X'
  attachInterrupt(pin_HydrauLeftLeverFrwd, _hydLeftFwd, RISING);
  attachInterrupt(pin_HydrauLeftLeverBkwd, _hydLeftBwd, RISING);
  // ----- HyRightFwd     -> 'I'
  attachInterrupt(pin_HydrauRightLeverFrwd, _hydRightFwd, RISING);
  attachInterrupt(pin_HydrauRightLeverBkwd, _hydRightBwd, RISING);
  // ----- GreenButtonLeftJS  -> 'C'
  attachInterrupt(pin_GreenButtonLeftJS, _setCamera, RISING);
  // ----- RedButtonLeftJS  -> 'BACKSPACE'
  attachInterrupt(pin_RedButtonLeftJS, _hideshowpan, RISING);
  // ----- ZoomOut      -> 'PgUp'
  attachInterrupt(pin_GreenButtonRightJS, _zoomOutOn, RISING);
  // ----- ZoomIN       -> 'PgPgDwn'
  attachInterrupt(pin_RedButtonRightJS, _zoomInOn, RISING);
  // ----- Attach       -> 'A'
  attachInterrupt(pin_A, _attach, RISING);
  // ----- Directions
  attachInterrupt(pin_FrwdInfo,      _forwardOn,  RISING);
  attachInterrupt(pin_BkwdInfo,      _backwardOn, RISING);
  attachInterrupt(pin_FrwdBkwdToggle, _toggleDir, RISING);
  // -------------------------------------------- Analog inputs
  analogReadResolution(12);
  // -------------------------------------------- Analog outputs
  analogWriteResolution(12);
  analogWrite(out_forward, 0);
  analogWrite(out_bckward, 0);
  // ----- reset buffer
  strcpy(rcvString, "");
  // ----- wait for serial PC
  while (!Serial);
  // -------------------------------------------- keyboard
  Keyboard.begin();
  t0 = millis();
  tHorn0 = t0;
//                    SUBROUTINES
// ----- send strings to the serial link
void sendSerial(char *txt) {
  if ((sendOk) && (Serial.availableForWrite() > strlen(txt))) {
    Serial.println(txt); // println add '\r\n' to the string
// ----- azerty to qwerty
char az2qw(char inch) {
  char outch = inch;
  switch (inch) {
    case 'A': outch = 'Q'; break;
    case 'Z': outch = 'W'; break;
    case 'Q': outch = 'A'; break;
    case 'W': outch = 'Z'; break;
    case 'M': outch = ':'; break;
    case 'a': outch = 'q'; break;
    case 'z': outch = 'w'; break;
    case 'q': outch = 'a'; break;
    case 'w': outch = 'z'; break;
    case 'm': outch = ';'; break;
      break;
  return outch;
// ----- set Direction
void setDirection(short val) {
  Direction = val;
  strToSend[nStrReRedLght][4] = char(48 + (val == -1 ? 1 : 0));
  // redLights and reset speed
  sndStrFlag  |= (bitReRedLght | bitAcc0) ;
//  'ESC', dt, 'UP', dt, 'ENTER'
void quitFS17() {
  delay(100);
  Keyboard.write(KEY_ESC);
  delay(200);
  Keyboard.write(KEY_UP_ARROW);
  delay(100);
  Keyboard.write(KEY_RETURN);
  delay(100);
// 'ESC', dt, 'RIGHT', dt, 'ENTER', dt, 'ENTER', dt
void quitGame() {
  // mask the interruptions
  intOk = false;
  delay(200);
  Keyboard.write(KEY_RIGHT_ARROW);
  delay(100);
  delay(300);
  delay(100);
//  n -= 1 [ 'RIGHT', dt ]n , dt, 'ENTER', dt, 'ENTER'
void loadGame(short n) {
  n -= 1;
  if (n > 20) n = 20;
  for (short ii = 0; ii < n; ii++) {
    delay(100);
  delay(150);
  delay(100);
  sndStrFlag  |= bitAcc0;
// enter normal game
void simpleGame() {
  Keyboard.write(KEY_BACKSPACE);
  delay(200);
  Keyboard.write(KEY_TAB);
  delay(100);
// enter game with Harvest
void harvestGame() {
  delay(200);
  delay(200);
  Keyboard.write('H');
  delay(200);
  delay(100);
void AltTab() {
  Keyboard.press(KEY_LEFT_ALT);
  Keyboard.press(KEY_TAB);
  delay(100);
  Keyboard.releaseAll();
  delay(100);
void ShiftAltTab() {
  Keyboard.press(KEY_LEFT_SHIFT);
  delay(100);
  delay(100);
// personnal map (bug in the official one)
//                    MAIN LOOP
void loop() {
  // ------------------------------------------  commands read from serial input
  while (Serial.available()) {
    char inChar = (char)Serial.read();
    rcvString[nrcv++] = inChar;
    if (inChar == '\n') {
      rcvString[strcspn(rcvString, "\r\n")] = 0;
      // enFS, qtFS, qtGm, keyA, keyE, keyH, key{letter}, kPSC, kTAB, kENT, kBKS, kESC,
      // ld{ngame:02d}, sOk0, sOk1
      //---------------------------------------------------------------------------- keys
      // ----- simple key
      if      (strncmp(rcvString, "key", 3) == 0)   Keyboard.write(az2qw(rcvString[3]));
      // ----- special key
      else if (rcvString[0] == 'k') {
        addStr = rcvString + 1 ;
        if (rcvString[1] == 'F') {
          if      (strcmp(addStr, "F01") == 0)  Keyboard.write(KEY_F1);
          else if (strcmp(addStr, "F02") == 0)  Keyboard.write(KEY_F2);
          else if (strcmp(addStr, "F03") == 0)  Keyboard.write(KEY_F3);
          else if (strcmp(addStr, "F04") == 0)  Keyboard.write(KEY_F4);
          else if (strcmp(addStr, "F05") == 0)  Keyboard.write(KEY_F5);
          else if (strcmp(addStr, "F06") == 0)  Keyboard.write(KEY_F6);
          else if (strcmp(addStr, "F07") == 0)  Keyboard.write(KEY_F7);
          else if (strcmp(addStr, "F08") == 0)  Keyboard.write(KEY_F8);
          else if (strcmp(addStr, "F09") == 0)  Keyboard.write(KEY_F9);
          else if (strcmp(addStr, "F10") == 0)  Keyboard.write(KEY_F10);
          else if (strcmp(addStr, "F11") == 0)  Keyboard.write(KEY_F11);
          else if (strcmp(addStr, "F12") == 0)  Keyboard.write(KEY_F12);
          delay(100);
        else if (rcvString[1] == 'K') {
          if      (strcmp(addStr, "KP0") == 0)  Keyboard.write(KEYPAD_0);
          else if (strcmp(addStr, "KP1") == 0)  Keyboard.write(KEYPAD_1);
          else if (strcmp(addStr, "KP2") == 0)  Keyboard.write(KEYPAD_2);
          else if (strcmp(addStr, "KP3") == 0)  Keyboard.write(KEYPAD_3);
          else if (strcmp(addStr, "KP4") == 0)  Keyboard.write(KEYPAD_4);
          else if (strcmp(addStr, "KP5") == 0)  Keyboard.write(KEYPAD_5);
          else if (strcmp(addStr, "KP6") == 0)  Keyboard.write(KEYPAD_6);
          else if (strcmp(addStr, "KP7") == 0)  Keyboard.write(KEYPAD_7);
          else if (strcmp(addStr, "KP8") == 0)  Keyboard.write(KEYPAD_8);
          else if (strcmp(addStr, "KP9") == 0)  Keyboard.write(KEYPAD_9);
          else if (strcmp(addStr, "KP/") == 0)  Keyboard.write(KEYPAD_SLASH);
          else if (strcmp(addStr, "KP*") == 0)  Keyboard.write(KEYPAD_ASTERISK);
          else if (strcmp(addStr, "KP-") == 0)  Keyboard.write(KEYPAD_MINUS);
          else if (strcmp(addStr, "KP+") == 0)  Keyboard.write(KEYPAD_PLUS);
          else if (strcmp(addStr, "KPE") == 0)  Keyboard.write(KEYPAD_ENTER);
          else if (strcmp(addStr, "KP.") == 0)  Keyboard.write(KEYPAD_PERIOD);
          delay(100);
        else if (rcvString[1] == 'P') {
          if      (strcmp(addStr, "PSC") == 0)  Keyboard.write(KEY_PRINT_SCREEN);
          else if (strcmp(addStr, "PGU") == 0)  Keyboard.write(KEY_PAGE_UP);
          else if (strcmp(addStr, "PGD") == 0)  Keyboard.write(KEY_PAGE_DOWN);
          else if (strcmp(addStr, "PAU") == 0)  Keyboard.write(KEY_PAUSE);
          delay(100);
        else if (rcvString[1] == 'E') {
          if      (strcmp(addStr, "ESC") == 0)  Keyboard.write(KEY_ESC);
          else if (strcmp(addStr, "END") == 0)  Keyboard.write(KEY_END);
          else if (strcmp(addStr, "ENT") == 0)  Keyboard.write(KEYPAD_ENTER);
          delay(100);
        else if (rcvString[1] == 'A') {
          if      (strcmp(addStr, "ArU") == 0)  Keyboard.write(KEY_UP_ARROW);
          else if (strcmp(addStr, "ArD") == 0)  Keyboard.write(KEY_DOWN_ARROW);
          else if (strcmp(addStr, "ArL") == 0)  Keyboard.write(KEY_LEFT_ARROW);
          else if (strcmp(addStr, "ArR") == 0)  Keyboard.write(KEY_RIGHT_ARROW);
          delay(100);
        else {
          if      (strcmp(addStr, "TAB") == 0)  Keyboard.write(KEY_TAB);
          else if (strcmp(addStr, "RET") == 0)  Keyboard.write(KEY_RETURN);
          else if (strcmp(addStr, "BKS") == 0)  Keyboard.write(KEY_BACKSPACE);
          else if (strcmp(addStr, "HOM") == 0)  Keyboard.write(KEY_HOME);
          delay(100);
      // ----- combined keys
      else if (strcmp(rcvString, "AlTb") == 0)  AltTab();
      else if (strcmp(rcvString, "ShAT") == 0)  ShiftAltTab();
      // ---------------------------------------------------------------------- functions
      // ----- send info or not
      else if (strncmp(rcvString, "sOk", 3) == 0) sendOk = (rcvString[3] == '1');
      // ----- accept or not interrupt
      else if (strncmp(rcvString, "iOk", 3) == 0) intOk = (rcvString[3] == '1');
      // ----- load game #
      else if (strncmp(rcvString, "ld", 2) == 0)  loadGame(atoi(rcvString + 2));
      // ----- simple game
      else if (strcmp(rcvString, "SiGa") == 0)    simpleGame();
      // ----- harvest game
      else if (strcmp(rcvString, "HaGa") == 0)    harvestGame();
      // ----- quit FS
      else if (strcmp(rcvString, "qtGm") == 0)    {
        quitGame();
        forceReleaseButtons = true;
      // ----- quit FS
      else if (strcmp(rcvString, "relb") == 0)    forceReleaseButtons = true;
      // ----- reset Arduino Due
      else if (strcmp(rcvString, "rstd") == 0)    RSTC->RSTC_CR = 0xA5000005;
      // ----- clear string
      nrcv = 0;
  // ----- reset speed
  if (sndStrFlag & bitAcc0) {
  // ----- Common loop PR/ PC / keyboard  (nCharPRList < nStrToSend < nCharWList)
  for (il = 0, jl = 1, kl = 1, ll = 2; il < nCharPRList; il++, jl <<= 1, kl <<= 2, ll <<= 2) {
    if (kbCharPR & kl) {
      // press key
      Keyboard.press(kbPRlist[il]);
      kbCharPR &= ~kl;
    else if ((kbCharPR & ll)) {
      // release key
      Keyboard.release(kbPRlist[il]);
      kbCharPR &= ~ll;
    if (sndStrFlag & jl) {
      // send Strings to PC
      sendSerial(strToSend[il]);
      sndStrFlag &= ~jl;
    if (kbCharW & jl) {
      // chars to send (write) to keyboard
      Keyboard.write(kbWlist[il]);
      kbCharW &= ~jl;
  // ----- Common loop PC / keyboard  (nStrToSend < nCharWList)
  for (; il < nStrToSend; il++, jl <<= 1) {
      sndStrFlag &= ~jl;
    if (kbCharW & jl) {
      kbCharW &= ~jl;
  // ----- remaining chars to write to keyboard
  for (; il < nCharWList; il++, jl <<= 1) {
    if (kbCharW & jl) {
      kbCharW &= ~jl;
  // ----- special sequence to send to keyboard
  if (kbCharSeqFFF) {
    for (il = 0; il < 3; il++) Keyboard.write('F');
  if (kbCharSeqFFF5) {
    delay(100);
    Keyboard.write(229);
  if (kbCharSeqFFF6) {
    delay(100);
    Keyboard.write(230);
  if (kbCharSeq5F5) {
    delay(100);
    delay(100);
  if (kbCharSeq6F6) {
    delay(100);
    delay(100);
  if (kbCharSeq56F56) {
    delay(100);
    delay(100);
    delay(100);
    delay(100);
  if (forceReleaseButtons) {
    // release all buttons
    oldSendOk = sendOk;
    sendOk = true;
    if (hornOn)         _hornOff();
    if (beaconOn)       _beacon();
    if (warningOn)      _WarningOff();
    if (Li_fr_down)     _lght_fr_low();
    if (Li_re_down)     _lght_re_low();
    if (Li_fr_up)       _lght_fr_up();
    if (Li_re_up)       _lght_re_up();
    if (leftBlinkerOn)  _leftBlinkOff();
    if (rightBlinkerOn) _rightBlinkOff();
    if (zoomInOn)       _zoomInOff();
    if (zoomOutOn)      _zoomOutOff();
    if (cameraOn)       _setCamera();
    releaseCnt = 1;
  // check delta time to send data
  t1 = millis();
  // check if horn not blocked
  if (hornOn && ((unsigned long)(t1 - tHorn0) >= dtHorn)) forceReleaseButtons = true;
  // ------------------------------------------ Steering Wheel
  // read from ADC (0.1 to 3.2)
  curStwVal = myMap(analogRead(in_steeringW), 124, 3971);
  // write to DAC
  if (curStwVal != prevStwVal) {
    analogWrite(out_steeringW, curStwVal);
    prevStwVal = curStwVal;
    curStwAngle = map(curStwVal, 0, maxV12, -30, 30);
    if ((curStwAngle != prevStwAngle) && (okToSend)) {
      sprintf(sndString, "1STW%d", curStwAngle); // + offset ?
      sendSerial(sndString);
      prevStwAngle = curStwAngle;
  // ------------------------------------------ Accel
  // read from ADC (accel pedal max value is 2.4 V instead of 3.2)
  if ((!brakesOn) && (Direction != 0)) {
    accelPedal = myMap(analogRead(in_acc_pedal), 124, 2966);
    accelHand  = myMap(analogRead(in_acc_hand),  124, 2225);
    curAccel = max(accelPedal, accelHand);
    // write to DAC
    if (curAccel != prevAccel) {
      prevAccel = curAccel;
      if      (Direction ==  1) analogWrite(out_forward, curAccel);
      else if (Direction == -1) analogWrite(out_bckward, curAccel);
      curAccel2 = map(curAccel, 0, maxV12, 0, 100);
      if ((curAccel2 != prevAccel2) && (okToSend)) {
        sprintf(sndString, "1ACC%.2f", min(1.05 * float(curAccel2) / 100., 1.));
        prevAccel2 = curAccel2;
  // ------------------------------------------ brakes
  curBrksVal = myMap(analogRead(in_brakes), 124, 3971);
  if (curBrksVal != prevBrksVal) {
    prevBrksVal = curBrksVal;
    analogWrite(out_brakes, curBrksVal);
    if ((curBrksVal < 820) && (brakesOn)) {
      sendSerial((char *)"2BRK0");
      brakesOn = false;
    else if ((curBrksVal > 1230) && (!brakesOn)) {
      sendSerial((char *)"2BRK1");
      // reset speed
      brakesOn = true;
  if (okToSend) t0 = t1;
  if (releaseCnt) {
    // count the nb of loop: be sure we made 1 loop at least
    releaseCnt += 1;
    if (releaseCnt == 3) {
      // we are sure here that the buttons were released
      releaseCnt = 0;
      sendOk = oldSendOk;
//                    INTERRUPTIONS
// ---------------------------------------------- pin_PosN_0 & pin_PosN_1 & pin_BP4_N
void _posN() {
  if (intOk) kbCharW |= bitKeyB;     // PosN -> 'B'
// ---------------------------------------------- pin_Horn
void _hornOn() {
  if (intOk) {
    attachInterrupt(pin_Horn, _hornOff, FALLING);
    hornOn = true;
    tHorn0 = millis();
    kbCharPR |= bitKey0Press;     // Horn -> '0'  HOLD
void _hornOff() {
  kbCharPR |= bitKey0Release;       // Horn -> '0'  RELEASE
  hornOn = false;
// ---------------------------------------------- pin_Beacon
void _beacon() {
  if (intOk) {
    kbCharW |= bitKeyHome ;           // 'HOME'
    beaconOn = !beaconOn;
    strToSend[nStrBeacon][4] = char(48 + int(beaconOn));
    sndStrFlag |= bitBeacon;
// ---------------------------------------------- pin_SeqLev_PB
void _act_o() {
  if (intOk) kbCharW |= bitKeyO;       // action -> 'O'
// ---------------------------------------------- pin_RightBlinker
void _rightBlinkOn() {
  if (intOk) {
    attachInterrupt(pin_RightBlinker, _rightBlinkOff, FALLING);
    kbCharW |= bitKP3;            // KP3 -> 227
    strToSend[nStrRightBlinker][4] = '1';
    rightBlinkerOn = true;
    sndStrFlag |= bitRightBlinker;
void _rightBlinkOff() {
  strToSend[nStrRightBlinker][4] = '0';
// ---------------------------------------------- pin_LeftBlinker
void _leftBlinkOn() {
  if (intOk) {
    attachInterrupt(pin_LeftBlinker, _leftBlinkOff, FALLING);
    kbCharW |= bitKP1;            // KP1 -> 225
    strToSend[nStrLeftBlinker][4] = '1';
    leftBlinkerOn = true;
    sndStrFlag |= bitLeftBlinker;
void _leftBlinkOff() {
  strToSend[nStrLeftBlinker][4] = '0';
// ---------------------------------------------- pin_Warning
void _WarningOn() {
  if (intOk) {
    attachInterrupt(pin_Warning, _WarningOff, FALLING);
    kbCharW |= bitKP2;            // KP2 -> 226
    strToSend[nStrWarning][4] = '1';
    warningOn = true;
    sndStrFlag |= bitWarning;
void _WarningOff() {
  strToSend[nStrWarning][4] = '0';
  warningOn = false;
// ---------------------------------------------- pin_Li_FrUp
void _lght_fr_up() {
  if (intOk) {
    Li_fr_up = !Li_fr_up;
    strToSend[nStrLghtFrUp][4] = char('0' + int(Li_fr_up));
    sndStrFlag |= bitLghtFrUp;
    kbCharW |= bitKP5;            // KP5 -> 229
// ---------------------------------------------- pin_Li_FrDown
void _lght_fr_low() {
  if (intOk) {
    Li_fr_down = !Li_fr_down;
    sndStrFlag |= bitLghtFrDown;
    boolean Li_re = Li_re_up || Li_re_down;
    if (Li_fr_down) {
      if (Li_fr_up && Li_re) kbCharSeq56F56 = true;
      else if (Li_fr_up)     kbCharSeq5F5 = true;
      else if (Li_re)        kbCharSeq6F6 = true;
      else                   kbCharW |= bitKeyF;
    else {
      if (Li_fr_up != Li_re)  kbCharSeqFFF = true;
      else if (Li_fr_up)      kbCharSeqFFF5 = true;
      else                    kbCharSeqFFF6 = true;
// ---------------------------------------------- pin_Li_ReUp
void _lght_re_up() {
  if (intOk) {
    Li_re_up = !Li_re_up;
    strToSend[nStrLghtReUp][4] = char('0' + int(Li_re_up));
    sndStrFlag |= bitLghtReUp;
    if (! Li_re_down) kbCharW |= bitKP6;            // KP6 -> 230
// ---------------------------------------------- pin_Li_ReDown
void _lght_re_low() {
  if (intOk) {
    Li_re_down = !Li_re_down;
    sndStrFlag |= bitLghtReDown;
    if (! Li_re_up) kbCharW |= bitKP6;            // KP6 -> 230
// ---------------------------------------------- pin_UTurn
void _u_turn() {
  if (intOk) kbCharW |= bitKeyG;       // 'G'
// ---------------------------------------------- pin_LG_Up
void _lg_up() {
  if ((intOk) && (!Lg_up)) {
    kbCharW |= bitKeyV;           // 'V'
    Lg_up = true;
// ---------------------------------------------- pin_LG_Down
void _lg_down() {
  if ((intOk) && (Lg_up)) {
    Lg_up = false;
// ---------------------------------------------- pin_HydrauLeftLeverFrwd
void _hydLeftFwd() {
  if (intOk) kbCharW |= bitKeyX;           // 'X'
// ---------------------------------------------- pin_HydrauLeftLeverBkwd
void _hydLeftBwd() {
// ---------------------------------------------- pin_HydrauRightLeverFrwd
void _hydRightFwd() {
  if (intOk)  kbCharW |= bitKeyI;           // 'I'
// ---------------------------------------------- pin_HydrauRightLeverBkwd
void _hydRightBwd() {
// ---------------------------------------------- pin_GreenButtonLeftJS
void _setCamera() {
  cameraOn = !cameraOn;
  if (intOk) kbCharW |= bitKeyC;         // 'C'
// ---------------------------------------------- pin_RedButtonLeftJS
void _hideshowpan() {
  if (intOk) kbCharW |= bitKeyBS;      // 'BS'
// ---------------------------------------------- pin_GreenButtonRightJS
void _zoomOutOn() {
  if (intOk) {
    attachInterrupt(pin_GreenButtonRightJS, _zoomOutOff, FALLING);
    zoomOutOn = true;
    kbCharPR |= bitKeyPgUpPress;      // zoomOut -> 'PgUp'  HOLD
void _zoomOutOff() {
  kbCharPR |= bitKeyPgUpRelease;        // zoomOut -> 'PgUp'  RELEASE
  zoomOutOn = false;
// ---------------------------------------------- pin_RedButtonRightJS
void _zoomInOn() {
  if (intOk) {
    attachInterrupt(pin_RedButtonRightJS, _zoomInOff, FALLING);
    zoomInOn = true;
    kbCharPR |= bitKeyPgDwnPress;     // zoomIn -> 'PgDown' HOLD
void _zoomInOff() {
  kbCharPR |= bitKeyPgDwnRelease;       // zoomOut -> 'PgDown'  RELEASE
  zoomInOn = false;
// ---------------------------------------------- pin_FrwdInfo
void _forwardOn() {
  attachInterrupt(pin_FrwdInfo, _forwardOff, FALLING);
  setDirection(1);
void _forwardOff() {
  setDirection(0);
// ---------------------------------------------- pin_BkwdInfo
void _backwardOn() {
  attachInterrupt(pin_BkwdInfo, _backwardOff, FALLING);
  setDirection(-1);
void _backwardOff() {
  setDirection(0);
// ---------------------------------------------- pin_FrwdBkwdToggle
void _toggleDir() {
  if (Direction == 0) Direction = -1 ;
  setDirection(-Direction);
// ---------------------------------------------- pin_A
void _attach() {
  if (intOk) kbCharW |= bitKeyA;      // 'A'
2/ Arduino UNO (attached to "Master" PC)
Nothing very special to notice... It's a quite simple program.
inputsUNO.c  _______________________________________________________________
Program Arduino UNO
Manage relays for Farming Simulator
// ----- pins for Raspberry's
const short RPi_Out  = 0;
const short RPi_Disp = 1;
const short RPi_Pres = 2;
const short Supply15 = 3;
short Rpi_pins[] = {10, 11, 12, 13};
// ----- Sound relays (high current)
short Sound_pins[] = {8, 9};
// pin for reset DUE
const short pin_resetDue = 3;
// Cylinders orders
const short Order1 = 0;
const short Order2 = 1;
const short Order3 = 2;
const short Order4 = 3;
short Order_pins[] = {7, 6, 5, 4};
const short pin_TireUp   =  2 ;    // ---- Tire Up info
// ----- boolean to send
volatile boolean sendTireUp = false;
int nrcv = 0;
//                    SETUP
void setup() {
  // -------------------------------------------- Relays
  // ----- output pins for sound relays
  for (short i=0; i<2; i++) pinMode(Sound_pins[i], OUTPUT);
  sndRelays(0);
  // ----- output pins for Rpi's relays
  for (short i=0; i<4; i++) pinMode(Rpi_pins[i], OUTPUT);
  rpiRelays('a', 0);
  setSupply(1);
  // ----- output pins for cylinders orders' relays
  for (short i=0; i<4; i++) pinMode(Order_pins[i], OUTPUT);
  orderRelays(0);
  // reset DUE
  pinMode(pin_resetDue, OUTPUT);
  digitalWrite(pin_resetDue, HIGH);
  // attach an interrupt to the tire Up info
  attachInterrupt(digitalPinToInterrupt(pin_TireUp), _TireUp, RISING);
  while (!Serial);
//                    SUBROUTINES
  if (Serial.availableForWrite() > strlen(txt)) {
// ----- relays sound
void sndRelays(short onOff) {
  for (short i=0; i<2; i++) digitalWrite(Sound_pins[i], onOff);
// ----- relays RPi's
void rpiRelays(char nr, short onOff) {
  if (nr == 'a') {
    for (short i=0; i<3; i++) digitalWrite(Rpi_pins[i], 1-onOff);
  else digitalWrite(Rpi_pins[nr-'0'], 1-onOff);
// ----- set 15v supply
void setSupply(short onOff) {
  digitalWrite(Rpi_pins[Supply15], 1-onOff);
// ----- relays orders
void orderRelays(short nr) {
  if (nr == 0){
      for (short i=0; i<4; i++) digitalWrite(Order_pins[i], 1);
  else {
      for (short i=1; i<5; i++) {
          if (i == nr) digitalWrite(Order_pins[i-1], 0);
          else         digitalWrite(Order_pins[i-1], 1);
void resetDue() {
  digitalWrite(pin_resetDue, LOW);
  delay(500);
//                    MAIN LOOP
void loop() {
      // for DEBUG Serial.println(rcvString);
      // snd{0|1}, rpi{0|1|2|a}{0|1}, rstd, ord{0|1|2|3}, sup{0|1}
      if      (strncmp(rcvString, "snd", 3) == 0) sndRelays(rcvString[3] - '0');
      else if (strncmp(rcvString, "rpi", 3) == 0) rpiRelays(rcvString[3], rcvString[4] - '0');
      else if (strncmp(rcvString, "sup", 3) == 0) setSupply(rcvString[3] - '0');
      else if (strncmp(rcvString, "ord", 3) == 0) orderRelays(rcvString[3] - '0');
      else if (strcmp(rcvString, "rstd") == 0)  resetDue();
      else if (strcmp(rcvString, "rstu") == 0) {
        setSupply(1);
        sndRelays(0);
        rpiRelays('a', 1);
        orderRelays(0);
      else if (strcmp(rcvString, "shtd") == 0) {
        sndRelays(0);
        rpiRelays('a', 0);
        orderRelays(0);
        setSupply(0);
      nrcv = 0;
  if (sendTireUp) {
    sendSerial((char *)"TiUp");
    sendTireUp = false;
//                    INTERRUPTIONS
void _TireUp() {
  sendTireUp = true;     // set flag to true
Back to intro
Tractor Simulator (interface with Farming Simulator 17)
Global presentation
Tractor simulator (cabin tractor interface with Farming Simulator 17): Part 1 - global presentation
The hardware
Tractor simulator (cabin tractor interface with Farming Simulator 17): Part 2 - the hardwareTractor simulator (cabin tractor interface with Farming Simulator 17): Part 2 - the hardware
Actual doc
Raspberry Pis
Tractor simulator (cabin tractor interface with Farming Simulator 17): Part 3 - the software, 2/ Raspberrys
PCs
Tractor simulator (cabin tractor interface with Farming Simulator 17): Part 3 - the software, 3/ PCs
