Legacy Personal Blogs Tractor simulator (cabin tractor interface with Farming Simulator 17): Part 3 - the software, 2/ Raspberrys
  • Author Author: dhal
  • Date Created: 18 Dec 2017 11:54 AM Date Created
  • Views 755 views
  • python
  • raspberry-pi3
  • raspberry_pi_3
dhal
dhal
18 Dec 2017
1/ Raspberry's configuration
I have downloaded the "Raspbian Stretch with Desktop" version from the Rasperry site and copy the image with Win32DiskImager on a 16Go micro SDHC card (class 10, up to 100 MB/s, "A1").
I have let the raspberry boot on it (expand the filesystem), then I have adapted  the local configs (keyboard, TimeZone, no splash ..) and allowed SSH login .
After that, I have added some extra info in the /boot/cmdline.txt file :
- logo.nologo         to hide the 4 raspberry logos on the boot screen
- consoleblank=0    to turn screen blanking off completely
- net.ifnames=0    to restore original ethernet names
I have then removed all the apps I don't use (from here).
sudo apt-get --purge remove wolfram-engine bluej greenfoot nodered nuscratch scratch sonic-pi libreoffice* claws-mail claws-mail-i18n minecraft-pi python-pygame
sudo apt-get autoremove --purge
sudo apt-get update && sudo apt-get upgrade -y
I have disabled the X screen blanking/sleep (screensaver) in changing one line in /etc/lightdm/lightdm.conf, below the [Seat:*] section
#xserver-command=X     to    xserver-command=X -s 0 -dpms
(ie. blanking timeout to 0 and turn off the display power management signaling)
I have installed nuitka to compile my python scripts:
sudo pip3 install nuitka
I have created a devDH dir (my dev dir) under /home/pi.
I have written compile file under /home/pi/devDH to compile my python scripts (and chmod u+x on it; usage: ./compile myPythonScript Option)
compile________________________________________________________________
#!/bin/bash
nuitka --recurse-all --python-version=3.5 --remove-output  $2 $1.py
if [ -d $1.build ]; then
    rm -r $1.build
fi
if [ -d $1.dist ]; then
    cp -u -r ./$1.dist/* .
    rm -r ./$1.dist
fi
if [ -f $1.exe ]; then
    chmod u+x ./$1.exe
fi
______________________________________________________________________________________
I have added a setConfig.ini under /boot dir whose utility will be described later:
setConfig.ini _________________________________________________________________
[SETTINGS]
done = 0
stoplaunch = 0
debug = 0
verbose = b11
[NET]
base = 192.168.0.
node = oneNameInTheAddressSectionBelow
links = Name(s)InTheAddressSectionBelowSeparatedByCommaOrEmpty
port_base = 17700
wifi = 0
ssid =
psk =
static = 1
gateway = 1
dns = 3
[ADDRESS]
fs_hat = 60
rpi_pres = 61
rpi_out = 62
rpi_disp = 63
master = 64
show = 65
The advantage of this file (as in /boot)  is it can be modified directly on the microSD card (under windows for example) without the need to be under Raspbian. As guessed, it helps for the net configuration of the raspberrys.
I have added a file launch.desktop under /home/pi/.config/autostart to launch my app automatically after boot:
launch.desktop__________________________________________________________
[Desktop Entry]
Type=Application
Name=launch
NoDisplay=true
Exec=/home/pi/devDH/launch.sh
For the Raspberry "Outputs", I add at the end of .bashrc the line /home/pi/devDH/launch.sh as it doesn't need the graphic (startx) environment (just CLI - "Command Line Interface" - mode).
with launch.sh (under /home/pi/devDH and chmod u+x on it):
launch.sh____________________________________________________________________
#!/bin/bash
cd /home/pi/devDH
#  LAUNCH PROGRAM IF NOT SSH
if [ "$(echo $(who am i) | cut -c 4-6)" != "pts" ]; then
    # CONFIG
    clear
    echo -e -n "\nSet config ..."
    sudo ./setConfig.exe
    let exval=$?
    echo -e " Ok\n"
    if [ $exval -eq 1 ]; then
        progName="NameOfTheExeProgramToLaunch"
        # Wait for connection
        echo -e -n "\nConnection ..."
        IP=$(hostname -I) || true
        until [ "$IP" ]; do
        done
        echo -e "\b\b\b => IP address = $IP\n"
        # LAUNCH PROGRAM
        # ----- PROGRAM -----
        while [ $exval -eq 1 ]; do
            echo -e "\nLaunching program\n"
            debug=`cat /boot/setConfig.ini | grep debug | cut -d'=' -f2`
            if [ $((debug)) -eq 1 ]; then
                # ----- through lxterminal if in debug mode
                lxterminal -e ./$progName.exe
                let exval=0
            else
                ./$progName.exe
                let exval=$?
            fi
        done
        if [ $exval -eq 3 ]; then
            sudo halt
        elif [ $exval -eq 2 ]; then
            sudo reboot
        fi
        echo -e -n "\nReboot ..."
        sudo reboot
    fi
fi
Principle: I use the exit codes of the programs (exval) to choose either to stop (0) or reboot the program (1), reboot (2) or shutdown (3) the raspberrys.
Also, depending on the attached screen, some lines to change or add in the /boot/config.txt
hdmi_force_hotplug=1                         force the HDMI output even if not detected
hdmi_group=2                                 see here
hdmi_mode=87                                 see here
hdmi_cvt={W} {H} {Hz} {ratio} 0 0 0          see here
max_usb_current=1                            for max current in the USB plug, to power a screen for example
display_rotate=2                             if needed to rotate the screen of 180° (here)
If needed to add some extra fonts (for Zen@Terra App), copy the fonts (.TTF, .OTF, .TTC) to /usr/local/share/fonts
Finally, for the tactile screen (Zen@Terra App):
sudo apt-get install xserver-xorg-input-evdev xinput-calibrator -y
sudo mv /usr/share/X11/xorg.conf.d/10-evdev.conf /usr/share/X11/xorg.conf.d/45-evdev.conf
(ie. renaming 10-evdev.conf to 45-evdev.conf in order to get it to load after 40-libinput.conf so Xinput_calibrator could calibrates and save the calibration data into /usr/share/X11/xorg.conf.d/99-calibration.conf)
2/ Common python function
2.1/ Set Configuration
As seen above, I wrote a setConfig exe file to configure automatically after boot the rapsberry, depending on the done field in the /boot/setConfig.ini file
setConfig.py_________________________________________________________________
#!/usr/bin/python3.5
# -*- coding: utf-8 -*-
""" setConfig
    Set raspberry configuration
__author__ = 'Damien HALLEZ'
__version__ = '1.1'
__date__ = 'Nov 2017'
#                                MAIN
if __name__ == "__main__":
    from configparser import ConfigParser
    from  os import name as osname
    dhMark = '@ddevDH'
    iniFile = '/boot/setConfig.ini'
    dhcpcdFile = '/etc/dhcpcd.conf'
    wifiFile = '/etc/wpa_supplicant/wpa_supplicant.conf'
    hostfile1 = '/etc/hostname'
    hostfile2 = '/etc/hosts'
    if osname == 'nt':
        # ----- changes for windows env to test
        ptxt = '.txt'
        iniFile = iniFile.replace('/', '_')
        dhcpcdFile = dhcpcdFile.replace('/', '_')
        wifiFile = wifiFile.replace('/', '_')
        hostfile1 = hostfile1.replace('/', '_') + ptxt
        hostfile2 = hostfile2.replace('/', '_') + ptxt
    config = ConfigParser()
    config.filename = iniFile
    config.read(config.filename, encoding='utf-8')
    SETTINGS = config['SETTINGS']
    NET = config['NET']
    if bool(int(SETTINGS['done'])):
        exitVal = 1 # ----- continue, nothing to configure
    else:
        # ===== set the hostname
        hostname = NET['node'].strip().title()
        IdRecv = int(config['ADDRESS'][hostname])
        netBase = NET['base'].strip()
        wifiFlag = bool(int(NET['wifi']))
        # ***** ==== read DHCPCD.CONF
        # ----- read the  file
        with open(dhcpcdFile, 'rt') as dhcpcd: txt = dhcpcd.readlines()
        # ----- copy until "@ddevDH"
        txtr = []
        dhMarkFlag = False
        for t in txt:
            txtr.append(t)
            if dhMark in t:
                dhMarkFlag = True
                break
        if not dhMarkFlag: txtr.append('# {}\n'.format(dhMark))
        if bool(int(NET['static'])):
            # ----- ajout addresse
            if wifiFlag:
                txtr.append('interface wlan0\n')
            else:
                txtr.append('interface eth0\n')
            txtr.append('static ip_address={}{}/24\n'.format(netBase, IdRecv))
            txtr.append('static routers={}{}\n'.format(netBase, NET['gateway'].strip()))
            dns = NET['dns'].strip()
            if len(dns) > 3:
                txtr.append('static domain_name_servers={} 8.8.8.8\n'.format(dns))
            else:
                txtr.append('static domain_name_servers={}{} 8.8.8.8\n'.format(netBase, dns))
        # ***** ===== rewrite ----- DHCPCD.CONF
        with open(dhcpcdFile, 'wt') as dhcpcd: dhcpcd.writelines(txtr)
        # §§§§§ ===== read WPA_SUPPLICANT.CONF
        with open(wifiFile, 'rt') as wifi: txt = wifi.readlines()
        txtr = []
        dhMarkFlag = False
        for t in txt:
            txtr.append(t)
            if dhMark in t:
                dhMarkFlag = True
                break
        if wifiFlag:
            txtr.append('network={\n')
            txtr.append('ssid="{}"\n'.format(NET['ssid']))
            txtr.append('psk="{}"\n'.format(NET['psk']))
            txtr.append('}\n')
        # §§§§§ ===== rewrite WPA_SUPPLICANT.CONF
        with open(wifiFile, 'wt') as wifi: wifi.writelines(txtr)
        # ##### ===== rewrite "hostname"
        with open(hostfile1, 'wt') as hst1: hst1.write(hostname + '\n')
        # $$$$$ =====  read "hosts"
        with open(hostfile2, 'rt') as hst2: txt = hst2.readlines()
        lclIp = '127.0.1.1'
        txtr = []
        for t in txt:
            if lclIp in t:
                txtr.append('{}       {}\n'.format(lclIp, hostname))
            else:
                txtr.append(t)
        # $$$$$ =====  rewrite "hosts"
        with open(hostfile2, 'wt') as hst2: hst2.writelines(txtr)
        # ---- set the modification flag in setConfig.ini
        config['SETTINGS']['done'] = '1'
        with open(config.filename, 'wt', encoding='utf-8') as cfgfile:
            config.write(cfgfile)
        exitVal = 2 # ----- to reboot (see launch.sh)
    if bool(int(SETTINGS['stoplaunch'])):
        exitVal = 0
    exit(exitVal)
It modifies the files /boot/setConfig.ini, /etc/dhcpcd.conf, /etc/wpa_supplicant/wpa_supplicant.conf, /etc/hostname and /etc/hosts with the right parameters read from /boot/setConfig.ini.
The setConfig.exe file was built with ./compile setConfig in /home/pi/devDH.
2.2/ TCP/IP manager
As seen on the general presentation (Part 1), all the PCs/Raspberrys "talk" to each other thanks to an ethernet link. I choose a TCP/IP protocol which is very reliable.
defTCPIP.py_________________________________________________________________
""" TCPIP link manager
__version__ = '1.2'
import socket, select
from multiprocessing import Process, Queue
from queue import Empty
BUF_SIZE = 512          # large enough fro my app
#                              TCP Send
class TCPLink():
    TCPLink(IPtoNnode, IPtoNlinks, portBase, feedback=None)
        portBase = port base to define receive and send port from address
        IPtoN = {'192.168.1.xx':'Name1', '192.168.1.xy':'Name2', ... }
        feedback = None if managed by the process TCPLink
            otherwise, it's a queue IN for the calling process (q.put_nowait)
                       (q.get in the calling process)
            from sender:
             ['TCP:snt1', msgs,     toHost] when msgs successfully sent
             ['TCP:snt0', msgs,     toHost] when msgs failed to send
             ['TCP:out', 'TCPSend', toHost] when 'TCPSend' exited
            from reicever:
             ['TCP:rcv1', msgs, fromHost] when msgs received from FromHost
             ['TCP:rcv0', msgs, addr] when msgs received from addr
             ['TCP:rcv?', msgs, ''] when received msgs not in good format
             ['TCP:out', 'TCPRecv', '<:>'] when 'TCPRecv' exited
    def __init__(self, IPtoNnode, IPtoNlinks, portBase, feedback=None):
        # ----- queue to send to
        if feedback is None:
            self.qFeedback = Queue()
            feedback = self.qFeedback.put_nowait
        else:
            self.qFeedback = None
        self.feedback = feedback
        # ----- get IP Addr from hosts
        self.IPtoN = IPtoNlinks
        self.portBase = portBase
        # ----- set local address
        self.myAddr, self.hostName = list(IPtoNnode.items())[0]
        self.portRecv = portBase + int(self.myAddr.split('.')[-1])
        print('\tConnecting "{}" ({}, {}) to'\
              .format(self.hostName, self.myAddr, self.portRecv))
        # ----- receiver process
        self.pRecv = Process(target=TCPRecv, \
                             args=(self.portRecv, IPtoNlinks, feedback))
        self.pRecv.start()
        # ----- sender processes
        self.N_AdportQueProcStat = {}
        for addr, host in IPtoNlinks.items():
            qSend = Queue()
            port = portBase + int(addr.split('.')[-1])
            if port == portBase:
                # ----- local host
                addr = socket.gethostbyname('localhost')
                port += int(addr.split('.')[-1])
            print('\t\t"{}" : ( {}, {} )'.format(host, addr, port))
            pSend = Process(target=TCPSend, \
                            args=(addr, port, host, qSend.get, \
                                        feedback, self.myAddr))
            pSend.start()
            self.N_AdportQueProcStat[host] = [ [addr, port], \
                                                qSend, pSend, True ]
    def sendTos(self, msg, hosts):
        # ----- send msg to hosts
        for host in hosts:
            self.N_AdportQueProcStat[host][1].put_nowait(msg)
    def sendTo(self, msg, host):
        # ----- send msg to one host
    def send(self, msg):
        # ----- send msg to all
        for host in self.N_PorAdQueProcStat.keys():
    def relaunch(self, host):
        # ----- relaunch a process, host = toHost or '<:>'
        #       (['TCP:out', 'TCPSend', toHost] or
        #        ['TCP:out', 'TCPRecv', '<:>'] or
        if host == '<:>':
            # ----- Receiver
            print('\t[ ] relaunch TCP link to receive from emitter(s)')
            # ----- relaunch
                                 args=(self.portRecv, self.IPtoN, \
                                       self.feedback))
            self.pRecv.start()
        else:
            # ----- Sender
            print('\t[ ] relaunch TCP link to send to ' + host)
            # ----- relaunch
            addrPort, qSend, pSend, status = self.N_AdportQueProcStat[host]
                                args=(addrPort[0], addrPort[1], host, \
                                      qSend.get, self.feedback, self.myAddr))
            pSend.start()
            self.N_AdportQueProcStat[host][2] = pSend
    def recv(self, wait4data=True, returnAll=True):
        # ----- receive data
        if self.qFeedback is not None:
            while True:
                try:
                    typ, msgs, host = self.qFeedback.get(wait4data)
                except Empty:
                    typ = msgs = host = ''
                if returnAll or (not returnAll and typ == 'TCP:recv'):
                    break
                else:
                    if typ == 'TCP:out':
                        self.relaunch(host)
                    elif typ == 'TCP:snt1':
                        print('\t-> {} to {}'.format(msgs, host))
                    elif typ == 'TCP:snt0':
                        print('\t/!\ Fail sending {} to {}'.format(msgs, host))
            if returnAll:
                return typ, msgs, host
            else:
                return msgs, host
    def stop(self, host):
        if pSend.is_alive:
            pSend.terminate()
            pSend.join()
        self.N_AdportQueProcStat[host][3] = False
        return [val[3] for val in self.N_AdportQueProcStat.values()]
    def close(self):
        # ----- close process
        if self.pRecv.is_alive(): self.pRecv.terminate()
        for addrPort, qSend, pSend, status \
                in self.N_AdportQueProcStat.values():
            if pSend.is_alive:
                pSend.terminate()
                pSend.join()
        print(' << TCPSend proc: Out')
        self.pRecv.join()
        print(' << TCPRecv proc: Out')
#                              TCP Send
def TCPSend(toAddr, toPort, toHost, get2send, feedback, myAddr):
    toAddr = 192.168.... to send to
    toPort = port to send to
    toHost = hostname of the corresponding toAddr
    getdata2send  => message to send
            protocol: cmd=val@myAddr | ack:cmd=val@myAddr
            @myAddr to manage the receivers list (see TCPRecv)
    feedback : to send data back
        ['TCP:snt1', msgs,    toHost] when msgs in qIn successfully sent
        ['TCP:snt0', msgs,    toHost] when msgs in qIn failed to send
        ['TCP:out', procName, toHost] when procName = 'TCPSend' exited
    print(' >> {} proc for {}: On'.format(procName, toHost))
    class fakesock():
        def send(self, msg): raise
        def close(self): pass
    s = fakesock() # to begin, time for other process to be connected
    while s is not None:
        msgs = get2send() + '@' + myAddr
        retry = True
        while retry:
            try:
                s.send(msgs.encode())
                feedback(['TCP:snt1', msgs, toHost])
                retry = False
            except:
                s.close()
                s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
                s.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
                try:
                    s.connect((toAddr, toPort))
                except:
                    s = None
                    retry = False
                    feedback(['TCP:snt0', msgs, toHost])
    feedback(['TCP:out', procName, toHost])
    if s is not None: s.close()
    print('\t(-) Error: TCP sending to ' + toHost)
    print(' << {} proc for {}: Out'.format(procName, toHost))
#                            TCP Receive
def TCPRecv(portRecv, IPtoN, feedback):
    portRecv = port to listen to
    IPtoN : IP[addr] = alias hostName
    feedback : send info to calling process (queue.put_nowait)
        ['TCP:rcv1', msgs, fromHost] when msgs received from identified alias host
        ['TCP:out', procName, '<:>'] when procName = 'TCPRecv' exited
    try:
        s.bind(('', portRecv))
        s.listen(5)
        s.settimeout(None)
        R_LIST = [s]
        print(' >> {} proc: On'.format(procName))
        TCPOn = True
    except:
        print(' << {} proc: Off'.format(procName))
        feedback(['TCP:out', procName, '<:>'])
        TCPOn = False
    R_Socks = []
    # ================================================= Main Loop
    while TCPOn:
        # ----- listen to procs
        R_Socks.clear()
        # ----- use select
        try:
            R_Socks = select.select(R_LIST, [], [], None)[0]
        except: pass
        # ----- read readable socks
        for sock in R_Socks:
            if sock == s:
                # new connection detected
                new_sock = s.accept()[0]
                R_Socks.append(new_sock)
                R_LIST.append(new_sock)
            else:
                # Data received from client
                try:
                    data = sock.recv(BUF_SIZE)
                    smsgs = data.decode().strip()
                    if smsgs:
                        if '@' in smsgs:
                            msg, addr = smsgs.split('@')
                            if addr in IPtoN:
                                feedback(['TCP:rcv1', msg, IPtoN[addr]])
                            else:
                                feedback(['TCP:rcv0', msg, addr])
                        else:
                            feedback(['TCP:rcv?', smsgs, ''])
                except:
                    sock.close()
                    if sock in R_LIST: R_LIST.remove(sock)
    s.close()
    print('\t(-) Error: TCP listening to Emitter')
This class creates a process to receive from and another to send to the TCP/IP link. The main class TCPLink manages these send/receive functions through queues
This is set with:
eth = TCPLink(IPtoNnode, IPtoNlinks, portBase, qIn.put_nowait)
IPtoNnode is a lookup table that associate an address to the current host name
IPtoNnode = {baseAddress+endAddressHostName: hostName} (for example: {'192.168.0.' + '63': "Rpi_Disp"}, see /boot/setConfig.ini)
IPtoNlinks is  a lookup table that associate the addresses of the other hosts to couple with their names
IPtoNlinks  {baseAddress+endAddressHostToLink: nameOfHost for nameOfHost in listOfHostsToLink } (for example {'192.168.0.64': "Master", '192.168.0.60': "Fs_Hat"})
So, in the program it will be a convenient and easy way to send orders to a host:
eth.sendTo(order, nameOfTheHostToSendTo) (example: eth.sendTo('exit=1', 'Master'))
or a same command to multiple processes
eth.sendTos(order, listOfHostsToSendTo) (example: eth.sendTos('exit=1', ['Master', 'Fs_Hat']))
portBase is a base of port number (here, set to 17700, see in /boot/setConfig.ini) from which a port will be computed from an host address (from the end of this address) and attached to this address
Actually I will use 2 channels to send and receive allowing hard-replug; as long as a process don't have to send to another process, the link is not initialized.
For example (according to  /boot/setConfig.ini) "Rpi_Disp" will be on 192.168.0.63:17763 and "Master" on 192.68.0.64:17764
     if "Rpi_Disp" wants to send an info to "Master", it will address it to 192.68.0.64:17764
     if "Master" wants to send an info to "Rpi_Disp", it will address it to 192.68.0.63:17763
To set the IPtoNnode, IPtoNlinks, portBase from the /boot/setConfig.ini from ConfigParser:
config.read('/boot/setConfig.ini', encoding='utf-8')
netCfg = config['NET']
addrCfg = config['ADDRESS']
procName = netCfg['node'].strip().title()
baseAddr = netCfg['base'].strip()
IPtoNnode = {baseAddr+addrCfg[procName]:procName}
if netCfg['links']:
    IPtoNlinks = {baseAddr + addrCfg[s.strip()].strip():\
                    s.strip().title() \
                        for s in netCfg['links'].split(',')}
qIn is a Queue from which the TCPLink class will transmit informations (errors, sending, receiving infos) to the main process which gathers all the info coming from the parrallel processes.
The info transmitted by TCPLink to qIn follows this format: [TCPInfo, message, fromOrToHost] (example: ['TCP:rcv1', 'exit=1', 'Master'])
The TCPInfo could be:
     from sender:
             ['TCP:out', 'TCPSend', toHost]      when 'TCPSend' in charge of sending to toHost exited
     from reicever:
             ['TCP:rcv1', msgs, fromHost]           when msgs received from FromHost in the list set from /boot/setConfig.ini
             ['TCP:rcv0', msgs, addr]                   when msgs received from addr not in the list set from /boot/setConfig.ini
             ['TCP:rcv?', msgs, '']                       when received msgs not in a good format
             ['TCP:out', 'TCPRecv', '<:>']        when 'TCPRecv' in charge of receiving the info from the TCP link exited
In case of receiving 'TCP:out', just use eth.relaunch(fromOrToHost) to relaunch the terminated process.
2.3/ Printing an error message
Very easy, just display a message surrounded by the '*' char ... That helps when a raspberry reboot due to an error, to have a quick view of what happened.
defErrPrint.py________________________________________________________________
def errPrint(Msg):
    print an error message
    sep = '*'*60
    print('{}\n{}\n{}\n'.format(sep, Msg.center(60), sep))
3.a/ Outputs
This raspberry is in charge of switching on/off, blinking the tractor lights, from orders coming from TCP/IP.
To use the GPIO, I've chosen the gpiozero library which offers an easy and simple way to manage the inputs/outputs. It has first to be installed:
sudo apt-get install python3-gpiozero
sudo pip3 install gpiozero
Rpi_Outputs.py_______________________________________________________________
""" PROCESS Rpi_Outputs
__version__ = '1.0'
__date__ = 'nov 2017'
#                                MAIN
    from defTCPIP import TCPLink
    from multiprocessing import Queue
    from os import path
    from time import strftime, sleep, time
    from gpiozero import LED
    from defErrPrint import errPrint
    # ------------------------------------------------------------- read config
    config.filename = r'/boot/setConfig.ini'
    if osname == 'nt':
        # windows to test program
        config.filename = config.filename.replace('/','_')
    # ----- verify config ini ok
    try:
        if netCfg['links']:
                            s.strip().title() \
        else: IPtoNlinks = {}
        portBase = int(netCfg['port_base'])
        Ok = True
    except:
        Ok = False
    if not Ok:
        errPrint(r'/!\ Error reading .ini file')
        sleep(10)
        exit(1)
    # ----- Proc Name from ini = Rpi_Outputs
    print('> {} [{}] >'.format(procName, strftime('%d/%m/%y %H:%M:%S')))
    qIn = Queue()
    # --------------------------------------------------- list of PC to connect
    print('\t{}: {} '.format(procName, eth.myAddr))
    # ---------------------------------------------------- Digital LookUp Table
    outLUT = { 'ReLeftBlinker'   : 14,  \
               'ReRightBlinker'  : 10 , \
               'FrLeftBlinker'   : 18,  \
               'FrRightBlinker'  : 23 , \
               'FrRightLghtDown' :  8 , \
               'FrLeftLghtDown'  : 24 , \
               'ReLeftLghtDown'  :  7 , \
               'ReRightLghtDown' : 25 , \
               'FrLeftLghtUpR'   : 16 , \
               'FrLeftLghtUpL'   : 20 , \
               'FrRightLghtUpL'  : 21 , \
               'FrRightLghtUpR'  :  6 , \
               'ReLeftLghtUpL'   : 13 , \
               'ReLeftLghtUpR'   : 19 , \
               'ReRightLghtUpR'  : 26 , \
               'ReRightLghtUpL'  : 12 , \
               'LeftBrake'       :  4 , \
               'Beacon'          : 27 , \
               'RightBrake'      : 15 , \
               'ReLeftRedLght'   : 11 , \
               'ReRightRedLght'  : 22
    # --- .on(), .off(), .blink(on_time=1, off_time=1, n=None, background=True)
    leftBlinkers  = [ LED(outLUT['FrLeftBlinker'],   active_high=False) , \
                      LED(outLUT['ReLeftBlinker'],   active_high=False) ]
    rightBlinkers = [ LED(outLUT['FrRightBlinker'],  active_high=False) , \
                      LED(outLUT['ReRightBlinker'],  active_high=False) ]
    lghtFrDown    = [ LED(outLUT['FrLeftLghtDown'],  active_high=False) , \
                      LED(outLUT['FrRightLghtDown'], active_high=False) ]
    lghtFrUp      = [ LED(outLUT['FrRightLghtUpR'],  active_high=False) , \
                      LED(outLUT['FrRightLghtUpL'],  active_high=False) , \
                      LED(outLUT['FrLeftLghtUpR'],   active_high=False) , \
                      LED(outLUT['FrLeftLghtUpL'],   active_high=False) ]
    lghtReDown    = [ LED(outLUT['ReLeftLghtDown'],  active_high=False) , \
                      LED(outLUT['ReRightLghtDown'], active_high=False) ]
    lghtReUp      = [ LED(outLUT['ReLeftLghtUpL'],   active_high=False) , \
                      LED(outLUT['ReLeftLghtUpR'],   active_high=False) , \
                      LED(outLUT['ReRightLghtUpL'],  active_high=False) , \
                      LED(outLUT['ReRightLghtUpR'],  active_high=False) ]
    brakes        = [ LED(outLUT['LeftBrake'],       active_high=False) , \
                      LED(outLUT['RightBrake'],      active_high=False) ]
    beacon        =   LED(outLUT['Beacon'],          active_high=False)
    ReRedLght     = [ LED(outLUT['ReLeftRedLght'],   active_high=False) , \
                      LED(outLUT['ReRightRedLght'],  active_high=False) ]
    lights = 0x000000
    iFrLeftBlinker   =  0x000001
    iReLeftBlinker   =  0x000002
    iFrRightBlinker  =  0x000004
    iReRightBlinker  =  0x000008
    iFrLeftLghtDown  =  0x000010
    iFrRightLghtDown =  0x000020
    iFrLeftLghtUpL   =  0x000040
    iFrLeftLghtUpR   =  0x000080
    iFrRightLghtUpL  =  0x000100
    iFrRightLghtUpR  =  0x000200
    iReLeftLghtDown  =  0x000400
    iReRightLghtDown =  0x000800
    iReRightLghtUpR  =  0x001000
    iReRightLghtUpL  =  0x002000
    iReLeftLghtUpR   =  0x004000
    iReLeftLghtUpL   =  0x008000
    iLeftBrake       =  0x010000
    iBeacon          =  0x020000
    iRightBrake      =  0x040000
    iReLeftRedLght   =  0x080000
    iReRightRedLght  =  0x100000
    iLeftBlinker  = iFrLeftBlinker  | iReLeftBlinker
    iRightBlinker = iFrRightBlinker | iReRightBlinker
    iLghtFrDown   = iFrLeftLghtDown | iFrRightLghtDown
    iLghtFrUp     = iFrLeftLghtUpL  | iFrLeftLghtUpR | \
                    iFrRightLghtUpL | iFrRightLghtUpR
    iLghtReDown   = iReLeftLghtDown | iReRightLghtDown
    iLghtReUp     = iReRightLghtUpR | iReRightLghtUpL | \
                    iReLeftLghtUpR  | iReLeftLghtUpL
    iWarning      = iLeftBlinker    | iRightBlinker
    iBrakes       = iLeftBrake      | iRightBrake
    iReRedLght    = iReLeftRedLght  | iReRightRedLght
    warning = leftBlinkers + rightBlinkers
    allLights = warning + lghtFrDown + lghtFrUp + \
                lghtReDown + lghtReUp + brakes + ReRedLght
    chaserFr = [ lghtFrDown[1], rightBlinkers[0] ] + lghtFrUp + \
               [ leftBlinkers[0], lghtFrDown[0] ]
    chaserRe = [ lghtReDown[0], leftBlinkers[1]] + lghtReUp + \
               [ rightBlinkers[1], lghtReDown[1] ]
    def animLights():
        beacon.on()
        for lght in allLights: lght.on()
        sleep(.75)
        for lght in allLights: lght.off()
        sleep(.2)
        for i in range(4):
            for lghtFr, lghtRe in zip(chaserFr, chaserRe):
                lghtFr.on()
                lghtRe.on()
                sleep(.225)
                lghtFr.off()
                lghtRe.off()
            for lght in brakes: lght.on()
            sleep(.225)
            for lght in brakes: lght.off()
        sleep(.2)
        sleep(.75)
        beacon.off()
    exitVal = 0
    MainOn = True
    exitFlag = False
    getdata = qIn.get
    wait4data = True
    T0 = time()
    Tend = 5
    ackn = False
    while MainOn:
        try:
            ret = getdata(wait4data)
        except Empty:
            ret = []
        except KeyboardInterrupt:
            ret = []
            exitFlag = True
            MainOn = False
        if ret: typ, msgs, proc = ret
        else: typ = ''
        if 'TCP' in typ:
            # ----------------------------------------------------- TCP
            typ2 = typ.split(':')[-1]
            if 'out' in typ2:
                eth.relaunch(proc)
            elif 'snt1' in typ2:
                print('\t-> {} to {}'.format(msgs, proc))
            elif 'snt0' in typ2:
                print('\t/!\ Fail sending {} to {}'.format(msgs, proc))
            elif typ2 in ['rcv1', 'rcv0']:
                # ----- aknowledge
                print('\t<- {} from {}'.format(msgs, proc))
                if exitFlag:
                    print('\t {} stopped'.format(proc))
                    if typ2 == 'rcv1':
                        MainOn = not all(eth.stop(proc))
                cmd, val = msgs.split('=')
                ackn = True
                if cmd == 'Anim':
                    if int(val) == 1:
                        animLights()
                        # ----- put back to what was in memory
                        j = 1
                        n = 0
                        for i in range(21):
                            if lights & j :
                                if n < 4: allLights[n].blink(.66, .33)
                                else:     allLights[n].on()
                            j <<= 1
                            n += 1
                elif cmd == 'LeftBlinker':
                    if int(val) == 1:
                        for lght in leftBlinkers: lght.blink(.66, .33)
                        lights |= iLeftBlinker
                    else:
                        for lght in leftBlinkers: lght.off()
                        lights &= ~iLeftBlinker
                elif cmd == 'RightBlinker':
                    if int(val) == 1:
                        for lght in rightBlinkers: lght.blink(.66, .33)
                        lights |= iRightBlinker
                    else:
                        for lght in rightBlinkers: lght.off()
                        lights &= ~iRightBlinker
                elif cmd == 'Beacon':
                    if int(val) == 1:
                        beacon.on()
                        lights |= iBeacon
                    else:
                        beacon.off()
                        lights &= ~iBeacon
                elif cmd == 'Brake':
                    if int(val) == 1:
                        lights |= iBrakes
                    else:
                        lights &= ~iBrakes
                elif cmd == 'LghtDown':
                    if int(val) == 1:
                        for lght in lghtFrDown + lghtReDown: lght.on()
                        lights |= (iLghtFrDown | iLghtReDown)
                    else:
                        for lght in lghtFrDown + lghtReDown: lght.off()
                        lights &= ~(iLghtFrDown | iLghtReDown)
                elif cmd == 'LghtFrDown':
                    if int(val) == 1:
                        for lght in lghtFrDown: lght.on()
                        lights |= iLghtFrDown
                    else:
                        for lght in lghtFrDown: lght.off()
                        lights &= ~iLghtFrDown
                elif cmd == 'LghtFrUp':
                    if int(val) == 1:
                        for lght in lghtFrUp: lght.on()
                        lights |= iLghtFrUp
                    else:
                        for lght in lghtFrUp: lght.off()
                        lights &= ~iLghtFrUp
                elif cmd == 'LghtReDown':
                    if int(val) == 1:
                        for lght in lghtReDown: lght.on()
                        lights |= iLghtReDown
                    else:
                        for lght in lghtReDown: lght.off()
                        lights &= ~iLghtReDown
                elif cmd == 'LghtReUp':
                    if int(val) == 1:
                        for lght in lghtReUp: lght.on()
                        lights |= iLghtReUp
                    else:
                        for lght in lghtReUp: lght.off()
                        lights &= ~iLghtReUp
                elif cmd == 'ReRedLght':
                    if int(val) == 1:
                        for lght in ReRedLght: lght.on()
                        lights |= iReRedLght
                    else:
                        for lght in ReRedLght: lght.off()
                        lights &= ~iReRedLght
                elif cmd == 'Warning':
                    if int(val) == 1:
                        for lght in warning: lght.blink(.66, .33)
                        lights |= iWarning
                    else:
                        for lght in warning: lght.off()
                        lights &= ~iWarning
                elif cmd == 'Exit':
                    # stop Rpi_INputs
                    exitVal = int(val)
                    exitFlag = True
                    wait4data = False
            elif 'rcv?' in typ2:
                print('\t ????? {} received from "{}"'.format(msgs, proc))
                ackn = False
        elif typ:
            print('\t/!\ unknown type : ', typ)
        if exitFlag:  MainOn = not (time() - T0 > Tend)
    qIn.cancel_join_thread()
    # ----------------------------------------------------------- close TCPLink
    eth.close()
    # -------------------------------------------------------------------- exit
    print('< {} [{}] <\n\n'.format(procName, strftime('%d/%m/%y %H:%M:%S')))
    exit(exitVal)
3.b/ Zen@Terra
This raspberry, at the driver's right side, reproduces the Michelin App "Zen@TerraRegistered" that consists of tuning the tires pressures depending on the coupled tooling and the rolling surface (road of field). The driver selects with a tactile screen the corresponding conditions of tooling/loads and rolling surface to (virtually here) adjust the pressure in the tires.
It's named RPi_Pressure as it manages the tire pressures ...
It uses the fonts: Caracteres L1.ttf, Michelin-Black_0.otf, Michelin-Bold_0.otf, Michelin-Light.otf, Michelin-Regular.otf, Michelin-SemiBold.otf.
tkinter manages the graphics and it consists to overlay (tk.Canvas.create_image), showing (state=tk.NORMAL) or hiding (state=tk.HIDDEN) images and/or texts (tk.Canvas.create_text) or other shapes (tk.Canvas.create_oval, tk.Canvas.create_arc).
Images in the img directory:
The main part (__main__) manages the TCP/IP link. It communicates with the graphic part (board) thanks to a queue (named setBoard).
The board scans every 40ms if some data are in this queue (in def wait4action).
The board can send info to the __main__ through another queue (qIn) which gather also the messages coming from TCP/IP.
The incoming data in qIn follows this format [type, msgs, process]
if type == 'TCP:...', the msgs comes from the TCP/IP link
if type == 'SUB', the msgs comes from board and is send to TCP/IP link (eth.sendTo), notably to send the new max speed reference.
Rpi_Pressure.py_______________________________________________________________________
""" RPi_Pressure
__version__ = '1.0'
__date__ = '27 Nov 2017'
import tkinter as tk
from time import time, sleep
from os import path
appRed = '#CC0000'
appBlue = '#006699'
appGreen = '#41B649'
appOrange = '#CC6600'
def nullFun(): return
class board():
    Main animation
    # ========================================================== initializing
    def __init__(self, debug, qIn, qOut, langs):
        # ======================= open graphic window, top screen, full screen
        fig = tk.Tk()
        if not debug: fig.overrideredirect(True)
        fig.lift()
        WxH = [1280, 800]
        fig.wm_attributes('-topmost', True)
        fig.geometry('{}x{}+0+0'.format(*WxH))
        fig.title('zen@Terra')
        fig.bind('q', self.Quit)
        fig.bind('Q', self.Quit)
        fig.bind('H', self.Hide)
        fig.bind('h', self.Hide)
        fig.bind('S', self.Show)
        fig.bind('s', self.Show)
        fig.bind('<Control-KeyPress-F>', self._toFr)
        fig.bind('<Control-KeyPress-E>', self._toEn)
        fig.bind('<Control-KeyPress-G>', self._toGe)
        fig.bind('<Control-KeyPress-R>', self._toRu)
        self.getData = qIn.get_nowait
        self.enterEmpty = qIn.empty
        self.putData = qOut.put_nowait
        # ----- attach a canvas to the window
        cnv = tk.Canvas(fig, bd=0, bg='white', highlightthickness=0, \
                       width=WxH[0], height=WxH[1])
        cnv.pack()
        # ----- to simplify the notations
        setText = cnv.create_text
        setImage = cnv.create_image
        setCircle = cnv.create_oval
        setArc = cnv.create_arc
        self.setConfig = cnv.itemconfig
        self.getConfig = cnv.itemcget
        self.setCoords = cnv.coords
        self.getCoords = cnv.coords
        self.wbind = cnv.tag_bind
        self.getTag = cnv.find_withtag
        self.move = cnv.move
        curLang = langs['LANG']['curlang']
        self.curLang = curLang
        self.labels = {}
        self.langs = langs
        # ----- fonts
        fontButton = ('Michelin', 12, 'bold')
        fontLabel = ('Michelin', 17, 'bold')
        fontPres = ('Michelin', 22, 'bold')
        fontTimer = ('Michelin', 22)
        fontLabelSmall = ('Michelin', 9, 'bold')
        fontSpeed = ('CARACTERES L1', 40)
        # ----- Directory containing the pictures
        imgDir = '../img'
        if not path.exists(imgDir): imgDir = imgDir.replace('..','.')
        def imgLoadTk(fn): return tk.PhotoImage(file=path.join(imgDir,fn))
        # =================================== load and display background image
        self.bckImgTk = imgLoadTk('background.png')
        self.BckImg = setImage(640, 400, image=self.bckImgTk)
        # ===================================================== top view button
        self.topviewTk = imgLoadTk('top_view.png')
        # setImage(1280-50-5, 67/2, anchor=tk.E, image=self.topviewTk)
        tk.Button(cnv, bd=8, bg='#6699CC', image= self.topviewTk, \
                  anchor=tk.CENTER, \
                  command=self.toggleTopView, height=42, width=42)\
                       .place(x=1280-5, y=67/2, anchor=tk.E)
        self.langButTxt = tk.StringVar()
        self.langButTxt.set(curLang[:2])
        # ======================================================= lang button
        self.langBut=tk.Button(cnv, textvariable=self.langButTxt,  \
                 bd=1, relief=tk.FLAT, command=self.nextLang, \
                  bg='#6699CC', font=fontLabelSmall)
        self.langBut.place(x=1280-75, y=67/2-6, anchor=tk.E)
         # ===== load tractor alone: tractor =========================== TRACTOR
        self.tractorAloneTk = imgLoadTk('tractor.png')
        self.tractorAlone = setImage(495, 428, image=self.tractorAloneTk)
        # ----- load the tractor + trailer (3rdWhl)
        self.tractorTrailerk = imgLoadTk('tractor_trailer.png')
        self.tractorTrailer = setImage(513, 428, image=self.tractorTrailerk,\
                                           state=tk.HIDDEN)
        self.wheelTk = {}
        self.wheel = {}
        self.nbAxles = 2
        self.curAxle = 0
        self.curWheelClr = ['Green']*3
        self.selAxle = {na:[] for na in range(3)}
        self.wshift = 152
        # -------------------- pressure probe, check sign, sandglass positions
        midfx = 374
        midfy = 546
        midrx = 655
        midry = 533
        midtx = 768 + self.wshift
        midty = midfy
        # ----- wheels, check, sandglass positions
        xys = [[midfx, midfy],[midrx, midry],[midtx, midty]]
        # -------------------------------------------------------------- WHEELS
        for clr in ['Blue', 'Orange', 'Green', 'Red']:
            tag = ('whl' + clr, 'toShift')
            clrl = clr.lower()
            self.wheelTk[clr] = []
            self.wheel[clr] = []
            for i, fn in enumerate(['', 'rear_', '']):
                self.wheelTk[clr].append(imgLoadTk(fn+'wheel_{}.png'.format(clrl)))
                tagi = ('whl{}{}'.format(i, clr), *tag)
                self.wheel[clr].append(\
                    setImage(*xys[i], state=tk.HIDDEN, tag=tagi, \
                                 image=self.wheelTk[clr][-1]))
                self.selAxle[i].append(self.wheel[clr][-1])
        self.wShow(self.wheel['Green'][:self.nbAxles])
        # ----- pressure probe positions
        xyp = [[x, y+z] for [x,y],z in zip(xys,[50, 59, 50])]
        # ------------------------------- displays
        ptfx = 404
        ptfy = 656
        ptrx = 687
        ptry = ptfy
        pttx = 796 + self.wshift
        ptty = ptfy
        # ----- 'real' pressures
        xyd = [[ptfx, ptfy],[ptrx, ptry],[pttx, ptty]]
        # ----- target pressures
        xyt = [[x+5, y] for x,y in xyd]
        # ----- manometer
        xym = [[x-20, y+15] for x,y in xyd]
        tagi = tag
        wTargetPres = []
        self.targetPres = [1.8]*3
        self.curPres = self.targetPres.copy()
        self.prevPres = self.targetPres.copy()
        self.oriTargetPres = self.targetPres.copy()
        self.xflTimer = [None]*3
        self.curPresClr = [appGreen]*3
        # ------------------------------- PRESSURE PROBE, CHECK SIGN, SANDGLASS
        tag = 'toShift'
        self.mesPresTk = []
        self.checkTk = imgLoadTk('check.png')
        self.check = []
        self.sandglassTk = imgLoadTk('sandglass.png')
        self.sandglass = []
        self.manoTk = imgLoadTk('mano.png')
        self.mano = []
        wCurPres = []
        tagi = tag
        state = tk.NORMAL
        for i, fn in enumerate(['Fr', 'Re', 'Fr' ]):
            self.mesPresTk.append(imgLoadTk('mesPres_{}.png'.format(fn)))
            if i == 2:
                tagi = ('3rdWhl', tag)
                state = tk.HIDDEN
            # ----- pressure probes
            setImage(*xyp[i], image=self.mesPresTk[-1], anchor=tk.NW, \
                     state=state, tag=tagi)
            # ----- check icones
            self.check.append(setImage(*xys[i], anchor=tk.CENTER, state=state, \
                                    image=self.checkTk, tag=tagi))
            wTargetPres.append(setText(*xyt[i], text='1.8', \
                                            fill=appGreen, state=state, \
                                    anchor=tk.SW, font=fontPres, tag=tagi))
            if i == 2: tagi = ('3rdWhl+', tag)
            # ----- sandglass
            self.sandglass.append(setImage(*xys[i], image=self.sandglassTk, \
                                           state=tk.HIDDEN, \
                                           anchor=tk.CENTER, tag=tagi))
            wCurPres.append(setText(*xyd[i], text='1.8', fill=appOrange, \
                                         anchor=tk.NW, font=fontPres))
            # ----- manometers
            self.mano.append(setImage(*xym[i], image=self.manoTk, tag=tagi, \
                             anchor=tk.E, state=tk.HIDDEN))
        # -------------------------------------------------- TOOLS (PRESSURES)
        self.variableLoadList = ['DIRECTDRILL', 'TRAILER', 'SPREADER' , \
                                 'DRILL']
        tool2img = { 'TRACTOR': 'nothing',  'CULTIVATOR': 'cultivator', \
                     'DIRECTDRILL': 'direct_drill',\
                     'TRAILER': 'trailer', 'PLOUGH': 'plough',\
                     'DRILL': 'drill', 'SPREADER':'spreader' }
        self.toolPressures = {}
        self.toolSpeed = {}
        for i, key in enumerate(tool2img.keys()):
            if key in self.variableLoadList:
                self.toolPressures[key] = {}
                self.toolSpeed[key] = {}
                for mode in ['road', 'field', 'boost']:
                    self.toolPressures[key][mode] = []
                    self.toolSpeed[key][mode] = []
                    for load in [0.0, 0.5, 1.0]:
                        pressures, speed = (langs[key]['_{}@{:.1f}'.format(mode, load)]).split('@')
                        self.toolPressures[key][mode].append(\
                                        eval(pressures.replace('-', '1.2')))
                        self.toolSpeed[key][mode].append(int(speed))
            else:
                    pressures, speed = (langs[key]['_{}@-'.format(mode)]).split('@')
                    self.toolPressures[key][mode] = [\
                                               eval(pressures.replace('-', '1.2'))]
                    self.toolSpeed[key][mode] = [int(speed)]
        self.xflatingTool = {na:[self.sandglass[na], wCurPres[na], \
                                self.mano[na]] for na in range(3)}
        # --------------------------------------------------------- TOOLS (draw)
        self.toolsTk = {}
        for key, img in tool2img.items(): \
            self.toolsTk[key] = imgLoadTk(img + '.png')
        self.setImage = setImage
        self.setText = setText
        self.fontButton = fontButton
        self.toolInd = 0
        self.toolList = {i:key for i, key in enumerate(tool2img.keys())}
        self.indTool = {key:i for i, key in self.toolList.items()}
        self.curTool = self.toolList[self.toolInd]
        self.frontMassTool = ['DIRECTDRILL', 'PLOUGH']
        self.load = 0
        self.mode = 'road'
        # ===== load large button 1 ================================ [BUTTON 1]
        tag = 'Tooling'
        # ----- label 1
        self.labels['TOOLING'] = setText(194+5, 82, font=fontLabel, \
                                            text=langs['TOOLING'][curLang],
                                              anchor=tk.NW)
        # ----- shadow
        self.but1sTk = imgLoadTk('big_shadow.png')
        but1s = setImage(194+4, 114+5, image=self.but1sTk, anchor=tk.NW)
        def wbind(ws, tag, wc, but, action):
            def handler(event, self=self, ws=ws, tag=tag, wc=wc, action=action):
                return self.pressAction(event, ws, tag, wc, but, action)
            self.wbind(wc, '<Button-1>', handler)
        # ----- button
        self.but1Tk = imgLoadTk('big_but.png')
        but1 = setImage(194, 114, image=self.but1Tk, tag=tag, anchor=tk.NW)
        wbind(but1s, tag, but1, None, self.selTooling)
        # ----- image in button
        self.tractorButTk = imgLoadTk('tractor_but.png')
        tractorBut = setImage(194+222/2, 114+97-29, image=self.tractorButTk, \
                                        tag=tag, anchor=tk.SE)
        wbind(but1s, tag, tractorBut, None, self.selTooling)
        # ----- front mass
        self.frontMassTk = imgLoadTk('front_mass.png')
        self.frontMass = self.setImage(194+222/2-79+3, 114+97/2-3, \
                                 image=self.frontMassTk, state=tk.HIDDEN, \
                                        tag=tag, anchor=tk.E)
        wbind(but1s, tag, self.frontMass, None, self.selTooling)
        # ----- tool attached to tractor
        self.toolBut = self.setImage(194+222/2, 114+97-29, \
                                 image=self.toolsTk[self.curTool], \
                                        tag=tag, anchor=tk.SW)
        wbind(but1s, tag, self.toolBut, None, self.selTooling)
        # ----- text in button
        self.txtBut1 = self.setText(194+222/2, 114+92, anchor=tk.S, \
                     tag=tag, text=self.langs[self.curTool][self.curLang], \
                               font=self.fontButton )
        wbind(but1s, tag, self.txtBut1, None, self.selTooling)
        # -------------------------------------------------------- sub button 1
        self.subbut1Tks = imgLoadTk('small_shadow.png')
        self.subbut1Tkg = imgLoadTk('small_but_grey.png')
        self.subbut1Tky = imgLoadTk('small_but_yellow.png')
        self.subbut1Tki = []
        self.subbut1y = []
        tag = 'subequip'
        for i, fn in enumerate(['empty', 'half', 'full' ]):
            tag2 = 'but1#{}'.format(i)
            taga = (tag, tag2)
            j = 84*i
            # ----- shadow
            subbut1s = setImage(194+4+j, 225+5, anchor=tk.NW, \
                                tag=tag, state=tk.HIDDEN, image=self.subbut1Tks)
            # ----- grey background
            subbut1b = setImage(194+j, 225, anchor=tk.NW, tag=taga, \
                                state=tk.HIDDEN, image=self.subbut1Tkg )
            wbind(subbut1s, tag2, subbut1b, i, self.selToolingSub)
            # ----- yellow background
            self.subbut1y.append(\
                             state=tk.HIDDEN, image=self.subbut1Tky ))
            wbind(subbut1s, tag2, self.subbut1y[-1], i, self.selToolingSub)
            # ----- image
            self.subbut1Tki.append(imgLoadTk(fn+'.png'))
            subbut1i = setImage(194+j+53/2, 225+52/2, anchor=tk.CENTER, tag=tag, \
                             state=tk.HIDDEN, image=self.subbut1Tki[-1] )
            wbind(subbut1s, tag2, subbut1i, i, self.selToolingSub)
        # ===== load large button 2 ================================ [BUTTON 2]
        tag = 'Surf'
        self.field = False
        # ----- label 2
        self.labels['USAGE'] = setText(610+5, 82, font=fontLabel, \
                                         text=langs['USAGE'][curLang], \
                                           anchor=tk.NW)
        # ----- shadow
        but2s = setImage(610+4, 114+5, image=self.but1sTk, anchor=tk.NW)
        # ----- button
        but2 = setImage(610, 114, image=self.but1Tk, \
        wbind(but2s, tag, but2, None, self.toggleSurf)
        # ----- image in button: Field
        self.fieldButTk = imgLoadTk('field.png')
        fieldBut = setImage(610+222/2, 114+10, image=self.fieldButTk, \
                                  tag=(tag, 'field'), state=tk.HIDDEN, \
                                     anchor=tk.N)
        wbind(but2s, tag, fieldBut, None, self.toggleSurf)
        # ----- image in button: Road
        self.roadButTk = imgLoadTk('road.png')
        roadBut = setImage(610+222/2, 114+10, image=self.roadButTk, \
                                     tag=(tag, 'road'), anchor=tk.N)
        wbind(but2s, tag, roadBut, None, self.toggleSurf)
        # ----- text in button: field
        txtBut2f = setText(610+222/2, 114+92, anchor=tk.S, \
                               state=tk.HIDDEN, tag=(tag, 'field'), \
                                   text=langs['FIELD'][curLang], \
                                       font=fontButton )
        self.labels['FIELD'] = txtBut2f
        wbind(but2s, tag, txtBut2f, None, self.toggleSurf)
        # ----- text in button: road
        txtBut2r = setText(610+222/2, 114+92, anchor=tk.S, \
                               tag=(tag, 'road'), \
                                   text=langs['ROAD'][curLang], \
                                       font=fontButton )
        self.labels['ROAD'] = txtBut2r
        wbind(but2s, tag, txtBut2r, None, self.toggleSurf)
        # -------------------------------------------------------- sub button 2
        self.subbut2Tki = []
        self.subbut2y = []
        tag = 'field'
        for i, fn in enumerate(['bank', 'flat']):
            j = 91*i
            tag2 = 'but2#{}'.format(i)
            taga = (tag, tag2)
            # ----- shadow
            subbut2s = setImage(650+4+j, 225+5, anchor=tk.NW, state=tk.HIDDEN, \
                             tag=tag, image=self.subbut1Tks )
            subbut2b = setImage(650+j, 225, anchor=tk.NW, state=tk.HIDDEN, \
                             tag=taga, image=self.subbut1Tkg )
            wbind(subbut2s, tag2, subbut2b, i, self.surfSub)
            self.subbut2y.append(\
                             tag=taga, image=self.subbut1Tky ))
            wbind(subbut2s, tag2, self.subbut2y[-1], i, self.surfSub)
            # ----- image
            self.subbut2Tki.append(imgLoadTk(fn+'.png'))
            subbut2i = setImage(650+j+53/2, 225+52/2, anchor=tk.CENTER, state=tk.HIDDEN, \
                             tag=taga, image=self.subbut2Tki[-1] )
            wbind(subbut2s, tag2, subbut2i, i, self.surfSub)
        self.bankFlag = False
        # ===== load button MANUAL ============================ [BUTTON MANUAL]
        tag = 'Manual'
        self.manualOn = False
        # ----- shadow
        self.rightButtTks = imgLoadTk('medium_but_shadow.png')
        manualButs = setImage(1098+4, 88+5, image=self.rightButtTks, \
                                     anchor=tk.NW)
        # ----- normal button
        self.manualButtTk = imgLoadTk('manual_but_off.png')
        self.manualBut = setImage(1098, 88, image=self.manualButtTk, \
        wbind(manualButs, tag, self.manualBut, None, self.toggleManualMode)
        # ----- blue button
        self.manualButtTkb = imgLoadTk('manual_but_on.png')
        self.manualButBlue = setImage(1098, 88, image=self.manualButtTkb, \
                                         tag=tag, state=tk.HIDDEN, anchor=tk.NW)
        wbind(manualButs, tag, self.manualButBlue, None, self.toggleManualMode)
        txtButManual = setText(1098+108/2, 88+78-5, anchor=tk.S, \
                                        text=langs['MANUAL'][curLang], \
                                    font=fontLabelSmall, tag=tag )
        self.labels['MANUAL'] = txtButManual
        wbind(manualButs, tag, txtButManual, None, self.toggleManualMode)
        # ===== load button - ====================================== [BUTTON -]
        tag = ('submanual', '-')
        # ----- shadow
        self.plusminusButtTks = imgLoadTk('plus_minus_shadow.png')
        minusButs = setImage(235+4, 742+5, image=self.plusminusButtTks, \
                                state=tk.HIDDEN, tag=tag, anchor=tk.CENTER)
        self.minusButtTk = imgLoadTk('minus_but.png')
        minusBut = setImage(235, 742, image=self.minusButtTk, \
        wbind(minusButs, '-', minusBut, None, self.minusButFun)
        # ===== load button Axle ================================ [BUTTON AXLE]
        tag = ('submanual', 'axle')
        # ----- shadow
        self.axleButtTks = imgLoadTk('axle_shadow.png')
        axleButs = setImage(513+4, 742+5, image=self.axleButtTks, \
                                     state=tk.HIDDEN, anchor=tk.CENTER, tag=tag)
        self.axleButtTk = imgLoadTk('axle_but.png')
        axleBut = setImage(513, 742, image=self.axleButtTk, \
        wbind(axleButs, 'axle', axleBut, None, self.nextAxle)
        txtButAxle = setText(513, 742+61/2-5, anchor=tk.S, \
                                     state=tk.HIDDEN,  font=fontLabelSmall, \
                                         tag=tag, text=langs['AXLE'][curLang])
        self.labels['AXLE'] = txtButAxle
        wbind(axleButs, 'axle', txtButAxle, None, self.nextAxle)
        self.lastAxle = 1
        # ===== load button + ====================================== [BUTTON +]
        tag = ('submanual', '+')
        # ----- shadow
        plusButs = setImage(790+4, 742+5, image=self.plusminusButtTks, \
        self.plusButtTk = imgLoadTk('plus_but.png')
        plusBut = setImage(790, 742, image=self.plusButtTk, \
        wbind(plusButs, '+', plusBut, None, self.plusButFun)
        # ===== load button BOOST ============================== [BUTTON BOOST]
        tag = 'Boost'
        self.boostOn = False
        boostButs = setImage(1098+4, 189+5, image=self.rightButtTks, \
                                  state=tk.HIDDEN, tag=tag, anchor=tk.NW)
        self.boostButtTk = imgLoadTk('boost_but_off.png')
        self.boostBut = setImage(1098, 189, image=self.boostButtTk, \
        wbind(boostButs, tag, self.boostBut, None, self.toggleBoostMode)
        # ----- red button
        self.boostButtTkr = imgLoadTk('boost_but_on.png')
        self.boostButRed = setImage(1098, 189, image=self.boostButtTkr, \
        wbind(boostButs, tag, self.boostButRed, None, self.toggleBoostMode)
        txtButBoost = setText(1098+108/2, 189+78-7, anchor=tk.S, \
                                          tag=tag, text=langs['BOOST'][curLang])
        self.labels['BOOST'] = txtButBoost
        wbind(boostButs, tag, txtButBoost, None, self.toggleBoostMode)
        # --------------------------------------------------------- triple warn
        tag = 'subBoost'
        self.triplwarnw = []
        ux, uy, d = 1073, 331, 44
        dx, dy, r = ux+d, uy+d, round(d/2)
        for i in range(3):
            j = i*58
            self.triplwarnw.append(\
                setCircle(ux+j, uy, dx+j, dy, outline='black', width=3, \
                              tag=tag, state=tk.HIDDEN))
        self.wFill([self.triplwarnw[0]], appRed)
        # --------------------------------------------------------- Boost Timer
        ux, uy, d = 1073, 416, 160
        self.boostTimer = [\
            setArc(ux, uy, dx, dy, width=0, fill=appRed, tag=tag, \
                   start=90, style=tk.PIESLICE, state=tk.HIDDEN, extent=0)]
        dr = 15
        self.boostTimer.append(\
                setCircle(ux+dr, uy+dr, dx-dr, dy-dr, outline='white', width=5, \
                              fill='black', tag=tag, state=tk.HIDDEN))
            setText(ux+r, uy+r, text='03:00', fill='white', font=fontTimer, \
        self.boostTimerTimes = 0
        self.boostTime = 180
        self.refreshTimerDisplay()
        # ----- speed indicator ---------------------------------------- SPEED
        ux, uy, d = 1083, 348, 141
        tag = 'Speed'
        setCircle(ux, uy, dx, dy, tag=tag, outline='black', width=4)
        dr = 3
        setCircle(ux+dr, uy+dr, dx-dr, dy-dr, tag=tag, outline='white', \
                          fill=appRed, width=2)
        dr = 27
        setCircle(ux+dr, uy+dr, dx-dr, dy-dr, tag=tag,  outline=None, \
                          fill='white', width=0)
        self.speedvalw = setText(ux+r, uy+r, text='35', font=fontSpeed, \
                                 tag=tag)
        # ========================================================== TOP VIEW 1
        self.topViewFlag = -1
        self.topview1Tk = imgLoadTk('topview_tractor.png')
        self.topview = [setImage(0, 294, anchor=tk.NW, state=tk.HIDDEN, \
                             image=self.topview1Tk )]
        # ========================================================== TOP VIEW 2
        self.topview2Tk = imgLoadTk('topview_tractor_trailer.png')
        self.topview.append(setImage(0, 294, anchor=tk.NW, state=tk.HIDDEN, \
                             image=self.topview2Tk ))
        tag = 'topview'
        ptx = [190, 473, 739]
        pty = [y+294 for y in [48, 457]]
        wTargetPresTV = {}
        wCurPresTV = {}
        self.manoTV = {}
        tagi = tag
        for i, x in enumerate(ptx):
            wTargetPresTV[i] = []
            wCurPresTV[i] = []
            self.manoTV[i] = []
            for j, y in enumerate(pty):
                if i == 2:
                    tagi = ('3rdWhlTV', tag)
                    state = tk.HIDDEN
                wTargetPresTV[i].append(setText(x+5*j, y+2, text='1.8', \
                                           anchor= j and tk.SW or tk.NW, \
                if i == 2: tagi = ('3rdWhlTV+', tag)
                wCurPresTV[i].append(setText(x+5*(j==0), y+2, text='1.8', fill=appOrange, \
                                             anchor= j and tk.NW or tk.SW, \
                                               font=fontPres))
                # ----- manometers
                self.manoTV[i].append(setImage(x-20, y-7+21*j, image=self.manoTk, \
                                            tag=tagi, \
        self.topViewOn = False
        self.topViewMoved = False
        self.topViewPrevAxle = 3
        self.xflatingToolTV = {na:[*wCurPresTV[na], \
                                   *self.manoTV[na]] for na in range(3)}
        self.wTargetPresAx = []
        self.wTargetPresAll = []
        self.wCurPresAx = []
        for i in range(3):
            self.wTargetPresAx.append([wTargetPres[i], \
                                            *wTargetPresTV[i]])
            self.wTargetPresAll += self.wTargetPresAx[-1]
            self.wCurPresAx.append([wCurPres[i], *wCurPresTV[i]])
        # ------------------------------------- some variable to save or to add
        self.xflateOn = [False]*3
        self.setTimer = fig.after
        self.stopTimer = fig.after_cancel
        self.fig = fig
        self.setTimer(10, self.wait4action)
        self.setPresSpeed()
        print('  >> mainBoard: On')
        self.fig.mainloop()
    # ======================================================= widgets management
    # -------------------------------------------------------- general functions
    def pressAction(self, event, ws, tag, wc, but, action):
        """ press button action:    remove the shadow (ws)
                                    move the image down (tag)
                                    extra widget to hanlde (but)
                                    set the action after release (action)
        self.wHide([ws])
        self.move(tag, 4, 4)
        def handler(event, self=self, \
                        ws=ws, tag=tag, wc=wc, but=but, action=action):
            return self.releaseAction(event, ws, tag, wc, but, action)
        self.wbind(wc, '<ButtonRelease-1>', handler)
    def releaseAction(self, event, ws, tag, wc, but, action):
        """ release button action:    display the shadow (ws)
                                      move the image up (tag)
        self.move(tag, -4, -4)
        self.wShow([ws])
        if but is None: action()
        else:           action(ws, but)
    def setSpeed(self, v):
        """ Display the speed in the roadsign
        self.curSpeed = v
        self.setConfig(self.speedvalw, text='{:d}'.format(v))
    def wHide(self, lst):
        """ hide the widgets in the passed list
        for tag in lst: self.setConfig(tag, state=tk.HIDDEN)
    def wShow(self, lst):
        """ show the widgets in the passed list
        for tag in lst: self.setConfig(tag, state=tk.NORMAL)
    def wFill(self, lst, clr):
        """ Fill the shape of the widgets in the passed list
        for tag in lst: self.setConfig(tag, fill=clr)
    def wGetColor(self, w):
        return self.getConfig(w, 'fill')
    def refreshTimerDisplay(self):
        """ Refresh the timer display
        self.setConfig(self.boostTimer[0], extent=-2*self.boostTime)
        self.setConfig(self.boostTimer[2], text='{:02d}:{:02d}'\
                       .format(*divmod(self.boostTime, 60)))
    def setTargetPressure(self, na):
        """ Display the target pressure of the axle #na
        txt = '{:.1f}'.format(self.targetPres[na])
        for w in self.wTargetPresAx[na]: self.setConfig(w, text=txt)
    def setCurPressure(self, na):
        """ Display the current pressure of the axle #na
        txt = '{:.1f}'.format(self.curPres[na])
        for w in self.wCurPresAx[na]: self.setConfig(w, text=txt)
    def _toFr(self, event): self.translate('fr')
    def _toEn(self, event): self.translate('en')
    def _toGe(self, event): self.translate('ge')
    def _toRu(self, event): self.translate('ru')
    def nextLang(self):
        Langs = ['En', 'Fr', 'Ge', 'Ru']
        indx = Langs.index(self.curLang.title()) + 1
        if indx >= len(Langs) : indx=0
        self.translate(Langs[indx])
    def translate(self, ln):
        """ translate the labels
        for key, w in self.labels.items():
            self.setConfig(w, text=self.langs[key][ln])
        self.setConfig(self.txtBut1, text=self.langs[self.curTool][ln])
        self.curLang = ln
        self.langButTxt.set(ln[:2])
    # ------------------------------------------------------------------ But 1
    def selTooling(self):
        self.toolInd += 1
        if self.toolInd >= len(self.toolList): self.toolInd = 0
        self.setTool()
    def selToolingSub(self, ws, but):
        self.wHide(self.subbut1y)
        self.wShow([ws, self.subbut1y[but]])
        self.load = but
        self.setPresSpeed()
    def setTool(self):
        """ set the tool attached to but1
        # ----- change image of tool
        self.setConfig(self.toolBut, image=self.toolsTk[self.curTool])
        self.load = 0
        # ----- front mass or not
        if self.curTool in self.frontMassTool:
            self.wShow([self.frontMass])
        else:
            self.wHide([self.frontMass])
        self.setConfig(self.txtBut1, \
                       text=self.langs[self.curTool][self.curLang])
        # ----- display or not the load
        if self.curTool in self.variableLoadList:
            self.wShow(['subequip'])
        else:
            self.wHide(['subequip'])
        # ----- if 3rdWhl : image
        if 'TRAILER' in self.curTool:
            self.wHide([self.tractorAlone, *self.selAxle[2]])
            self.wShow([self.tractorTrailer, '3rdWhl', 'whl2Green'])
            if self.nbAxles == 2: self.move('toShift', -self.wshift, 0)
            self.nbAxles = 3
            self.curPresClr[2] = appGreen
        else:
            self.wShow([self.tractorAlone])
            self.wHide([self.tractorTrailer, '3rdWhl', '3rdWhl+', \
                            *self.selAxle[2]])
            if self.nbAxles == 3: self.move('toShift', self.wshift, 0)
            self.nbAxles = 2
        self.setPresSpeed(not self.topViewOn)
        if self.topViewOn and self.topViewPrevAxle != self.nbAxles:
            self.toggleTopView(True)
    def setPresSpeed(self, refreshPres=True, saved=None):
        self.oriTargetPres = self.toolPressures[self.curTool][self.mode][self.load]
        Vref = self.toolSpeed[self.curTool][self.mode][self.load]
        self.setSpeed(Vref)
        if saved is None:
            self.targetPres = self.oriTargetPres.copy()
        else:
            self.targetPres = saved
        if refreshPres: self.manPress()
        self.putData(['SUB', 'Vref={}'.format(Vref), 'Rpi_Disp'])
    # ------------------------------------------------------------------ But 2
    def toggleSurf(self):
        # ----- no action if boost on
        if not self.boostOn:
            if self.field:
                # ----- field set -> set ROAD
                self.wHide(['field', 'Boost'])
                self.wShow(['road'])
                self.mode = 'road'
            else:
                # ----- road set -> set FIELD
                self.wShow(['field', 'Boost'])
                self.wHide(['road', *self.subbut2y, self.boostButRed])
                self.mode = 'field'
            # ----- toggle value
            self.field = not self.field
            self.setPresSpeed()
    def surfSub(self, ws, but):
        """ Sub Button 2 [but] released (angle / flat)
        self.wHide(self.subbut2y)
        self.wShow([ws, self.subbut2y[but]])
        if but:
            if self.bankFlag:
                self.oriTargetPres = [round(v-0.4, 1) \
                                          for v in self.oriTargetPres]
        else:
            if not self.bankFlag:
                self.oriTargetPres = [round(v+0.4, 1) \
                self.bankFlag = True
        if self.targetPres != self.oriTargetPres:
            self.manPress()
    # ----------------------------------------------------------------- MANUAL
    def toggleManualMode(self):
        # ----- boost on not on
            if self.manualOn:
                # ----- Manual Off
                self.wShow([self.manualBut, \
                            *self.wheel['Green'][:self.nbAxles]])
                self.wHide([self.manualButBlue, 'submanual', 'whlBlue'])
                self.wFill(self.wTargetPresAll, appGreen)
                self.targetPres = self.prevPresM.copy()
                self.manPress()
            else:
                # ----- Manual On
                self.manualOn = True
                self.wHide([self.manualBut])
                self.wShow([self.manualButBlue, 'submanual'])
                self.prevPresM = self.oriTargetPres.copy()
                self.curAxle = self.nbAxles
                self.nextAxle()
    def minusButFun(self):
            self.targetPres[self.curAxle] = \
                max(round(self.targetPres[self.curAxle] - 0.1, 1), 0.4)
            self.manPress()
    # ------------------------------------------------------------------ [AXLE]
    def nextAxle(self):
            self.lastAxle = self.curAxle
            self.curAxle += 1
            self.xflate(self.lastAxle)
            if self.curAxle >= self.nbAxles: self.curAxle = 0
            self.wFill(self.wTargetPresAx[self.curAxle], appBlue)
            self.wHide([*self.selAxle[self.curAxle]])
            self.wShow([self.wheel['Blue'][self.curAxle]])
            self.curPresClr[self.curAxle] = appBlue
            self.curWheelClr[self.curAxle] = 'Blue'
    def plusButFun(self):
                min(round(self.targetPres[self.curAxle] + 0.1, 1), 3.0)
            self.manPress()
    # ------------------------------------------------------------------- BOOST
    def toggleBoostMode(self):
        if self.boostOn:
            # ----- Boost Off
            self.wHide([self.boostButRed, 'subBoost', 'whlRed'])
            self.wShow([self.boostBut])
            if self.manualOn: self.wShow(['submanual'])
            self.curWheelClr = self.prevWheelClr.copy()
            for na in range(self.nbAxles):
                self.wShow([self.wheel[self.curWheelClr[na]][na]])
            self.curPresClr = self.prevPresClr.copy()
            for na, clr in enumerate(self.curPresClr):
                self.wFill(self.wTargetPresAx[na], clr)
            self.move('Speed', 0, -267)
            self.mode = 'field'
            mem = self.prevPresB.copy()
        else:
            if self.manualOn: self.wHide(['submanual'])
            # ----- Boost On
            self.boostOn = True
            self.wHide([self.boostBut, 'whlGreen', 'whlBlue'])
            self.wShow([self.boostButRed, 'subBoost', \
                        *self.wheel['Red'][:self.nbAxles]])
            self.wFill(self.wTargetPresAll, appRed)
            self.prevWheelClr = self.curWheelClr.copy()
            self.curWheelClr = ['Red']*3
            self.prevPresClr = self.curPresClr.copy()
            self.curPresClr = [appRed]*3
            self.move('Speed', 0, 267)
            self.mode = 'boost'
            self.prevPresB = self.targetPres.copy()
            mem = None
            self.setTimer(1000, self.boostDelay)
        self.setPresSpeed(saved=mem)
    # ============================================================== ANIMATIONS
    # --------------------------------------------------------------- Pressures
    def manPress(self, redraw=False):
            self.setCurPressure(na)
            self.setTargetPressure(na)
            if self.curPres[na] != self.targetPres[na] or redraw:
                if appGreen in self.curPresClr[na]:
                    self.wFill(self.wTargetPresAx[na], 'black')
                if not self.xflateOn[na]:
                    if self.topViewOn: self.wShow(self.xflatingToolTV[na])
                    self.wShow(self.xflatingTool[na])
                        self.wHide([self.wheel[self.curWheelClr[na]][na]])
                        self.wShow([self.wheel['Orange'][na]])
                    self.xflateOn[na] = True
                if self.xflTimer[na] is not None:
                    self.stopTimer(self.xflTimer[na])
                self.xflTimer[na] = self.setTimer(1000, self.xflate, na)
    def xflate(self, na):
        if na < self.nbAxles:
            if self.curPres[na] == self.targetPres[na]:
                if self.topViewOn: self.wHide(self.xflatingToolTV[na])
                self.wHide([*self.xflatingTool[na], self.wheel['Orange'][na]])
                if 'Blue' in self.curWheelClr[na]:
                    if na != self.curAxle:
                        self.curWheelClr[na] = 'Green'
                        if self.curPres[na] == self.oriTargetPres[na]:
                            self.curPresClr[na] = appGreen
                self.wFill(self.wTargetPresAx[na], self.curPresClr[na])
                self.xflateOn[na] = False
            else:
                if self.curPres[na] > self.targetPres[na]:
                    self.curPres[na] = round(self.curPres[na] - 0.1, 1)
                else:
                    self.curPres[na] = round(self.curPres[na] + 0.1, 1)
    # -------------------------------------------------------------------- Boost
    def boostDelay(self):
        self.boostTime -= 1
        if not self.boostTime:
            self.boostTimerTimes += 1
            if self.boostTimerTimes > 2: self.boostTimerTimes = 0
            self.wFill([self.triplwarnw[self.boostTimerTimes]], appRed)
            self.wFill(self.triplwarnw[1:], '')
            self.toggleBoostMode()
        elif self.boostOn: self.setTimer(1000, self.boostDelay)
    # ------------------------------------------------------------------ top view
    def toggleTopView(self, redraw=False):
        if self.topViewFlag < 0 or redraw:
            self.topViewFlag = self.nbAxles - 2
            self.wShow([self.topview[self.topViewFlag], 'topview'])
            if self.nbAxles == 2 :
                self.wHide([self.topview[1], '3rdWhlTV', '3rdWhlTV+'])
                if not self.topViewMoved: self.move('topview', 161, 0)
                self.topViewMoved = True
            else:
                self.wShow([self.topview[0], '3rdWhlTV', '3rdWhlTV+'])
                if self.topViewMoved: self.move('topview', -161, 0)
            self.topViewPrevAxle = self.nbAxles
            self.topViewOn = True
        else:
            self.wHide([*self.topview, 'topview'])
        self.manPress(True)
    # ================================================================== ACTIONS
    def wait4action(self):
        loop = True
        while not self.enterEmpty():
            ret = self.getData()
            cmd, val = ret
            if ('Tool' in cmd) and (val in self.indTool):
                # ----- 'Tool=TRAILER'
                self.toolInd = self.indTool[val]
                self.curTool = val
                self.setTool()
            elif 'Lang' in cmd:
                # ----- 'Lang=En'
                self.translate(val[:2].title())
            elif ('Surf' in cmd) and (('field' in val) != self.field):
                # ----- 'Surf=road'
                self.toggleSurf()
            elif ('Manual' in cmd) and (bool(int(val)) != self.manualOn):
                # ----- 'Manual=1'
                self.toggleManualMode()
            elif ('Boost' in cmd) and (bool(int(val)) != self.boostOn):
                # ----- 'Boost=1'
            elif 'Pressures' in cmd:
                # ----- 'Pressures=[.8, .8, .8]'
                self.targetPres = eval(val)
                self.manPres()
            elif 'Exit' in cmd:
                loop = False
                break
            self.fig.update()
        if loop: self.setTimer(40, self.wait4action)
        else:    self.Quit()
    def Hide(self, event):
        self.fig.overrideredirect(False)
        self.fig.iconify()
    def Show(self, event):
        self.fig.overrideredirect(True)
    def Quit(self, *param):
        self.putData(['SUB', 'Exit', '()'])
        print('  << mainBoard: Off')
        self.fig.destroy()          # quit the program
if __name__ == '__main__':
    # ----- read params from ini file
    if osname == 'nt':
        # windows pour test programme
    try:
        settings = config['SETTINGS']
        vrbstr = settings['verbose']
        if   'b' in vrbstr: verbose = int(vrbstr.split('b')[1], base=2)
        elif 'x' in vrbstr: verbose = int(vrbstr.split('x')[1], base=16)
        else:               verbose = int(vrbstr)
        debug = int(settings['debug'])
        if netCfg['links']:
                            s.strip().title() \
        Ok = True
    except:
        Ok = False
    if not Ok:
        sleep(10)
        exit(1)
    # verbose : 1 = main, 2 = ethernet
    vrbm = bool(verbose & 1)
    vrbe = bool(verbose & 2)
    langs = ConfigParser()
    langs.read('Rpi_Pressure.ini', encoding='utf-16')
    qIn = Queue()
    print('\t{}: {}\n'.format(procName, eth.myAddr))
    # ------------------------------------------------------- Board management
    qCmd = Queue()
    setBoard = qCmd.put_nowait
    # ----- launch main program and loop
    pB = Process(target=board, args=(debug, qCmd, qIn, langs))
    pB.start()
    exitVal = 0
    MainOn = True
    exitFlag = False
    getdata = qIn.get
    wait4data = True
    T0 = time()
    Tend = 5
    ackn = False
    exitFromBoard = False
    while MainOn:
        try:
        except Empty:
            ret = []
            setBoard(['Exit',''])
            ret = []
        else: typ = ''
        if 'TCP' in typ:
            if 'out' in typ2:
                eth.relaunch(proc)
            elif ('snt1' in typ2) and vrbe:
                # ----- aknowledge
                if vrbe: print('\t<- {} from {}'.format(msgs, proc))
                if exitFlag:
                    if typ2 == 'rcv1':
                for cmdval in msgs.split('&'):
                    cmd, val = cmdval.split('=')
                    ackn = True
                    if 'Exit' in cmd:
                        # stop Rpi_Pressure
                        exitVal = int(val)
                        T0 = time()
                    setBoard([cmd, val])
                print('\t ????? {} received from {}'.format(msgs, proc))
                ackn = False
        elif 'SUB' in typ:
            if msgs == 'Exit':
                MainOn = False
                exitFromBoard = True
                exitFlag = True
                wait4data = False
            else:
                eth.sendTo(msgs, proc)
        elif typ:
    if not exitFromBoard: setBoard(['Exit','', ''])
    eth.close()
    pB.join()
    exit(exitVal)
Some screenshots:
3.c/ Dashboard
This raspberry (behind the steeringwheel) simulates a dashboard. As for previously, it ovelays, shows or hides images.
Images in img directory:
I use the Ackerman  steering angles (in def turn) for the turning  (see here) to be closer to reality.
It's simpler and faster to display images of rotated wheels than rotating an image...
Rpi_Display.py_________________________________________________________________________
""" RPi_Display
    Tractor board
__version__ = '1.0'
from math import pi, sin, cos, hypot, atan2, tan, atan, copysign
from time import sleep
from os import path
TrWb = 3.3        # wheelbase
TrTrs2 = 2.1/2    # Track
def rotate(rhoTheta, offset, angle):
    Rotate a figure (with polar coordinates), return cartesian coords
    rada = angle*pi/180
    rx, ry = offset
    return [n for elem in \
                [[r*cos(p+rada)+rx, r*sin(p+rada)+ry] for r, p in rhoTheta] \
                    for n in elem]
BEACONON = 0x01
BLINKON  = 0x02
class board():
    Main animation
    def __init__(self, debug, qIn, qOut):
        fig = tk.Tk()
        fig.lift()
        WxH = [1024, 600]
        fig.title('RPi_Display')
        fig.bind('H', self.hide)
        fig.bind('h', self.hide)
        fig.bind('S', self.show)
        fig.bind('s', self.show)
        cnv.pack()
        setPolygon = cnv.create_polygon
        imgDir = '../img'
        # ----- load and display background image
        self.bckImgTk = tk.PhotoImage(file=path.join(imgDir,'BoardBckgrnd.png'))
        self.BckImg = setImage(512, 300, image=self.bckImgTk)
        # ================================================ loading images files and texts...
        # loading tires (all angles)
        self.tireImg = {}
        self.RtiVwImg = {}
        self.LtiVwImg = {}
        for i in range(-35,36):
            if i >= 0:
                self.tireImg[i] = tk.PhotoImage(\
                        file=path.join(imgDir, 'FrTire+{:02d}.png'.format(i)))
            else:
                    file=path.join(imgDir, 'FrTire-{:02d}.png'.format(abs(i))))
            self.RtiVwImg[i] = setImage(519, 204, image=self.tireImg[i], anchor=tk.W, state=tk.HIDDEN)
            self.LtiVwImg[i] = setImage(508, 204, image=self.tireImg[i], anchor=tk.E, state=tk.HIDDEN)
        self.setConfig(self.RtiVwImg[0], state=tk.NORMAL)
        self.setConfig(self.LtiVwImg[0], state=tk.NORMAL)
        self.prevRtiVwImg = 0
        self.prevLtiVwImg = 0
        # ===== TopView
        self.tpVwImgTk = tk.PhotoImage(\
                            file=path.join(imgDir, 'TopView.png'))
        self.tpVwImg = setImage(512, 300, image=self.tpVwImgTk)
        self.hLights = {}
        # ===== Blinkers: FRONT / RIGHT
        self.FRBlImgTk = tk.PhotoImage(\
                            file=path.join(imgDir, 'light_front_blinker.png'))
        self.hLights['FRBl'] = [setImage(631, 268, image=self.FRBlImgTk, \
                                        anchor=tk.S, state=tk.HIDDEN)]
        # ----- Blinkers: FRONT / LEFT
        self.FLBlImgTk = self.FRBlImgTk.copy()
        self.hLights['FLBl'] = [setImage(395, 268, image=self.FLBlImgTk, \
        # ----- Blinkers: REAR / RIGHT
        self.RRBlImgTk = tk.PhotoImage(\
                            file=path.join(imgDir, 'light_rear_blinker.png'))
        self.hLights['RRBl'] = [setImage(620, 527, image=self.RRBlImgTk, \
                                        anchor=tk.N, state=tk.HIDDEN)]
        # ----- Blinkers: REAR / LEFT
        self.RLBlImgTk = self.RRBlImgTk.copy()
        self.hLights['RLBl'] = [setImage(406, 527, image=self.RLBlImgTk, \
        # ----- both (left/right for blinkers)
        self.hLights['BLBl'] = self.hLights['FLBl'] + self.hLights['RLBl']
        self.hLights['BRBl'] = self.hLights['FRBl'] + self.hLights['RRBl']
        # ===== lights: FRONT / RIGHT
        self.FRLdImgTk = tk.PhotoImage(\
                            file=path.join(imgDir, 'light_front_right.png'))
        self.hLights['FRLd'] = [setImage(550, 71, image=self.FRLdImgTk, \
        # ----- lights: FRONT / LEFT
        self.FLLdImgTk = tk.PhotoImage(\
                            file=path.join(imgDir, 'light_front_left.png'))
        self.hLights['FLLd'] = [setImage(475, 71, image=self.FLLdImgTk, \
        # ----- both front
        self.hLights['FBLd'] = self.hLights['FRLd'] + self.hLights['FLLd']
        # ===== lights: FRONT / RIGHT UP
        self.FRLuImgTk = tk.PhotoImage(\
                            file=path.join(imgDir, 'light_front_up_right.png'))
        self.hLights['FRLu'] = [setImage(589, 321, image=self.FRLuImgTk, \
        self.FLLuImgTk = tk.PhotoImage(\
                            file=path.join(imgDir, 'light_front_up_left.png'))
        self.hLights['FLLu'] = [setImage(435, 321, image=self.FLLuImgTk, \
        # ----- both front
        self.hLights['FBLu'] = self.hLights['FRLu'] + self.hLights['FLLu']
        # ===== Brakes: REAR / RIGHT
        self.RRBrImgTk = tk.PhotoImage(\
                            file=path.join(imgDir, 'light_brakes.png'))
        self.hLights['RRBr'] = [setImage(604, 531, image=self.RRBrImgTk, \
        # ----- Brakes: REAR / LEFT
        self.RLBrImgTk = self.RRBrImgTk.copy()
        self.hLights['RLBr'] = [setImage(428, 531, image=self.RLBrImgTk, \
        # ----- both Rear
        self.hLights['RBBr'] = self.hLights['RRBr'] + self.hLights['RLBr']
        # ===== lights: REAR / RIGHT UP
        self.RRLuImgTk = tk.PhotoImage(\
                            file=path.join(imgDir, 'light_rear_up_right.png'))
        self.hLights['RRLu'] = [setImage(583, 461, image=self.RRLuImgTk, \
        # ----- lights: REAR / LEFT
        self.RLLuImgTk = tk.PhotoImage(\
                            file=path.join(imgDir, 'light_rear_up_left.png'))
        self.hLights['RLLu'] = [setImage(448, 461, image=self.RLLuImgTk, \
        # ----- both Rear
        self.hLights['RBLu'] = self.hLights['RRLu'] + self.hLights['RLLu']
        self.beaconAng = 0
        rhoTheta = [[hypot(xi, yi), atan2(yi, xi)] for xi, yi in \
                            zip([4, 163, 169, 174, 177, 179, 180],\
                                [2, 76, 61.5, 46.5, 31, 15.5, 0])]
        rhoTheta += [[r,-th] for r,th in list(reversed(rhoTheta[:-1]))]
        self.beaconPol = rhoTheta
        self.LbeaconOffs = [405, 444]
        self.LBeacon = setPolygon(*rotate(rhoTheta, self.LbeaconOffs, \
                                         self.beaconAng + 180), \
                                  fill='orange', outline='', stipple='gray75',\
                                  state=tk.HIDDEN)
        self.RbeaconOffs = [629, 442]
        self.RBeacon = setPolygon(*rotate(rhoTheta, self.RbeaconOffs, \
                                         self.beaconAng), \
                                  state=tk.HIDDEN)
        # ----- set speed
        setText(180, 65, text='km/h', font=('DS-Digital', 30),\
                fill='darkblue')
        setText(180, 145, text='888', font=('DS-Digital', 100),\
                fill='#B2B2B2')
        self.speed = []
        for i in range(3):
            self.speed.append(setText(151+64.5*i,145, anchor=tk.E, text='0', \
                             font=('DS-Digital',100), fill='darkblue'))
        # ----- load other element
        self.symbMiscTk = tk.PhotoImage(file=path.join(imgDir, 'LeftElems.png'))
        setImage(180, 390, image=self.symbMiscTk)
        # ----- load right symbols
        xoff = 55
        self.rightSymbsTk = tk.PhotoImage(file=path.join(imgDir, 'RightElems.png'))
        setImage(890-xoff, 300, image=self.rightSymbsTk)
        # ----- load right arrow
        self.rightArrowTk = tk.PhotoImage(file=path.join(imgDir, 'RightArrow.png'))
        self.rightArrow = setImage(930, 319, image=self.rightArrowTk, \
                                             state=tk.HIDDEN)
        self.hLights['BRBl'] += [self.rightArrow]
        # ----- load left arrow
        self.leftArrowTk = tk.PhotoImage(file=path.join(imgDir, 'LeftArrow.png'))
        self.leftArrow = setImage(738, 319, image=self.leftArrowTk, \
                                            state=tk.HIDDEN)
        self.hLights['BLBl'] += [self.leftArrow]
        # ----- load warning symbol
        self.warnTk = tk.PhotoImage(file=path.join(imgDir, 'Warning.png'))
        self.warning = setImage(516, 380, image=self.warnTk, state=tk.HIDDEN)
        self.hLights['WARN'] = self.hLights['BLBl'] + self.hLights['BRBl'] \
                                                   + [self.warning]
        # ----- load warning disk
        self.warnDskTk = tk.PhotoImage(file=path.join(imgDir, 'RedDisk.png'))
        self.hLights['ERR'] = [setImage(833, 319, image=self.warnDskTk, \
                                                 state=tk.HIDDEN)]
        # ----- some variable to save or to add
        self.cancelTimer = fig.after_cancel
        self.beaconTimer = None
        self.blinkTimer = None
        self.fig = fig
        self.actionOn = 0
        self.fig.mainloop()
    def beaconRotate(self):
        """ rotate beacon ray
        self.setCoords(self.LBeacon, \
                       *rotate(self.beaconPol, self.LbeaconOffs, \
                               self.beaconAng + 180))
        self.setCoords(self.RBeacon, \
                       *rotate(self.beaconPol, self.RbeaconOffs, \
                               self.beaconAng))
        self.beaconAng += 30
        if self.beaconAng >= 360: self.beaconAng = 0
        self.beaconTimer = self.setTimer(40, self.beaconRotate)
    def beaconOnOff(self, OnOff):
        """ stop the beacon
        if self.beaconTimer is not None:
            self.cancelTimer(self.beaconTimer)
        if OnOff :
            for h in [self.LBeacon, self.RBeacon]:
                self.setConfig(h, state=tk.NORMAL)
            self.actionOn |= BEACONON
            self.beaconRotate()
        else:
                self.setConfig(h, state=tk.HIDDEN)
            self.actionOn &= ~BEACONON
    def lightsOnOff(self, lights, OnOff):
        """ lights on/off
        if OnOff :
            for h in self.hLights[lights]:
        else:
    def blink(self):
        """ blink (a) light(s)
        self.blinkFlag = (self.blinkFlag == False)
        if self.blinkFlag:
            for h in self.blinkCurh:
        else:
        self.blinkTimer = self.setTimer(400, self.blink)
    def blinkOnOff(self, lights, OnOff):
        """ stop blinking
        if self.blinkTimer is not None:
            self.cancelTimer(self.blinkTimer)
        if OnOff :
            self.blinkCurh = self.hLights[lights]
            self.blinkFlag = False
            self.actionOn |= BLINKON
            self.blink()
        else:
            self.actionOn &= ~BLINKON
    def turn(self, alpha):
        """ rotate the front wheels folling angle alpha
        if abs(alpha) > 30: alpha = copysign(30, alpha)
        if alpha:
            # ----- compute Ackerman angles
            Li = TrWb/tan(alpha*pi/180)
            alpha2 = copysign(round(abs(atan(TrWb/(Li + TrTrs2))*180/pi)), \
                              alpha)
            alpha1 = copysign(round(abs(atan(TrWb/(Li - TrTrs2))*180/pi)), \
                              alpha)
        else:
            alpha1 = alpha2 = 0
        # ----- limitations
        if abs(alpha1) > 35: alpha1 = copysign(35, alpha1)
        if abs(alpha2) > 35: alpha2 = copysign(35, alpha2)
        # ----- hide the previous ones
        self.setConfig(self.RtiVwImg[self.prevRtiVwImg], state=tk.HIDDEN)
        self.setConfig(self.LtiVwImg[self.prevLtiVwImg], state=tk.HIDDEN)
        # ----- show the new ones
        self.setConfig(self.RtiVwImg[alpha2], state=tk.NORMAL)
        self.setConfig(self.LtiVwImg[alpha1], state=tk.NORMAL)
        # ----- save the status
        self.prevRtiVwImg = alpha2
        self.prevLtiVwImg = alpha1
    def setSpeed(self, val):
        digits = [d for d in '{:03d}'.format(val)]
        first = True
        for i, di in enumerate(digits):
            if di == '0' and first and i != 2:
                # ----- don't display the headed 0
                self.setConfig(self.speed[i], state=tk.HIDDEN)
            else:
                first = False
                self.setConfig(self.speed[i], text=di, fill='darkblue', \
                               state=tk.NORMAL)
        """ wait for the orders
        loop = True
            cmd, which, val = ret
            if cmd == 'Beacon':   self.beaconOnOff(val)
            elif cmd == 'Light':
                 if which in self.hLights: self.lightsOnOff(which, val)
            elif cmd == 'Blink':
                 if which in self.hLights: self.blinkOnOff(which, val)
            elif cmd == 'Turn': self.turn(-val)
            elif cmd == 'Speed': self.setSpeed(val)
            elif cmd == 'Exit':
                loop = False
                break
            self.fig.update()
        if loop:
            # ----- info at 25Hz
        else:
            self.Quit()
    def hide(self, event):
        """ hide the window
        self.fig.iconify()
    def show(self, event):
        """ show the window
        """ Quit the window
#                                MAIN
    from time import time, strftime, sleep
    config = ConfigParser()
    from  os import name as osname
    if osname == 'nt':
    try:
        config.read(config.filename, encoding='utf-8')
        if netCfg['links']:
                            s.strip().title() \
        Ok = True
    except:
        Ok = False
    if not Ok:
        sleep(10)
        exit(1)
    # ----- Proc Name from ini = Rpi_In
    # verbose : 1 = main, 2 = ethernet, 4 = serial
    qIn = Queue()
    qCmd = Queue()
    pB = Process(target=board, args=(debug, qCmd, qIn))
    pB.start()
    setBoard(['Speed', '', 0])
    exitVal = 0
    MainOn = True
    exitFlag = False
    getdata = qIn.get
    wait4data = True
    T0 = time()
    Tend = 5
    ackn = False
    Vref = 16
    while MainOn:
        try:
        except Empty:
            ret = []
            ret = ['TCP:rcv0', 'Exit=0','Ctrl+C']
        else: typ = ''
        if 'TCP' in typ:
            if 'out' in typ2:
                eth.relaunch(proc)
                if vrbe: print('\t-> {} to {}'.format(msgs, proc))
                # ----- aknowledge
                if exitFlag:
                    if typ2 == 'rcv1':
                ackn = True
                    setBoard(['Blink', 'BLBl', bool(int(val))])
                    setBoard(['Blink', 'BRBl', bool(int(val))])
                    setBoard(['Beacon','', bool(int(val))])
                elif cmd in ['Brake', 'ReRedLght']:
                    setBoard(['Light', 'RBBr', bool(int(val))])
                    bval = bool(int(val))
                    setBoard(['Light', 'FBLd', bval])
                    setBoard(['Light', 'RBLu', bval])
                    setBoard(['Light', 'FBLd', bool(int(val))])
                    setBoard(['Light','FBLu', bool(int(val))])
                    setBoard(['Light', 'RBLu', bool(int(val))])
                    setBoard(['Light','RBLu', bool(int(val))])
                    setBoard(['Blink', 'WARN', bool(int(val))])
                elif cmd == 'STW':
                    setBoard(['Turn', '', int(val)])
                elif cmd == 'Vref':
                    Vref = float(val)
                elif cmd == 'Acc':
                    setBoard(['Speed', '', min(int(Vref*float(val)),Vref)])
                elif cmd == 'Exit':
                    # stop Rpi_Inputs
                    exitVal = int(val)
                    T0 = time()
                ackn = False
        elif 'SUB' in typ:
            if msgs == 'Exit':
                MainOn = False
                exitFlag = True
                wait4data = False
        elif typ:
    # ----- exit board is not done
    # ----- free the queue
    eth.close()
    pB.join()
    exit(exitVal)
______________________________________________________________________________________
Some screenshots:
     rotating beacon
     front and rear lights        warning lights
     left blinker        right blinker
     @65kph        Error system
     turn full right (see Ackerman angles)        turn full left
Back to intro
Tractor Simulator (interface with Farming Simulator 17)
Global presentation
Tractor simulator (cabin tractor interface with Farming Simulator 17): Part 1 - global presentation
The hardware
Tractor simulator (cabin tractor interface with Farming Simulator 17): Part 2 - the hardwareTractor simulator (cabin tractor interface with Farming Simulator 17): Part 2 - the hardware
Arduinos
Tractor simulator (cabin tractor interface with Farming Simulator 17): Part 3 - the software, 1/ Arduinos
Actual doc
PCs
Tractor simulator (cabin tractor interface with Farming Simulator 17): Part 3 - the software, 3/ PCs
