Legacy Personal Blogs Unboxing Molex Antenna Sample Kit
  • Author Author: xeonaj
  • Date Created: 21 Oct 2019 7:05 PM Date Created
  • Views 1555 views
  • ant
  • molex_webinar
  • antenna
  • mole
xeonaj
xeonaj
21 Oct 2019
I received the Molex Antenna Sample Kit for asking some good questions during an RF webinar -> Antenna Essentials: Key fundamentals that impact your RF system and steps to optimize antenna performance
So now am just going to show the antennas and some info about each. I didn't have the necessary tools and stuff to conduct a RoadTests & Reviews, so ended up with a blog. For more info check out ->Webinar Briefing & FAQ: Antenna Essentials: Key Fundamentals that Impact Your RF System is Available On-Demand!
The antenna Kit came in a good safe packaged box!
{gallery} The BOX
Box contents!
1. Bluetooth/Wi-Fi Antennas
146153 - Balance Flexible Antenna
146187 - Balance PCB Antenna
204281 - Balance Flexible Antenna Side-fed Cable
146175 - SMT MID Chip Antenna
47948 - SMT MID chip Antenna
203006 - Ceramic Chip Antenna
2. GNSS Antennas
146235 - Helix SMT GPS Antenna
146216 - RHCP LDS SMT GPS Antenna
146168 - GPS Ceramic Antenna (25x25mm)
204286 - GNSS Ceramic Antenna (25x25mm)
204283 - Low-profile CNSS Ceramic Antenna
3. Near Field Communications (NFC) Antennas
146236 - NFC Rectangular Antenna
4. Cellular Antennas
105263 - Cellular 6-Band Standalone Antenna
146185 - Cellular Quad-Band Flexible Antenna
146200 - Full LTE SMT antenna
204774 - 791~2170MHz Penta Band Antenna
5. Ultra Wide Band (UWB) Antennas
146184 - Ultra Wide Band (UWB) PCB Antenna
6. Industrial, Scientific and Medical (ISM) Antennas
105262 - 868/915MHz ISM Standalone Antenna
204287 - 433MHz Antenna
7. Combo Antennas (Wi-Fi, GPS, ISM, Cellular)
146186 - Combo GPS/Wi-Fi Flexible Antenna
146220 - Combo GPS/Wi-Fi PCB Antenna
203007 - Combo GPS/Wi-Fi Ceramic Antenna
201932 - Triple Band Ceramic Antenna
Lets Explore more about each Antenna ---
{gallery} Antennas! Antennas! Everywhere!
146153 - Molex Balanced 2.4-5G dual band Wi-Fi Flexible Antenna
https://www.molex.com/molex/products/datasheet.jsp?part=active/1461530100_ANTENNAS.xml
146187 - Molex Balanced Dual Band PCB Antenna
https://www.molex.com/molex/products/datasheet.jsp?part=active/1461870300_ANTENNAS.xml&channel=Products&Lang=en-US
204281 - Molex 2.4-5G Wi-Fi Balance Flexible Antenna Side-fed Cable
https://www.molex.com/molex/products/datasheet.jsp?part=active/2042810200_ANTENNAS.xml&channel=Products&Lang=en-US
https://www.molex.com/molex/products/datasheet.jsp?part=active/1461750001_ANTENNAS.xml
https://www.molex.com/molex/products/datasheet.jsp?part=active/0479480001_ANTENNAS.xml
https://www.mouser.in/ProductDetail/Molex/203006-0001?qs=AQlKX63v8Rtpx3sH6G2lNA%3D%3D
https://www.molex.com/molex/products/datasheet.jsp?part=active/1462350001_ANTENNAS.xml
https://www.molex.com/molex/products/datasheet.jsp?part=active/1462160001_ANTENNAS.xml
https://www.molex.com/molex/products/datasheet.jsp?part=active/1461680001_ANTENNAS.xml
https://www.molex.com/molex/products/datasheet.jsp?part=active/2042860001_ANTENNAS.xml
https://www.molex.com/molex/products/datasheet.jsp?part=active/2042830001_ANTENNAS.xml
https://www.molex.com/molex/products/datasheet.jsp?part=active/1462360031_ANTENNAS.xml&channel=Products&Lang=en-US
https://www.molex.com/molex/products/datasheet.jsp?part=active/1052630001_ANTENNAS.xml
https://www.molex.com/molex/products/datasheet.jsp?part=active/1461850100_ANTENNAS.xml&channel=Products&Lang=en-US
https://www.molex.com/molex/products/datasheet.jsp?part=active/1462000001_ANTENNAS.xml&channel=Products&Lang=en-US
https://www.molex.com/molex/products/datasheet.jsp?part=active/2047740001_ANTENNAS.xml&channel=Products&Lang=en-US
https://www.molex.com/molex/products/datasheet.jsp?part=active/1461840200_ANTENNAS.xml&channel=Products&Lang=en-US
https://www.molex.com/molex/products/datasheet.jsp?part=active/1052620002_ANTENNAS.xml
https://www.molex.com/molex/products/datasheet.jsp?part=active/2042870300_ANTENNAS.xml
https://www.molex.com/molex/products/datasheet.jsp?part=active/1461860150_ANTENNAS.xml
https://www.molex.com/molex/products/datasheet.jsp?part=active/1462200250_ANTENNAS.xml&channel=Products&Lang=en-US
https://www.molex.com/molex/products/datasheet.jsp?part=active/2030070001_ANTENNAS.xml&channel=Products&Lang=en-US
https://www.molex.com/molex/products/datasheet.jsp?part=active/2019320001_ANTENNAS.xml
Thank You danzima, rscasny and tariq.ahmad for bringing such an opportunity.
I really didn't know how to start with the blog content. This is my first ever genuine blog post! So if there are any suggestions please don't mind to post them, I would love to hear your thoughts on my first blog. I think you guys also have blog benchmarking system so please post a link to those blogs you think are the best example that I should follow. Thank You waiting to hear from you!
  • xeonaj
    xeonaj over 7 years ago in reply to Fred27 +1
    Yeah exactly! All I can do with them right now is using them in some board for extra range! I have been thinking to break into my small WiFi Dongle used for Kali Linux and add one of the antenna to it…
  • xeonaj
    Yeah exactly!
    I have been thinking to break into my small WiFi Dongle used for Kali Linux and add one of the antenna to it.
    The antenna are just built onto the board, I'll have to break the existing antenna on board and solder a connector onto the board and use my gifted antennas for extra range! AND KEEP HACKING AND PEN-TESTING FOR FUN
  • Fred27
    Fred27 over 7 years ago
    Great. It looks like you're getting in some road test practice. It does seem particularly difficult to do much with an antenna without some specialised test equipment.
  • xeonaj
    xeonaj over 7 years ago in reply to tariq.ahmad
    Yeah! I also learned something Blog writing is interesting as well as time consuming!
  • tariq.ahmad
    tariq.ahmad over 7 years ago
    Hi xeonaj ,
    You got it right.  The best thing to do is to jump right in and share.   Enthusiasm is contagious and the more you contribute the more you’ll find that this is a great place to learn and take your interest in electronics to another level.
