Legacy Personal Blogs Unintended Consequences........
  • Author Author: neilk
  • Date Created: 27 Mar 2020 4:42 PM Date Created
  • Views 4096 views
  • Likes 10 likes
  • Comments 23 comments
  • esp8266 wifi
  • ssid
  • humax
neilk
neilk
27 Mar 2020
Just before Christmas last year, my ISP offered me a deal whereby I could have my broadband connection upgraded to twice the speed and actually pay a little bit less, provided I signed up for another 18 months contract. The deal also included a new router. I have been satisfied with my ISP and the price was competitive so I signed up,
The router arrived, the switch over occurred and my desk top PC (cable connected) was back online and looking good almost immediately. I then went through the process of reconnecting both laptops and the wireless printer to the new SSID. I then brought the ESP8266 greenhouse monitor inside so that I could update the firmware via a cable connection - can't do OTA updates if the device can't connect to the network! Finally, I reconnected the Humax hard drive video recorder to the new SSID (we don't have a SMART TV).
Then the trouble started: my wife's laptop periodically refused to connect to the WiFi, or would drop out whilst she was using it and refuse to re-connect, although mine was OK. The only fix seemed to be to disable and then re-enable the WiFi adapter and then reboot the laptop. Strangely, after a few weeks, this behaviour stopped! Then the Humax video recorder started to regularly disconnect from the network, - every hour or so - flashing a message up on the TV screen to tell us and then re-connecting after a few seconds, flashing another message on the screen!! Although annoying, this was not a big problem, because we rarely streamed content from the Internet.
However......... In these extremely difficult times of enforced stay at home, we decided it would be good to be able to access streaming content. So we did, and it was very inconvenient when the recorder disconnected from the network in the middle of a film! I did some Googling and found a suggestion that certain models of Humax recorders don't like to connect to an SSID with a long name. Easy peasy - I logged onto the router, changed the SSID and password and then reconnected the Humax. By this time it was 9:30pm. We didn't stay around long enough to see if this had fixed the problem with the Humax.
The next morning, I sorted out the laptops again and then the printer. My brain obviously wasn't working properly, because I then logged on to my server to check the overnight temperatures in the greenhouse. It took me several minutes to realise that logging had stopped at about 9:20pm when I changed the SSID!
Out to the greenhouse, disconnect the unit, back inside and connect the unit to my PC and upload an updated firmware image. Check that it's connecting to the network and logging OK, and then back out to the greenhouse. Strange, it's not logging anymore. Back out to the greenhouse; watch it for a while, waiting for the blue LED to flash when it logs - it doesn't.......I wonder if the battery is flat? It shouldn't be!
Back to my desk, grab the phone powerpack, back out the greenhouse; plug it in and see the blue LED flash almost immediately! back to my desk and check it's logging. Yes!!
Thinking it through, even though the battery had several days of life left in it, when the unit failed to connect to the network at about 9:20pm, it just kept on trying and trying and failing  Connecting to the network and logging are the heaviest drain on power, so it's only to be expected that the remaining life in the battery drained away between 9:20pm and about 11:30am the following day!
To add insult to injury, the Humax recorder continues to regularly disconnect from the network and then reconnect!!! I have no idea why!
    genebren over 6 years ago +5
    I hate when that happens. I consider myself to be an above average user of computers/networks/etc., but nothing brings be to my knee crying faster than working on my home network. This sort of problem…
    dubbie over 6 years ago +5
    Neil, Sounds like life to me. I try to minimise these episodes by only updating or upgrading when absolutely necessary and certainly never to a new system hardware or software. Always wait until the initial…
  • Fred27
    Fred27 over 6 years ago +5
    Is your Ethernet connected PC OK? i.e. Is it the WiFi that's the problem? If so, you could leave the new router doing the broadband side of things and use your old reliable one on WiFi duties.
  • Fred27
    • Vote Up +5 Vote Down
  • neilk
    neilk over 6 years ago in reply to Fred27
    Hi Fred27 the weather stopped my gardening yesterday so I decided to try your suggestion. Seemed to work brilliantly until bedtime, when I turned off my PC - there was a shout from my wife - "Network disconnected".
    Thinks.............ah! I powered the old router from the dis board that gets switched off at night!!!!!!!!
    Plugged it into an outlet that stays on....."Network Connected"
    But.............this morning..............."Network disconnected" and won't reconnect!!!!!!!!!!!!
    Did a bit more peering at screens and thinking...
    When I look at the available networks in the Humax config screen, the new router appears twice. I had been selecting the first occurrence; the new router operates on 2.5Mhz and 5 Mhz bands; the selected network was the 5Mhz band - strongest signal. I have now connected to the 2.5Mhz offering and we'll see what happens!
  • neilk
    neilk over 6 years ago in reply to neilk
    Latest Update - connecting to the 2.5Mhz band didn't solve the problem!
    I have now disabled the use of DHCP on the Humax and assigned it a fixed IP address. I have also reserved that IP address on the router. Still connected to the 2.5Mhz band
    See what happens next!
    Surely, this is mass market consumer kit......I shouldn't need to do this!!!
  • neilk
    And it's no better! If anything, it's worse.....disconnectiong and reconnecting every 10 to 15 minutes!
    At least I can stream on my Laptop and cast the stream to the Chromecast...............until that stops working!!!!!!!!!!
  • Andrew J
    Andrew J over 6 years ago in reply to neilk
    I find wifi infuriating to debug when it goes wrong.  You have to assume that if it worked without issue on your old router and works intermittently on your new router then it's unlikely that the wifi module in the humax is failing.  I recently had a problem with PS4 not picking up the network - it's 2.4Ghz as well.  No rhyme or reason for it, 'yesterday' it worked, 'today' it didn't - I ended up unplugging it and carrying it closer to the router to see if it was still working (it was.)  I sorted that out by changing the broadcast channel on the router from Auto to 1 or 3 (can't remember.)  As I say, some routers, particularly BT but I may just be paranoid, broadcast a strong signal which can cause interference.
    The only things I can suggest are:
    • Are you able to power up your old router and log into it to check settings and do a comparison?
    • Does your new router allow you to set the channel width for 2.4Ghz?  It's better at 20Mhz rather than 40Mhz (or 80Mhz.)  The 5Ghz channel should be set to the widest.
    • Does it have traffic prioritisation (QoS or WMM) - enable WMM if it has it.
    I'm sure you've tried all those things and obviously I have no idea if they would help.  It might be worth downloading and trying a wifi analyser application.  Have you access to a wifi extender to try?
  • neilk
    Hi  Andrew J  and  colporteur   thank you both so much for you help and suggestions. I fear I will have to abandon this problem for now: my wife is working from home and getting through her work much faster than when she is in the office!!
    As a consequence she has embarked on, and I have been dragged unwillingly into, spring cleaning and reorganising the "office" area - ie the conservatory. As a consequence, this is the first opportunity I have had since my last post to sit down and reply to you!
    On top of that, because we can stream from the PC or laptop to the Chromecast  (to be honest the UI via windows is faster and slicker than the UI built into the players on the Humax) she has been telling me for some time to stop fiddling around trying to solve a problem that doesn't matter...................she doesn't understand the need to solve a problem because of the intellectual challenge involved!
    Thanks again for your input. I will get back to it!
    Neil
  • Andrew J
    "she doesn't understand the need to solve a problem because of the intellectual challenge involved!"
    Join the club! image
    I feel a need to stop whatever I'm working on after 5pm once it is working (enough) and not start on the next step, otherwise ructions ensue as I try to resolve the last little problem - and there's always one more as you know.
  • Andrew J
  • neilk
    neilk over 6 years ago in reply to Andrew J
    Another issue related to "wife WFH" and me being retired - I am used to doing my own thing during her office hours and then being social in the evenings....................that's not turning out too well at the moment image
  • Andrew J
    I stopped working about 6 months before my wife and had the same thing as well - I'd already settled into a retired routine.  It worked itself out after a few weeks once she'd found her own routine and had got work out of her system.  Now we make a concerted effort to do our own things and do things together with a priority on the latter really.  Situation is a bit different here of course but hopefully this won't go on too long.
    You may find she doesn't want to go back!  Seeing me going from work-grumpy-miserable to home-happy-cheerful meant it wasn't too long before she decided that her plans for working for two or three years could go out the nearest window image
    dubbie over 6 years ago in reply to Andrew J
    Andrew,
    I think I agree with you, about being at work - grumpy (although not that grumpy) and then being retired - definitely happy and more social. Regretfully my wife has not (yet!) accepted that doing electronics and building robots is an acceptable retirement activity. I currently have five Tobbie walking robot kits waiting to be assembled (they were bargains). For some reason gardening is more acceptable but again, "why do I need to spend money on plants? We have plants already." I did point out that our garden is currently a riot of colour (daffodils, tulips and primroses - all purchased in the last 12 months) but that didn't seem to cut any ice.
    Dubbie
  • colporteur
    colporteur over 6 years ago in reply to dubbie
    So true. So true. I can garden but I don't find it mentally stimulating as problem solving. Assembling a kit would be immensely rewarding.
