Legacy Personal Blogs Why I don't own a benchtop PSU, for my solar projects
  • Author Author: station240
  • Date Created: 22 Sep 2018 2:46 PM Date Created
  • Views 788 views
  • bench psu
  • mppt
  • solar
station240
station240
22 Sep 2018
As my areas of interest are power electronics, SMPS, solar power and related areas of Microcontrollers and opamps, any form of PSU I use for testing has to be suitable.
But most of the electronics can be powered from simple fixed voltage supplies.
3.3V MCU.
5V logic/modules.
12V relays.
+/-15V opamps and current sensors.
So I have a box of mains powered PSU modules I can use as is.
What does need a variable supply to test is the main DC bus (~400V) of SMPS and solar related inverters. Find whatvoltage range the circuits function, I've already found some work at far lower voltages than their label says.
Then you need to simulate a solar panel/array, but these days of 60 cell (40V max), 72 cell (50V max), 96 cell (64V max), even a single panel would require higher voltages than the average bench PSU.
Plus real solar panels have varying V/A curves, which you need to simulate to test MPPT functions, that means a programmable PSU or one with inbuilt solar simulator.
So you bog standard 0-30V benchtop PSU is almost entirely useless to me.
What I would like turns out to be a rare, and hard to obtain 'high voltage' supply, which are not only not mass produced, but often only in higher power ratings.
Some day I'll just build me own 0-400V DC supply, after a lot of careful planning.
    DAB over 8 years ago +1
    Back in my tech school days we always had a 0-400 v DC power supply around to power the tube circuits we built. They were about the size of a toaster with a substantial transformer and basic rectification…
  • rsc
    rsc over 8 years ago
    With a variac and a transformer from a microwave oven, you can get 0-3000VAC.  Add a couple of microwave diodes and a HV cap, and you have your HV DC power supply.
    Scott
  • rsc
    Scott
  • station240
    station240 over 8 years ago in reply to rsc
    I used High voltage in quote marks for a reason, I only need 0-400V, or maybe as far as 600V.
    The technical term for <1KV supplies is Low Voltage, a term I refuse to use as it implies low risk which isn't the case.
    Microwave HV components are lethal, not something I have to worry about, as I haven't gotten a Microwave with a working HV section.
    Actually I do have a variac, but how can you software control a big heavy rotating contact ?
