Legacy Personal Blogs Working with Modest Equipment
  • Date Created: 5 Feb 2016 10:45 PM Date Created
  • Views 2091 views
  • Comments 15 comments
  • test
  • gear
  • lab
5 Feb 2016
You'll see in my blogs that I don't use state-of-the art lab equipment.
That may point out that I'm a cheapskate. And yes, that's part of the story.
But the real reason is that I believe in modest means. I've learned that during my electronics studies.
I learned electronics in the 1st half of the 80's, when two things were different from now. Lab equipment was much more expensive. And there was a big crisis.
These days, I can afford to purchase a +100MHz, 4 channel oscilloscope, even mixed signal if I stress my budget a little. But I don't do that. I use a second hand DS1052E.
And I believe that my education learned me a great thing: learn to design and work with tolerance, fault margins and uncertainty.
Tolerance
I like to think that that is the best thing I got out of my education. Try to design with the worst component possible. Make a stable design with 10% tolerance. Use transistors with high Hfe range.
Deal with the real world at its worst.
These things force you to get a deep understanding of the problem domain. Almost an organic understanding.
The same with meters and other lab gear. When you have high-end material, it's easy to replicate tests.
When you deal with modest means, the brain has to jump in. You learn.
If you find yourself in a situation where your test gear isn't optimal, you have several choices.
The two most popular ones are:
  • give up or
  • think further.
When you choose #2, you learn. You understand and grow.
You'll often see articles from me where I use a mediocre meter, or where the signal on my oscilloscope shows significant ringing. That's my own choise. I like to go for the core of the problem.
I'm not looking for perfect images. I want to see that my design works. Or I want to see what happens in a circuit.
If precision is not part of the problem domain - I ignore it and don't take measures to avoid it. If the integrity of the signal does interest me, I use better measurement methods.
Or I visit a friend with better gear - something I plan to do again soon. I will keep you posted on that image.
  • D_Hersey
    D_Hersey over 10 years ago +4
    There is a distinction to be drawn between precision and accuracy. The DVM did not completely supplant the analog meter, for example. In critical safety situations, glancing at a needle has been found…
    shabaz over 10 years ago +3
    I also like that most of us have very sensitive or very high performance equipment for helping with our projects, yet some people don't realise it! For example a radio makes an incredible test tool, possibly…
    jw0752 over 10 years ago +1
    Hi Jan, I totally agree with your approach. When I started into electronics marginal equipment was all I could afford. I was a technician involved in repairing the equipment that was designed by others…
    Hi Jan,
    I totally agree with your approach. When I started into electronics marginal equipment was all I could afford. I was a technician involved in repairing the equipment that was designed by others. Once I got used to working with $20 analog meters and Radio Shack test equipment I stayed with it. It is easy to fool oneself into thinking that the better equipment will make a difference in the quality of the work but most of the time the difference comes back to thinking about the problem to solve it. I bought better equipment a couple times but ultimately found myself making most of my tests with my old analog meter. Obviously I got along well with my cheap meters because the complexity and precision of the equipment I was repairing really didn't demand Keithley Precision. That being said I do really appreciate it when there is a proper tool for the job at hand. There is nothing worse than trying to remove phillips head screws with a flat screw driver. A good example is the little de-soldering iron you recommended to me a while ago. That machine works extremely well and makes me wish I had purchased one years ago. The only plus, to not having one sooner, is now I know all the hard ways to salvage a circuit board.
    Hi Jan,
