Legacy Personal Blogs XMUTIL ... understanding platformstats
  • Author Author: albertabeef
  • Date Created: 1 May 2021 7:43 PM Date Created
  • Views 2752 views
  • platformstats
  • xilinx
  • xilinx-linux
  • xilinx fpga
  • xmutil
albertabeef
albertabeef
1 May 2021
In this blog series, I dive into Xilinx's new platform management utility called xmutil.
In my last blog, I gave a high level overview of the xmutil utility.
XMUTIL ... a new platform and app management utility from Xilinx
We already saw that xmutil is a shell script, that calls the following utilities as sub-commands:
sub-commandsutilityreference
boardidfru_print.py?
bootfw_status
bootfw_update
image_updatehttps://github.com/Xilinx/linux-image_update
listapps
unloadapp
loadapp
dfx-mgr-clienthttps://github.com/Xilinx/dfx-mgr
platformstatsplatformstatshttps://github.com/Xilinx/platformstats
ddrqosddr-qoshttps://github.com/Xilinx/ddr-qos
axiqosaxi-qoshttps://github.com/Xilinx/axi-qos
pwrctlsom-pwr-ctlhttps://github.com/Xilinx/xmutil/blob/release-2020.2.2_k26/som-pwrctl
In this blog, I start investigating how to port this utility to a custom platform (in this case, Ultra96-V2), starting with the platformstats sub-command / utility.
Installing xmutil on Ultra96-V2
In order to understand how the xmutil works, lets install the xmutil and platformstats components to the Ultra96-V2 board.
Note that I am using my Vitis-AI 1.3 image for Ultra96-V2 for this exercise :
http://avnet.me/vitis-ai-1.3-project
On our embedded Ultra06-V2 platform, let's start by creating a xmutil directory to work with:
mkdir xmutil
cd xmutil
Next, let's clone the xmutil repository, and install the shell script to the /usr/bin directory:
git clone https://github.com/Xilinx/xmutil
cd xmutil
cp xmutil /usr/bin/.
cd ..
Finally, let's clone the platformstats repository, build the utility, and install to the expected location (I figured this out with trial and error):
git clone -b avnet-2020.2 https://github.com/Xilinx/platformstats
cd platformstats
./build.sh
cp src/libplatformstats.so.1.0 /usr/lib/.
ln -s /usr/lib/libplatformstats.so.1.0 /usr/lib/libplatformstats.so.1
ln -s /usr/lib/libplatformstats.so.1 /usr/lib/libplatformstats.so
cp platformstats /usr/bin/.
cd ..
If we run the platformstats sub-command via xmutil, with the "-a" argument, we get the following output:
root@u96v2-sbc-base-2020-2:~/xmutil/platformstats# xmutil platformstats -a
CPU Utilization
CPU0    :     6.222449%
CPU1    :     0.100000%
CPU2    :     0.100000%
CPU3    :     0.100000%
RAM Utilization
MemTotal      :     2036740 kB
MemFree       :     1513088 kB
MemAvailable  :     1717784 kB
Swap Mem Utilization
SwapTotal    :    0 kB
SwapFree     :    0 kB
Power Utilization
no hwmon device found for ina260_u14 under /sys/class/hwmon
no hwmon device found for ams under /sys/class/hwmon
CMA Mem Utilization
CmaTotal   :     0 kB
CmaFree    :     0 kB
CPU Frequency
match not foundCPU0     :    0.000000 MHz
match not foundCPU1     :    0.000000 MHz
Most of the code seems to be generic, making use of the standard linux file system.
platformstats optiondescriptionreference
-cCPU Utilization/proc/stat
-rRAM Utilization/proc/meminfo (lines 1-3)
-sSwap Mem UItilization/proc/meminfo (lines 15-16)
-pPower Utilization/sys/class/hwmon/hwmon*/*
-mCMA Memory Utilization/proc/meminfo (lines 38-39)
-fCPU Frequency/proc/cpuinfo
The "CPU Frequency" hangs, and I don't know why.  I noticed that is also hangs on the KV260.
The "Power Utilization" is not working on Ultra96-V2, and is looking for "ina260", "ams" devices specific to the KV260.
root@u96v2-sbc-base-2020-2:~/xmutil/platformstats# xmutil platformstats -p
Power Utilization
For a custom board, therefore, this option needs to be modified.
Modifying platformstats for Ultra96-V2
I modified the code for the avnet platforms.  These modifications were based on the work I had previously done with the python based project:
https://www.hackster.io/AlbertaBeef/monitoring-power-on-the-avnet-platforms-e52a23
For the Ultra96-V2, I specified the power monitoring devices available on the pmbus as a data structure.
Note that I also included a few temperature values, which should probably be included with a new option ( -t => Temperature ).
struct pmbus_info pmbus_ultra96v2[] =
   //    device   address           name    label         alias  unit  division
   //  ir38060-i2c-6-45
   {  "ir38060", "6-0045",            "", "pout1", "         5V", "mW", 1000 },
   {  "ir38060", "6-0045",            "", "iout1", "         5V", "mA",    1 },
   {  "ir38060", "6-0045",            "", "iout1", "         5V", "mV",    1 },
   {  "ir38060", "6-0045", "temp1_input", "temp1", "Temperature",  "C", 1000 },
   // irps5401-i2c-6-43
   { "irps5401", "6-0043",            "", "pout1", "     VCCAUX", "mW", 1000 },
   { "irps5401", "6-0043",            "", "pout2", "  VCCO 1.2V", "mW", 1000 },
   { "irps5401", "6-0043",            "", "pout3", "  VCCO 1.1V", "mW", 1000 },
   { "irps5401", "6-0043",            "", "pout4", "     VCCINT", "mW", 1000 },
   { "irps5401", "6-0043",            "", "pout5", "    3.3V DP", "mW", 1000 },
   { "irps5401", "6-0043", "temp1_input", "temp1", "Temperature",  "C", 1000 },
   // irps5401-i2c-6-44
   { "irps5401", "6-0044",            "", "pout1", "   VCCPSAUX", "mW", 1000 },
   { "irps5401", "6-0044",            "", "pout2", "   PSINT_LP", "mW", 1000 },
   { "irps5401", "6-0044",            "", "pout3", "  VCCO 3.3V", "mW", 1000 },
   { "irps5401", "6-0044",            "", "pout4", "   PSINT_FP", "mW", 1000 },
   { "irps5401", "6-0044",            "", "pout5", " PSPLL 1.2V", "mW", 1000 },
   { "irps5401", "6-0044", "temp1_input", "temp1", "Temperature",  "C", 1000 },
   { "", "", "", "", "", 1 }
I did the same for the UltraZed-EVCC:
struct pmbus_info pmbus_uz7ev_evcc[] =
   //  ir38063-i2c-3-4c
   {  "ir38063", "3-004c",            "", "pout1", "              Carrier 3V3", "mW", 1000 },
   //  ir38063-i2c-3-4b
   {  "ir38063", "3-004b",            "", "pout1", "              Carrier 1V8", "mW", 1000 },
   // irps5401-i2c-3-4a
   { "irps5401", "3-004a",            "", "pout1", "      Carrier 0V9 MGTAVCC", "mW", 1000 },
   { "irps5401", "3-004a",            "", "pout2", "      Carrier 1V2 MGTAVTT", "mW", 1000 },
   { "irps5401", "3-004a",            "", "pout3", "         Carrier 1V1 HDMI", "mW", 1000 },
//{ "irps5401", "3-004a",            "", "pout4", "                   Unused", "mW", 1000 },
   { "irps5401", "3-004a",            "", "pout5", "Carrier 1V8 MGTVCCAUX LDO", "mW", 1000 },
   // irps5401-i2c-3-49
   { "irps5401", "3-0049",            "", "pout1", "    Carrier 0V85 MGTRAVCC", "mW", 1000 },
   { "irps5401", "3-0049",            "", "pout2", "         Carrier 1V8 VCCO", "mW", 1000 },
   { "irps5401", "3-0049",            "", "pout3", "         Carrier 3V3 VCCO", "mW", 1000 },
   { "irps5401", "3-0049",            "", "pout4", "          Carrier 5V MAIN", "mW", 1000 },
   { "irps5401", "3-0049",            "", "pout5", " Carrier 1V8 MGTRAVTT LDO", "mW", 1000 },
   { "irps5401", "3-0049", "temp1_input", "temp1", "              Temperature",  "C", 1000 },
   //  ir38063-i2c-3-48
   {  "ir38063", "3-0048",            "", "pout1", "          SOM 0V85 VCCINT", "mW", 1000 },
   // irps5401-i2c-3-47
   { "irps5401", "3-0047",            "", "pout1", "           SOM 1V8 VCCAUX", "mW", 1000 },
   { "irps5401", "3-0047",            "", "pout2", "                  SOM 3V3", "mW", 1000 },
   { "irps5401", "3-0047",            "", "pout3", "           SOM 0V9 VCUINT", "mW", 1000 },
   { "irps5401", "3-0047",            "", "pout4", "       SOM 1V2 VCCO_HP_66", "mW", 1000 },
   { "irps5401", "3-0047",            "", "pout5", "    SOM 1V8 PSDDR_PLL LDO", "mW", 1000 },
   { "irps5401", "3-0047", "temp1_input", "temp1", "              Temperature",  "C", 1000 },
   // irps5401-i2c-3-46
   { "irps5401", "3-0046",            "", "pout1", "        SOM 1V2 VCCO_PSIO", "mW", 1000 },
   { "irps5401", "3-0046",            "", "pout2", "     SOM 0V85 VCC_PSINTLP", "mW", 1000 },
   { "irps5401", "3-0046",            "", "pout3", "  SOM 1V2 VCCO_PSDDR4_504", "mW", 1000 },
   { "irps5401", "3-0046",            "", "pout4", "     SOM 0V85 VCC_PSINTFP", "mW", 1000 },
   { "irps5401", "3-0046",            "", "pout5", "    SOM 1V2 VCC_PSPLL LDO", "mW", 1000 },
   { "irps5401", "3-0046", "temp1_input", "temp1", "              Temperature",  "C", 1000 },
And the same for the UltraZed-EG IOCC and PCIE carrier cards:
struct pmbus_info pmbus_uz3eg_xxx[] =
   // irps5401-i2c-3-43
   { "irps5401", "3-0043",            "", "pout1", "       PSIO", "mW", 1000 },
   { "irps5401", "3-0043",            "", "pout2", "     VCCAUX", "mW", 1000 },
   { "irps5401", "3-0043",            "", "pout3", "    PSINTLP", "mW", 1000 },
   { "irps5401", "3-0043",            "", "pout4", "    PSINTFP", "mW", 1000 },
   { "irps5401", "3-0043",            "", "pout5", "      PSPLL", "mW", 1000 },
   { "irps5401", "3-0043", "temp1_input", "temp1", "Temperature",  "C", 1000 },
   // irps5401-i2c-3-44
   { "irps5401", "3-0044",            "", "pout1", "     PSDDR4", "mW", 1000 },
   { "irps5401", "3-0044",            "", "pout2", "     INT_IO", "mW", 1000 },
   { "irps5401", "3-0044",            "", "pout3", "       3.3V", "mW", 1000 },
   { "irps5401", "3-0044",            "", "pout4", "        INT", "mW", 1000 },
   { "irps5401", "3-0044",            "", "pout5", "   PSDDRPLL", "mW", 1000 },
   { "irps5401", "3-0044", "temp1_input", "temp1", "Temperature",  "C", 1000 },
   // irps5401-i2c-3-45
   { "irps5401", "3-0045",            "", "pout1", "    MGTAVCC", "mW", 1000 },
   { "irps5401", "3-0045",            "", "pout2", "         5V", "mW", 1000 },
   { "irps5401", "3-0045",            "", "pout3", "       3.3V", "mW", 1000 },
   { "irps5401", "3-0045",            "", "pout4", "  VCCO 1.8V", "mW", 1000 },
   { "irps5401", "3-0045",            "", "pout5", "    MGTAVTT", "mW", 1000 },
   { "irps5401", "3-0045", "temp1_input", "temp1", "Temperature",  "C", 1000 },
The print_pmbus_info function scans the /sys/class/hwmon to find the matching pmbus device, address, and label, then displays the value.  I admit the code is not very clean, but gets the job done.
Finally, I use the hostname command to determine which Avnet board we are running on:
int print_power_utilization(int verbose_flag)
  FILE *fp;
  char hostname[128] = "";
  fp = popen("hostname", "r");
  if (fp != NULL) {
    if ( fgets(hostname, sizeof(hostname), fp) != NULL ) {
      if (verbose_flag)
        printf("hostname=%s\n", hostname);
    pclose(fp);
  if ( strstr(hostname,"u96v2") )
    if (verbose_flag)
      printf("Ultra96-V2\n");
    print_pmbus_info(verbose_flag,pmbus_ultra96v2);
  if ( strstr(hostname,"uz7ev") )
    if (verbose_flag)
      printf("UltraZed-7EV-EVCC\n");
    print_pmbus_info(verbose_flag,pmbus_uz7ev_evcc);
  if ( strstr(hostname,"uz3eg") )
    if (verbose_flag)
      printf("UltraZed-3EG\n");
    print_pmbus_info(verbose_flag,pmbus_uz3eg_xxx);
return(0);
Let's clone this version of the platformstats repository, re-build, and re-install:
git clone -b avnet-2020.2 https://github.com/AlbertaBeef/platformstats platformstats_avnet
cd platformstats_avnet
./build.sh
cd ..
Now if we run the platformstats sub-command via xmutil on the Ultra96-V2 board, we get the following:
root@u96v2-sbc-base-2020-2:~/xmutil/platformstats_avnet# xmutil platformstats -p
Power Utilization:
        ir38060@6-0045-pout1 (         5V) = 5062 mW
        ir38060@6-0045-iout1 (         5V) = 1187 mA
        ir38060@6-0045-iout1 (         5V) = 1187 mV
        ir38060@6-0045-temp1 (Temperature) = 61 C
        irps5401@6-0043-pout1 (     VCCAUX) = 156 mW
        irps5401@6-0043-pout2 (  VCCO 1.2V) = 0 mW
        irps5401@6-0043-pout3 (  VCCO 1.1V) = 125 mW
        irps5401@6-0043-pout4 (     VCCINT) = 1218 mW
        irps5401@6-0043-pout5 (    3.3V DP) = 0 mW
        irps5401@6-0043-temp1 (Temperature) = 54 C
        irps5401@6-0044-pout1 (   VCCPSAUX) = 281 mW
        irps5401@6-0044-pout2 (   PSINT_LP) = 250 mW
        irps5401@6-0044-pout3 (  VCCO 3.3V) = 500 mW
        irps5401@6-0044-pout4 (   PSINT_FP) = 656 mW
        irps5401@6-0044-pout5 ( PSPLL 1.2V) = 46 mW
        irps5401@6-0044-temp1 (Temperature) = 56 C
What Next ?
Which sub-command should we investigate next ?
