Clem Martins's Blog Flash Back
  • Author Author: clem57
  • Date Created: 6 Mar 2020 2:02 PM Date Created
  • Views 1373 views
  • Comments 6 comments
  • arduino iot
  • nano iot
  • computer programmer
  • vision ai
Flash Back
clem57
clem57
6 Mar 2020
                    In honor of...
   With the coming of Nanorama I think it is fitting to look back at another Arduino project 14 in Open Arduino . Back then we had the opportunity to work with the MKR1010. It amazes me how far hardware has progressed. Unfortunately as often is the case, the software lags behind. The ideas are there, but realizing them is very difficult because not enough time and tools available to somehow automate the process. In my many years in this biz of software, I have head about how programmers will one day be replaced by machines. The actual truth is  reality has blurred vision. We can use robotics to do physical things. We can use AI/ML to help improve day o day functions like Alexa . But the task of programming still has not be eliminated.  So pleas comment on your ideas of automating the actual programming task.
Thanks!
Clem
    dougw over 6 years ago +5
    Software and programming has been increasingly automated ever since the days of hand assembly. How much do libraries automate the process? With configurable OCX's in VB you hardly had to write any code…
  • Andrew J
    Andrew J over 6 years ago +3
    Automation of the mundane/rote elements of software has been for a long time, as Doug references above. 4GLs have been around as long as I remember. I have access to an interesting book from 1959: Programming…
    Jan Cumps over 6 years ago +3
    Google has also automated big parts of the exercise. It replaced “develop a library” with “apt-get install library” or “pip get library” and copy/paste. I think Google is the biggest software reuse initiative…
    With configurable OCX's in VB you hardly had to write any code to make very complex applications.
    A lot of programs in the near future will be "written" by dragging a bunch of libraries into a repository, defining some input and what output is required and presto ... the job is done.
    That won't spell the end of software design and programming, if anything it might increase the demand for programmers, but lots of coding by the masses will be essentially automated.
    • Vote Up +5 Vote Down
  • clem57
    clem57 over 6 years ago in reply to dougw
    Good point dougw . One down side to using libraries are incorrect calls to the API's. As some changes are made to the code in the APIs, these faults surface with unanticipated results.
    Clem
  • clem57
    Clem
