Clem Martins's Blog Projects using Pi 3
  • Author Author: clem57
  • Date Created: 11 Mar 2016 2:24 AM Date Created
  • Views 1006 views
  • Comments 5 comments
  • pi 3
  • ads-b
  • flight aware
Projects using Pi 3
clem57
clem57
11 Mar 2016
First usage of Pi 3
I installed the Piaware software to feed ADS-B into FlightAware. At first I had problem with Dongle in use:
Found 1 device(s):
0: Generic RTL2832U
  Using device 0: Generic RTL2832U
  Kernel driver is active, or device is claimed by second instance of librtlsdr.
In the first case, please either detach or blacklist the kernel module
(dvb_usb_rtl28xxu), or enable automatic detaching at compile time.
  usb_claim_interface error -6
Failed to open rtlsdr device #0.
Luckily a solution is pretty straightforward. In /etc/modprobe.d create a file called blacklist.conf with the following:
blacklist dvb_usb_rtl28xxu
blacklist rtl2832
blacklist rtl2830
Apparently the upgrade incorporates a new Linux kernel which includes a DVB driver for the dongle as a TV receiver.  Since the device is already in use by this driver, usage fails by anything else. Next:
sudo reboot
Problem gone. Software works great on Pi 3.
Cheers,
Clem
  • clem57
    clem57 over 10 years ago +1
    I have been up for over 1 week and have published data for http://flightaware.com with the following statistics: Date joined Days Tot flights Ave/day Tot pos Ave/day Tot flights Ave/day Tot pos Ave/day…
  • Problemchild
    Problemchild over 10 years ago +1
    The default driver for the DVB dongle is obviously the DVB one in almost all the distros both for the RPI and for other devices so the possible/probable requirement to Blacklist or remove the DVB driver…
  • clem57
    A check on Piaware:
    pi@raspberrypi:~ $ sudo piaware-status
    dump1090 is running.
    faup1090 is running.
    piaware is running.
    dump1090 is listening for connections on port 30005.
    faup1090 is connected to port 30005.
    piaware is connected to FlightAware.
    dump1090 is producing data on port 30005.
    Computer is working! Processor is running at around 6-10%
    Clem
  • clem57
    A check on Piaware:
    piaware is running.
    Clem
