Clem Martins's Blog Projects using Pi 3
  • Author Author: clem57
  • Date Created: 11 Mar 2016 2:24 AM Date Created
  • Views 1009 views
  • Comments 5 comments
  • pi 3
  • ads-b
  • flight aware
Projects using Pi 3
clem57
clem57
11 Mar 2016
First usage of Pi 3
I installed the Piaware software to feed ADS-B into FlightAware. At first I had problem with Dongle in use:
Found 1 device(s):
0: Generic RTL2832U
  Using device 0: Generic RTL2832U
  Kernel driver is active, or device is claimed by second instance of librtlsdr.
In the first case, please either detach or blacklist the kernel module
(dvb_usb_rtl28xxu), or enable automatic detaching at compile time.
  usb_claim_interface error -6
Failed to open rtlsdr device #0.
Luckily a solution is pretty straightforward. In /etc/modprobe.d create a file called blacklist.conf with the following:
blacklist dvb_usb_rtl28xxu
blacklist rtl2832
blacklist rtl2830
Apparently the upgrade incorporates a new Linux kernel which includes a DVB driver for the dongle as a TV receiver.  Since the device is already in use by this driver, usage fails by anything else. Next:
sudo reboot
Problem gone. Software works great on Pi 3.
Cheers,
Clem
  • clem57
    clem57 over 10 years ago +1
    I have been up for over 1 week and have published data for http://flightaware.com with the following statistics: Date joined Days Tot flights Ave/day Tot pos Ave/day Tot flights Ave/day Tot pos Ave/day…
  • Problemchild
    Problemchild over 10 years ago +1
    The default driver for the DVB dongle is obviously the DVB one in almost all the distros both for the RPI and for other devices so the possible/probable requirement to Blacklist or remove the DVB driver…
  • clem57
    The fun never ends. Last night the power goes out and stops PiAware on the Pi 3 of course. When power comes up, The pi 3 beat my router and the time was set by NTP 41 minutes late. So need to do either:
    sudo service ntp restart
    sudo reboot
    Next I change my password and needed:
    sudo piaware-config -user username -password
    The password will be prompted for.
    Weird thing was a sudo /etc/init.d/piaware start did not work. Finally a sudo reboot did.
    Lastly a look at the log in /tmp/piaware.out shows connection or enter:
    sudo piaware-status
    Clem
    mcb1 over 10 years ago in reply to clem57
    Maybe I might need to try the FlightRadar24 software and see if it has any issues.
    I think I have a compatible dongle sitting around, but not sure if it has an external aerial.
    Cheers
    Cheers
