Don Bertke's Blog Initial impression of the TI LDC1000EVM
  • Author Author: DAB
  • Date Created: 21 Sep 2013 7:22 PM Date Created
  • Views 782 views
  • security
  • detection
  • industrial_automation
  • medical
  • adc
  • physics
21 Sep 2013
Early last week I told you all about the Texas Instruments Inductance to Digital converter.
I recieved it yesturday and did some quick tests.
The EVM kit comes with a single board, about 4 inches long and about 1/2 inch wide that plugs into your USB port.
On the board is a small coil, the IDC and an MSP430 chip.
The software is downloaded from the TI website and enables you measure the changes in output as the coil picks up metal approaching it.
If you place your hand infront of the coil, your capacitance interacts with the inductance and gives you a change in the output.
I took my Element 14 pen and used it as a metal object to move in and out of the coil field of view.  The sensor was very sensitive to even small changes in position of the pen.
The TI video demo shows a sensitivity to about 2 microns, which is very impressive.
I bought the EVM to experiment with the inductance changes caused by thunder storms and to look at measuring metal content in various materials.
From my early experiments, it should provide some very interesting results.
I will post more information as I have time.
Meanwhile you should take a look at the TI website and consider what you could do with the inductive sensor.
Who knows, maybe we can get TI to free some up for road testing.
  • tpcipri
    tpcipri over 13 years ago
    I am curious about the range of the device. In the TI demo video they were using a cicrometer at close range. How is the accuracy say 1 to 10 inches away?
    e14 Contributor over 13 years ago in reply to tpcipri
    The range is directly proportional to the size of the coil. For a range of 10 Inches you would need a 10 inch coil.  Watch this space for a LDC1000 roadtest!
