Douglas Wong's Blog Just How Cool Is A Hemmi Slide Rule
  • Author Author: dougw
  • Date Created: 6 Oct 2021 1:32 PM Date Created
  • Views 5132 views
  • Comments 5 comments
  • doug wong
  • sun hemmi
  • sr51a
  • versalog
  • slide rule
dougw
dougw
6 Oct 2021
I made an unexpected discovery the other day while purging some old dead storage. I came across a slide rule and a super 8 movie camera. At this point, these items are mostly just curiosities, but I thought I would see if I could remember how to use a slide rule and blog about it in case members would find it interesting.
If you went through engineering after 1972, you probably never needed a slide rule because calculators took over  after that.
A decent slide rule jockey could go much faster than a calculator, but that didn't stop us from all wanting a calculator. Using a slide rule requires using quite a bit of brain power to plan operations and keep track of decimal points, and making a mistake in reading the result was very common.
My slide rule skills are pretty rusty and I never got really good at it since calculators became available in my second year of university.
This fairly high end Hemmi Versalog slide rule is made of bamboo with a celluloid surface. It still works perfectly after 50 years, with a very smooth action.
How many of you remember carrying around a little booklet of trig tables, which provided more significant digits than a slide rule could?
https://youtu.be/Q0W2GLUhwWE
It was interesting to dredge up some old memories about my university days and try to recall how to operate a slide rule.
If you have any technology memories from before PCs, feel free to comment below.
  • ralphjy
    ralphjy over 4 years ago
    I have fond memories of those old college days.  I also had a Hemmi and a Lafayette and a couple of Picketts (aluminum construction).  All of them still working well today.  I used to carry the pocket one to use when I was working in the lab.
    Not many of us had calculators in those days, so we weren't required to have a lot of precision in our exams.  The engineering slide rule was great because it allowed you to read the frequency, wavelength and impedance numbers directly off the scale without having to do the calculations.  Used to be a lot faster in exams than the guys with calculators image.
  • ralphjy
