Frank Milburn's Blog NSA1166 7-Segment 6-Digit Bubble Displays
  • Author Author: fmilburn
  • Date Created: 21 Oct 2021 6:23 AM Date Created
  • Views 4145 views
  • Comments 5 comments
  • led display
  • nsa1166
  • 7-segment
  • bubble display
  • display
fmilburn
fmilburn
21 Oct 2021
Jameco has these National Semiconductor NSA1166 7-segment 6-digit bubble displays and I bought a couple to distract me from what I should be doing.
They are very simple to drive as each segment has its own pin that is driven high and each digit has a pin to act as the cathode.  I plan to write my own driver but like everything these days, there is an Arduino library that I am using at the moment.  It might make an interesting display for use with my milliohm meter project which is waiting patiently for me to return.
I tested one with my bench multimeter current limited to 3mA to start to make sure I knew which pins were which and then set it up with an Arduino MKR1010 and the SevSegPlus library.
It works!  Behold the mighty '70s technology!
  • ralphjy
    ralphjy over 5 years ago
    Brings back old memories...  Well, almost.  I built a calculator using a similar display and a keypad, but I can’t remember which calculator chip that I used or any of the other details.
  • fmilburn
    fmilburn over 5 years ago in reply to ralphjy
    I had forgotten how tiny they are...
  • fmilburn
